Old Feb 25, 2008, 09:09 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
Is there a cheap way to charge a 4S A123?
I'm thinking about building a plane to use an A123 pack. Because it's A123, I think I'll need the extra volts that 4S provides. I was reading about the $10 3S charger, but is there a way to cheaply charge 4S? Thanks for the help.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Feb 25, 2008, 09:14 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
FMA Cell Pro 4 if you are not in a hurry.,max. of 3A charge rate on 4S.
Charles
Old Feb 25, 2008, 10:00 PM
Matthew Cotten is offline
Find More Posts by Matthew Cotten
Joined Oct 2003
Sorry guys, here I go again, drinkin' and thinkin' ......
Why can we not use ANY funky charger (with a balancer hooked up to each cell)and the a123lipodaptthingy???????
Now we are talking 25 bucks for the a123 balancer and an a123 cut off thingamajigggymodizzlsizzle
Matthew Cotten is offline Find More Posts by Matthew Cotten
Old Feb 25, 2008, 10:01 PM
Joined Oct 2003
....mosizzle.dizzle.com?
Old Feb 25, 2008, 10:14 PM
Southern Pride
But as the OP did not list what chager(s) he has or even if he is planing on using 2300 or 1100 mAh cells there is a lot of fill in the blanks here.
Yes a Lipodapter will work if he has a 4S Li charger or a Ni charger capable of charging 12 cells or more and if it has high enough amps. output or he is patient.
I use a very old AF 112PK Ni charger a Lipdapter to charge B&D VPX 1100 mAh 4S packs at 5amps.
The 12volt Pb setting on a Triton will also work but will not give a 100 % charge but then neither will the Daptors.
Charles
Old Feb 26, 2008, 03:29 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
The other option is a generic laptop powersupply from eBay switched to 14.4V. You can find them up to about 120W. Some folks use these with a fan added and some current limiting (a la zip line). You can get them either with AC input for use at home or 12V input to run off your car battery (or deep cycle). Given how cheap 200+W/10A chargers have become I would suggest they are a better, more flexible, no fuss solution.
kgfly is offline Find More Posts by kgfly
Old Feb 26, 2008, 05:53 AM
kmp647 is offline
Find More Posts by kmp647
marshall , va
Joined Jul 2003
this wont charge 4s a123 real fast but it will charge
$47
http://www.allerc.com/product_info.p...oducts_id=1872
kmp647 is offline Find More Posts by kmp647
Old Feb 26, 2008, 08:44 AM
stamper is offline
Find More Posts by stamper
stamper's Avatar
United States, IL, Bartlett
Joined Jun 2002
Charles
I use a Triton with a Daptor. I charge at 3-5 amps and when the Daptor cuts off I re-start the charge at .2 amps until it goes off again a few minutes later. Wouldn't charging at .2 amps give close to a full charge?
stamper is offline Find More Posts by stamper
Old Feb 26, 2008, 01:42 PM
hakank is offline
Find More Posts by hakank
Sweden (Åkersberga)
Joined Nov 2004
Sorry but was is a "zip line" ? Any link?
Tanks in advance,
/Håkan
hakank is offline Find More Posts by hakank
Old Feb 26, 2008, 01:50 PM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Charles
The Goose on a Dapter will - I asked the designer and he also felt this was acceptable procedure
richard hanson is online now Find More Posts by richard hanson
Old Feb 26, 2008, 02:18 PM
Southern Pride
well I have used Sid's LiPo dapters many times and IMO even with double goose IMO it does not provide a full charge on A123 cells. Others may very well disagree. I have several Dapter assisted charges in my A123 charing thread .
http://www.rcgroups.com/forums/showthread.php?t=603368
As someone else posted if you reduce the charge rate near the end or if you reduce it and restart to get a kinda false CV stage you can come close.
This is the very reason my Dan Baldwin designed charge terminators aka
DB Terminators which I use with my Zip chargers are set to stop the charge a 3S to 11.55 V (3.85 per cell). These charges terminate at approx. 7 amps. charge rate which happens to be very close to the 8A max. recomended for the Dapters. I have found that if stoped at a lower voltage the cells are not full enough to prevent rather rapid voltage decay.
My calibration tool was my TP1010C. If the 1010 could add 20 or more mAh capacity right after a Dapter, modified AF109 or Zip / DBT charge then the cells were not reaching full charge.
Of anyone is interested there is a charge graph here showing an official A123 racing charger in operation.
http://www.rcgroups.com/forums/showp...7&postcount=26
Charles
Old Feb 26, 2008, 03:41 PM
Southern Pride
Tanks in advance,
/Håkan
Zip cord is a term sometimes used to describe common lamp cord (electrical line). Since any wire has resistence it can be used in place of a power resistor to limit the flow of current.
My $10 3S A123 pack charger Thread
http://www.rcgroups.com/forums/showthread.php?t=747911
Charles
Old Feb 26, 2008, 04:56 PM
kgfly is offline
Joined May 2006
$47
Not worth it IMO as you still need an external balancer (if you want to balance your LiPos or A123s) so it ends up costing the same as or more than an integrated balance charger anyway and I prefer integrated balance chargers myself. Different strokes...
Old Feb 26, 2008, 10:17 PM
Evansville, WI
Joined Dec 2006
Thanks for the info. I've got a regular Cell-pro 4S, and a Parkzone NiMH charger, but I think the charge rate would be to low. Even my power supply is only rated for 3 amps(and only 13.8V). Part of the allure of the A123 is their ability to be charged fast. If I do it, I'll use the 2300 size cells.
Is there a way I could use something like Everydayflyer's Zip charger to charge 2 2S packs(which would then be run in series)?
Old Feb 27, 2008, 07:04 AM
Southern Pride
Short answer , if you have to ask then no!!!!!
Have you read the first post in that thread?
Do you understand Ohm's law?
If you have a voltage source which is greater than the battery and it is capable of delivering enough current and you have a means to limit the max. delivered current to a level which is safe for the battery and if you have a means to limit the max. voltage to a safe level then yes.
Charles
Discussion Cellpro 4S A123 version--does yours ever "reset" at the beginning of a charge? JWilliams2 Power Systems 15 Nov 29, 2007 05:36 AM
Is there a cheap, safe way to charge Li-Poly cells? mcross Scratchbuilt Indoor and Micro Models 18 Dec 28, 2002 08:31 PM
Is there a better way to order from the US to Canada? Martin Hunter Electric Plane Talk 22 Sep 21, 2002 03:02 PM
Is there a better way? ayanez Foamies (Kits) 0 Feb 11, 2002 08:02 AM
True Flaps (is there a easy way) LJH Electric Plane Talk 13 Jan 08, 2002 07:03 PM
