Old Jan 02, 2003, 10:53 PM
Darwin is offline
Find More Posts by Darwin
Darwin's Avatar
United States, IN, Lafayette
Joined Dec 1996
EPP Adhesives in United Kingdom/Australia
Hello, Guys:
I need some help here. An E-Zone reader in the UK asked me for guidance on an alternative to GOOP. Unfortunately, I no longer have the e-mail files I had collected with this information.
Could our fellow E-Zoners in the UK and Oz help out? I'd like to identify alternatives for GOOP, 3M 77, Dap Weldwood contact cement (as used for applying melamine countertops), and polyurethane glue (such as Pro-Bond polyurethane, Tite-Bond polyurethane, and Gorilla Glue).
All help appreciated, best regards,
Darwin Garrison
Darwin is offline Find More Posts by Darwin
Old Jan 02, 2003, 11:31 PM
Foxy is offline
Find More Posts by Foxy
Joined Nov 2001
Bostick clearbond works, but is slow drying. I mainly use hot glue from a cheap low temp gun. Water based latex contact glue may also work but I havent tried it.
These are all available in Oz
Adam
Foxy is offline Find More Posts by Foxy
Old Jan 03, 2003, 01:34 PM
Mark Grant is offline
Find More Posts by Mark Grant
Mark Grant's Avatar
London, England
Joined Dec 1999
Hi
For fixing melamine or Formica to worktops I use Evo-Stick impact adhesive or an equivilent. 3M 77 isn't available in the UK as far as I know, I got some from the States. Probond is available, it's just finding it that's the problem. I think Bison do, or did a product that was the same or similar. It may or may not be called Timber- tix.
I recently put together a SAS EPP Mamba, water based latex (Copydex) adhesive was supplied in the kit to fix the wing panels together and it worked fine.
Mark.
Mark Grant is offline Find More Posts by Mark Grant
Old Jan 05, 2003, 03:06 AM
Peter Haworth is offline
Find More Posts by Peter Haworth
Launceston Tasmania Australia
Joined Aug 2000
Hi Darwin, it's so long since I gave u the info for Oz I'll have to try to remember it all again.
3M77 is available in Oz, as is the other, lesser 3M products. Office supply stores such as Officeworks for the lesser stuff, art supply stores and engineering supply stores have the real stuff. I think Hobby Headquarters in Sydney may also be wholesaling it to the trade (they also have sheets of EPP).
Goop is available in several forms, Pacer Zap A Dap a Goop should be able to be sourced from any LHS that stocks Zap glues. Shoe repair stores also sell various versions of Shoe Goop.
I used a Canadian product called Weldbond instead of polyurathane glue, and it worked very effectively. I think that there is a Selleys brand polyurathane glue available, and that is available in small tubes. There are a number of boatbuilding polyeurathane glues available, one particularly I've used a week or so ago is called Purbond, but it is available in larger containers only, from a limited number of outlets.
Various types of contact glues are available, and if only small quantities are required, there are smaller tubes available under the Selleys brandname.
cheers
Peter Haworth
(former Oz E-Flight owner)
Peter Haworth is offline Find More Posts by Peter Haworth
Old Jan 05, 2003, 03:25 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
The foaming PU glue known as probond is available in the UK- Nexus Model Supplies carry it for one, and it is available mail order from some of the specialist woodworking suppliers-
such as http://www.axminster.co.uk/default.asp?part=LS7803.
Over here it is called Titebond Polyurethane AFAIK, and comes in a black canister.
I've never used Goop or an equivalent so far as I know, but if it's the stuff that is used for shoe repairs then a word with a local Timpsons shoe repair shop might be able to come up with a similar product- every town had a Timpsons at one time.
leccyflyer is offline Find More Posts by leccyflyer
Slope Sites in Melbourne Victoria Australia blackhawk Slope 6 Apr 17, 2010 01:18 AM
EPP foam in South Africa Barrypfi Foamies (Kits) 3 Jun 01, 2009 01:28 AM
Discussion epp supliers in australia? chris higdon Flying Wings 2 Jun 19, 2007 05:33 AM
Epp foam in Australia???? Brisbane bonnie&clyde99 Foamies (Kits) 7 Apr 30, 2004 09:58 AM
Fs Zagi Epp New In Box $35 wamdue Aircraft - Electric - Airplanes (FS/W) 3 Oct 31, 2002 02:12 PM
