Old Dec 03, 2010, 08:18 PM
Dr. |2udie is offline
Find More Posts by Dr. |2udie
Lower Blue Mountains, Australia
Joined Jan 2006
Certainly does. The spinner and hub I received were a bit dodgey. The hub seems to be suited to a 3.3mm shaft, where the recommended Eurgle motor is 3mm. Spinner is alright; just plain white. The 11x6 folding blades need some balancing though...
Dr. |2udie is offline Find More Posts by Dr. |2udie
Old Dec 05, 2010, 05:10 AM
AndrewID is offline
Find More Posts by AndrewID
youtu.be/-BG4w4XMBeE
AndrewID's Avatar
Israel
Joined Jan 2009
Originally Posted by sharonx View Post
Till XMAS - 50% off for registered users on r2hobbies !!!!
I ordered the green one + eargule 800kv 59g motor.
Does this kit comes with spinner ? with hub ?
Morning Sharon) how r u man?
just thinking to order it too )
but also looking for new HK 2.5m gliders - what you think?
ps. damn) ordered the red one)) welcome to the club !
AndrewID is offline Find More Posts by AndrewID
Old Dec 05, 2010, 10:40 AM
Straight Up is offline
Find More Posts by Straight Up
Vertical Unlimited
Straight Up's Avatar
Joined Mar 2007
Congrats! This is a GREAT plane! Yes, it comes with spinner, hub and folding 11x6 prop.
Straight Up is offline Find More Posts by Straight Up
Old Dec 06, 2010, 02:45 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Man that is an uneatable price, but I already have one :P, I hope you guys enjoy your Passers as much as I do.
Dont forget to put your pics and tricks
regards and good flights
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Dec 06, 2010, 10:38 AM
asterixx25 is offline
Find More Posts by asterixx25
Greece
Joined Nov 2009
Hi guys...
Is a "clear" thermal glider or is a light hotliner ?
asterixx25 is offline Find More Posts by asterixx25
Old Dec 06, 2010, 11:02 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
Is more a thermal, I think you can put a better power unit for extra kick but the wing need reinforcement then, otherwise you will have a rocket
EZ
Old Dec 07, 2010, 03:27 PM
guyst is online now
Find More Posts by guyst
guyst's Avatar
Joined Feb 2010
I just ordered the red one from R2hobbies.
It comes with 11x6 prop and spinner (I assume 3.17mm hub). If I keep the stock prop I need to go towards the 800kv which kind of limit the 28mm motors at HK. Any recommendations for a motor? Should I buy 10x6 prop or 9x6 prop and go with a higher kv?
Will the HXT900 work here?
What size of servo extensions are needed?
Guy
guyst is online now Find More Posts by guyst
Old Dec 07, 2010, 08:41 PM
yaitsfast is offline
Find More Posts by yaitsfast
Is everyone from California?
yaitsfast's Avatar
Orange County, NY
Joined May 2007
asterix... not a light hotliner. Don't let the wing shape fool you, this thing is built extremely light and I would not recommend any high G maneuvers. Although I have never broken mine, I haven't really tried either.
yaitsfast is offline Find More Posts by yaitsfast
Old Dec 08, 2010, 02:48 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
I use all stock, no problems, the 9g servos fit perfect every where, with a higher C rating battery you could use a bigger prop.
I use this motor on my Bolero 2.26m with a 10x6 prop it pulls it at 10m/s I think it will also fit on the passeer, and make sure to mount the prop forwards
http://www.r2hobbies.com/eng/proddet...od=rcps81518_p
Regards
EZ
Guy
Old Dec 09, 2010, 10:50 AM
Vertical Unlimited
Joined Mar 2007
Guy
I use a KD-A22-20L from Hobby King, and 3S 1000mAh packs. I replaced the stock prop with an Aeronaut 11x8 folder. Power draw is 300W, which gives fast vertical climbs. Spectators always gasp the first time they see it zoom to height. I use HXT 500 servos in the wing, and ERC500 digitals for the tail (V-mixed so I get "pseudo rudder").
As for being light-weight, yes you need to fly it within its limits, but I still do loops, rolls and aerobatics. I also like doing knife-edge sharp turns at low altitude when in gliding mode. This is not a pure thermal soarer - I get a lot more performance than simply stooging around for lift.
If you need convincing, check this out:
Passer-X aerobatics.MOV (1 min 44 sec)
Old Dec 16, 2010, 06:22 AM
AndrewID is offline
AndrewID's Avatar
Israel
Joined Jan 2009
Is there the first happy owners of the new 50% discounted birds?
Im ordered this motor and NanoLipo
Curious about what will be balanced for clear CG - where better to put the servos: under the wing or behind the engine ?
Old Dec 16, 2010, 08:29 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
Hey Andrew I have my behind the engineand the ESC attahced to the canopy with velcro, plenity of room this way. but you have to play a bit with the equipement to figure out what works best for your plane
EZ
Old Dec 17, 2010, 05:05 PM
Pisaneli is offline
Find More Posts by Pisaneli
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Mine is coming in the coming week. I hope. Due to holiday season it will be crowdy at the post office so I am keeping my fingers crossed.
This is the motor I am thinking of buying, Turnigy2836 Brushless Outrunner 1000kv It is heavier for around 30g compared to KDA but much more powerfull. I am using it in my allrounder Mibo Dart. The Dart weights 1kg and goes almost vertical with full power on 11x6.
Pisaneli is offline Find More Posts by Pisaneli
Old Dec 18, 2010, 07:21 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
That is the motor you need
EZ
Old Dec 19, 2010, 12:14 AM
ThomasLee is online now
Find More Posts by ThomasLee
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
ThomasLee is online now Find More Posts by ThomasLee
Site Sponsor
Discussion Passer X just came! yaitsfast Electric Sailplanes 35 Aug 11, 2011 12:05 AM
Discussion Passer X question please roundthebend Electric Sailplanes 1 Jan 08, 2008 02:16 PM
Discussion Just bought a Passer X. roundthebend Electric Sailplanes 2 Dec 05, 2007 11:29 AM
Discussion electric glider Passer X. tardis Electric Sailplanes 6 Aug 19, 2007 04:34 AM
Discussion Passer-X on ebay skymaster2000 Electric Sailplanes 0 Aug 14, 2006 04:38 PM
