Old Feb 26, 2008, 08:51 AM
NIGHTCTMAN is offline
Find More Posts by NIGHTCTMAN
Joined Jan 2005
Tam 1/12 scale F-16 Question
Dear fellow edf nuts,
I just got my main and front gear installed. My question is about the power system. I am sure I want to go with a 8S setup about 3700 mah or so because the packs could be used in T-rex 500. I like the looks and esp the price of the new midi fan, but want to spend a little money on the motor then. My question is will the Neu motors 1515 1.5 Y 5mm shaft thin case work on the wemo midi fan on 8S ? The Neu motor has a Kv of 1500 and the mega 22/30/3 has Kv of 1270. Tam said that the mega with the midi was about 1500 watts. I saw another member make a post about a medusa 1600 Kv motor on 8S in midi and he said just over 2 kilo watts. Want to get something ordered soon. Does anyone know of good electronic airvalve for small retracts ? Is the jetronics one way overkill for a jet like this?
May just put the servo and mech valve in then. Will a balanced midi fan hold up to the neu motor on 8S with some proper throttle management?
Matt
NIGHTCTMAN is offline Find More Posts by NIGHTCTMAN
Old Feb 26, 2008, 09:02 AM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
You need a two way valve for this retract.
The new Spring Air Mechanical valve works great and is cheap too.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Feb 26, 2008, 11:02 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Go with micro servo and use the valve I supply. You can't find anything else lighter than the one I supply.
Tam
Tamjets is offline Find More Posts by Tamjets
Old Feb 26, 2008, 11:22 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
the new midi fan? lol seriously, I'm pretty sure though you can still get the 5mm prop shaft from wemo for a nue install. And Roberts right, nice mech valve is all you need. And call Tam too, he has these micro valves that are cheap and work great. He has them adjustable or you can use the small adjustable break one for an easy pipe and go. And if your doing doors dont forget to get a micro switch for up action.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Discussion Skymaster 1 : 8 Scale F-16 Power by AP-1200 120mm EDF AirPower RC Electric Ducted Fan Jet Talk 17 Aug 09, 2014 04:32 AM
Build Log TLAR (~1/12) scale F(F Larry Dudeck Electric Ducted Fan Jet Talk 87 May 20, 2009 03:48 PM
Sold Cermark/ejf 1/8th Scale F-16 Edf Grey Camo Scheme PREACHHAMES Aircraft - Electric - Jets (FS/W) 10 Feb 19, 2008 09:41 PM
Tempting 1/18 scale F-16 and F/A-18 display models Thomas B Electric Ducted Fan Jet Talk 8 Dec 29, 2004 06:26 PM
1/5th scale F-16 interest airmcn_3 Fuel Jet Talk 3 Dec 22, 2004 04:41 PM
