Old Dec 19, 2010, 12:09 PM
Pisaneli is offline
Find More Posts by Pisaneli
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Another option is this motor, TR 28-30B 14A 1050Kv. Cheaper, lighter and still strong enough. I decided to buy it.
Pisaneli is offline Find More Posts by Pisaneli
Old Dec 19, 2010, 12:24 PM
shaprap is offline
Find More Posts by shaprap
Videography and stuff
shaprap's Avatar
Joined Oct 2009
The kit arrives with a cheap 11X6 prop, which I suppose EVERYONE replaced with a better one, so why did y'all choose a set up for 11X6 prop?
Why not a 12" or 10" ?
shaprap is offline Find More Posts by shaprap
Old Dec 19, 2010, 12:54 PM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Well I still use the original prop, but I am thinking to imporve it next week, with a 12x8. I checked my motor, esc, batttery combo with motocalc and I can go with either 12x8 or 13x7. Everything dependes in your combo.
The standard power unit gives me abour 9m/seg climb which is pretty decent for what I am using it for, height limited soaring
regards
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Dec 19, 2010, 02:21 PM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Who choose a 11x6 setup? I decided to go with the TR 28-30B 14A 1050Kv Brushless Outrunner which uses 10x6 prop which is the top prop for it. I always use Aeronaut props and this one is no exception. Because I am not looking for a hotliner and this bird certainly isn't why put too much power on it. 140 Watts is more than enough for Passer.
Old Dec 19, 2010, 02:34 PM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
well everything depends on the actual Kv of your motor, I always test them for accuarcy and the select the prop that gives the best efficiency, a 10x6 prop works good for some motors and not so well for other, there in no rule of the thumb, you need to test bench
EZ
Old Dec 19, 2010, 03:04 PM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
@Edwinzea
Can you tell me what's the diameter of the spinner?
Gorazd
Old Dec 19, 2010, 04:08 PM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
the standar is 3 cms, you have to check the distance between pins of your spiner. some are wider therefore giving extra lenght to the propeller
EZ
Old Dec 20, 2010, 02:15 PM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Just checked the whereabouts of my parcel and found out that the parcel left HK on 17th of January. This means that I will probably receive it after the holiday season.
Old Dec 21, 2010, 06:32 PM
serginho_la is offline
Find More Posts by serginho_la
Joined Dec 2010
What engine fits securely in HobbyKing SS 25A ESC?
I would use the original 11x6" prop and a 3S 1300mAh 25C lipo.
serginho_la is offline Find More Posts by serginho_la
Old Dec 22, 2010, 01:15 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
I would go for a 30A it is the minimun recomended, so if you go down to 25A you are risking a fried ESC, a LiPo fire and a lost plane
EZ
Old Dec 22, 2010, 09:15 AM
Joined Dec 2010
And if I use a 2S lipo battery with a 1100kv motor, how many grams of thrust would pull?
So I could use a lipo with more capacity.
Old Dec 22, 2010, 10:58 AM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
For example if we take this motor:
Here is the test report
Old Dec 22, 2010, 11:18 AM
Joined Dec 2010
Pisaneli Thanks, now I'm in doubt between two options:
1 - Motor KD A22-20L Brushless Outrunner (http://www.hobbycity.com/hobbyking/s...2106&aff=64164)
2 - Motor Turnigy TR2830-1050 (http://www.hobbyking.com/hobbyking/s...idProduct=2112)
The two will be used with a 2S Lipo.
I prefer flight duration, has great thermal here, I would only use the engine to reach them.
Old Dec 22, 2010, 11:24 AM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Because you are a thermal type of guy I would suggest to take the option No.2. The motor is lighter and has low power consuption on 2s which will give you longer flight times. Since you are not looking for a rocket this motor is right for you.
Old Dec 25, 2010, 09:24 AM
Straight Up is offline
Find More Posts by Straight Up
Vertical Unlimited
Straight Up's Avatar
Joined Mar 2007
You need POWER to achieve whatever style of flight you want. Whether you pull 150W (or whatever your target power is) with a 3S or a 2S is irrelevant. With 2S you would need to pull more current than with 3S, so you'd need larger capacity cells (and probably a fairly big prop). Beware that brushless motors generally get less efficient with reduced voltage, so running an 1100Kv motor on 2S is not a recipe for power nor duration. 3S will give you more efficiency. If you want duration, you'll have to sacrifice power.
Straight Up is offline Find More Posts by Straight Up
Discussion Passer X just came! yaitsfast Electric Sailplanes 35 Aug 11, 2011 12:05 AM
Discussion Passer X question please roundthebend Electric Sailplanes 1 Jan 08, 2008 02:16 PM
Discussion Just bought a Passer X. roundthebend Electric Sailplanes 2 Dec 05, 2007 11:29 AM
Discussion electric glider Passer X. tardis Electric Sailplanes 6 Aug 19, 2007 04:34 AM
Discussion Passer-X on ebay skymaster2000 Electric Sailplanes 0 Aug 14, 2006 04:38 PM
