Old Dec 25, 2010, 09:25 AM
Straight Up is offline
Find More Posts by Straight Up
Vertical Unlimited
Straight Up's Avatar
Mandurah, Western Australia
Joined Mar 2007
Originally Posted by shaprap View Post
The kit arrives with a cheap 11X6 prop, which I suppose EVERYONE replaced with a better one, so why did y'all choose a set up for 11X6 prop?
Why not a 12" or 10" ?
I used an 11x8 to get my target 300W from the motor I chose. That's not an 11x6. I get unlimited vertical climbs with good speed at this power level.
Straight Up is offline Find More Posts by Straight Up
Old Dec 26, 2010, 05:32 PM
serginho_la is offline
Find More Posts by serginho_la
Joined Dec 2010
Ok, I understand, thanks for the tips "Straight Up".
Could someone post the settings you use, or the weight needed to hit the CG, so I can get an idea of what battery I'll use.
serginho_la is offline Find More Posts by serginho_la
Old Dec 27, 2010, 01:25 AM
Vertical Unlimited
Joined Mar 2007
I use a KD A20-22L outrunner, Turnigy Plush 40A ESC, ARCED D591 digital servos on the V-tail, Rhino 1050mAh 3S Lipo. RTF weight is 690g. ESC is mounted immediately behind the motor, with the battery immediately behind the ESC. The receiver (Futaba R617FS 2.4GHz) is mounted under the front of the wing, while the V-tail servos are in-line under the wing (rotated to 45 from vertical to clear the wing). I don't use any lead, and the CG is perfect for me. I balance it just behind the wing joiner.
Old Dec 28, 2010, 05:13 AM
guyst is offline
Find More Posts by guyst
guyst's Avatar
Joined Feb 2010
What is the flight time with this setup?
guyst is offline Find More Posts by guyst
Old Dec 28, 2010, 06:26 PM
onecyclinder is offline
Find More Posts by onecyclinder
USA, CT, Norwalk
Joined Jul 2010
I bought the Passer-X $65 few years back and pritty much built the same. From China 10-20 motor for $12, two mini servos angled in back to fit bigger LiPo and four more mini in the wing. It's a super hot or glider responding qiuckly. Two suggestions add color to one side of the wing and with JR 11-X added flaporons, sweet. Dose a roll lika it's on rails. Oh yah, don't forget small ply for wing screws and tape top and bottom, good luck!
onecyclinder is offline Find More Posts by onecyclinder
Old Dec 28, 2010, 06:37 PM
USA, CT, Norwalk
Joined Jul 2010
By the way has anyone experienced flying The Super Glider with wings swept forward $99 almost looks like the Discus at 101 wing span? Also has wing-lets,I made new ones and it still won't fly, any help?
Old Dec 29, 2010, 12:33 PM
Pisaneli is offline
Find More Posts by Pisaneli
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
My Passer arrived today. Pics will follow.
Pisaneli is offline Find More Posts by Pisaneli
Old Dec 29, 2010, 12:58 PM
AndrewID is offline
Find More Posts by AndrewID
youtu.be/-BG4w4XMBeE
AndrewID's Avatar
Israel
Joined Jan 2009
great and congrats!
mine was send from HK on 10/12 and still qute..really strange (
AndrewID is offline Find More Posts by AndrewID
Old Dec 30, 2010, 01:08 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Good more and more Passers on the air,
@ Andrew, send them an email normally herman answers within 24 hours, just be a bit pushy and they will speed up things for you.
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Dec 30, 2010, 06:50 PM
Greywing is offline
Find More Posts by Greywing
USA, CA, Pismo Beach
Joined Oct 2007
That's good news, Pisaneli. How long did it take to get there? I got mine in about 6 days, all in good shape. I haven't started it yet but I'm very plaesed with the general quality. I got R2hobbies recommended motor Eurgle D2830 800KV with mine. They claim 320W but that seems a bit optimistic for its' fairly modest size. Has anyone else used this motor and if so any comments?
GW
Greywing is offline Find More Posts by Greywing
Old Dec 31, 2010, 01:20 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
well the first I had was supper powerfull, but the second nt so much, you know with this motors and HK is hit or miss but anyway they are good enough for a sport flyer
EZ
Old Dec 31, 2010, 07:41 AM
Vertical Unlimited
Joined Mar 2007
Motor run time is about 2 mins 30 seconds. However, with so much power on tap I once flew it for 1hr 6 mins this way. Flying for 30+ minutes is no problem at all.
Old Dec 31, 2010, 08:49 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
Yeap agreead with 3 minutes motor one can easily make one hour flight
EZ
Old Dec 31, 2010, 04:55 PM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Hi Greywing!
I received mine after 14 days. It was send from HK on the 15th and I received it on the 29th. It came so late because of the customs. It was held there for 5 days.
It came in good shape. The plane was double packed. Yes, the quality is very good, no bubbles on the covering, nice fuselage and good balsa.
I haven't received the instruction manual. Is that the same with the rest of you guys?
Looking forward to start building my Passer.
Old Dec 31, 2010, 05:15 PM
Greywing is offline
Joined Oct 2007
I got an instruction manual on their (R2Hobbies) website. It's not very good, but it's something. Pictures look like they were taken with a phone and not much detail but the assembly is mostly pretty obvious anyway. I see you got a red one. I thought from the discussions in the other thread they might have been out of those. Looks nice.
Discussion Passer X just came! yaitsfast Electric Sailplanes 35 Aug 11, 2011 12:05 AM
Discussion Passer X question please roundthebend Electric Sailplanes 1 Jan 08, 2008 02:16 PM
Discussion Just bought a Passer X. roundthebend Electric Sailplanes 2 Dec 05, 2007 11:29 AM
Discussion electric glider Passer X. tardis Electric Sailplanes 6 Aug 19, 2007 04:34 AM
Discussion Passer-X on ebay skymaster2000 Electric Sailplanes 0 Aug 14, 2006 04:38 PM
