Old May 31, 2001, 09:55 AM
wesdjohn is offline
Find More Posts by wesdjohn
Portland, ME
Joined May 2000
Kadet Senior ailerons? flaps?
I decided to go "bigger is better" rather than with the seniorita/LT-25. Will make a bigger splash my glow-only club.
Other than makeing it a tail-dragger, should I consider ailerons and flaps?
Anyone made these mods? Any info?
TIA
Wes J.
wesdjohn is offline Find More Posts by wesdjohn
Old May 31, 2001, 11:38 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
He might be busy and miss your question, so here's what has to be "Kadet Central"
http://home.networkone.net/~pjburke/kadets.htm
We had one in our group a while back. AF40G, 20 or 24 cells and a couple pounds extra ironmongery in the wings to make them two piece. Never dared weigh the thing, but it still flew just great. Durn thing made some parkfliers look frantic the way it shambled across the sky. It was so easy to fly, we got the owner's wife flying it around one day, she couldn't spell 'aircraft' but had no problems doing figure eights.
Bet you get lots of input on this one.
Regards
Dereck
Dereck is offline Find More Posts by Dereck
Old May 31, 2001, 12:29 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I've found a "normal" Senior Kadet can handle an -extra- 15 pounds!
Our twins at 12-13 pounds are reluctant to land. Glide forever.
Flaps are at: http://www.angelfire.com/indie/aerostuff/kadetflaps.htm
had to move it due to lack of space at "Seriously.."
Sparky Paul http://www.angelfire.com/indie/aerostuff
PJB's Seriously Aeronautical Stuff http://www.networkone.net/~pjburke/index.html
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jun 01, 2001, 10:22 PM
temacc is offline
Find More Posts by temacc
H2OFLY
Portland Oregon USA
Joined Feb 2000
Sparky, your "flaps" page cannot be found at this moment by my computer, using the URL you posted.
wesdjohn: I have a Kadet Senior with extended wing: 91 inches; uses Aveox 1406 4/y with planetary gearbox and 21 Sanyo 2000 cells. Weight is 9 pounds on wheels, 11 pounds on floats. Wing and tail are covered in transparent red Monokote; fuse is grey.
I have yet to finish the nacelles for the other wing: Twin motors; flaps; barndoor ailerons; will use 28 cells running 14 for each motor, probably separately wired and using controllers on each MaxCim. Weight will increase from 9 pounds on wheels to right at 10 pounds, but weight doesn't matter that much with it, as it thermals now at 9 pounds...makes my neck sore!
Go for it - it is a blast to drop flaps in a light breeze, and fly backwards.
Terry
temacc is offline Find More Posts by temacc
Old Jun 01, 2001, 10:36 PM
RedLine is offline
Find More Posts by RedLine
NE Ohio
Joined Apr 2001
http://www.angelfire.com/indie/aerostuff/kadflap.htm
RedLine is offline Find More Posts by RedLine
Old Jun 02, 2001, 12:37 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
thanks, Red. My indexed copy here showed the wrong title for the page..
Paul
Ailerons + Flaps Stability Question KillerWatt Parkflyers 7 Jul 01, 2002 08:43 PM
Weight/Loading differences between LT40 and Kadet Senior Helibee Fuel Plane Talk 1 May 14, 2002 08:34 PM
Kadet senior " TADITO" 40" ARFTF Airshow Aircraft - Electric - Airplanes (FS/W) 0 Jan 01, 2002 09:40 PM
Kadet Senior and spd 600 geared John Zook Sport Planes 5 Nov 13, 2001 10:16 AM
What thrust line for twin Kadet Senior? temacc Sport Planes 13 Jul 21, 2001 11:02 AM
