Old Jan 09, 2011, 04:12 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Hey Seginho, it is better when you clarify from the beginning what you need and why otherwise people just dont bother in going and meassuring things
OK my extensions are about 45cms long, the Carbon fiber tube is 4mm diametre and 35cm long, you can also buy it on R2Hobbies at good price. In fact I never buy extensions, I buy the cable and then solder in between the servo cable is cheaper and you do not have to worrie that the extension will pull off.
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Jan 09, 2011, 09:13 AM
Straight Up is offline
Find More Posts by Straight Up
Vertical Unlimited
Straight Up's Avatar
Mandurah, Western Australia
Joined Mar 2007
EZ
Me too! Now I even make the plugs since you can buy the plug kits cheaply. Beats soldering 6 times!
Straight Up is offline Find More Posts by Straight Up
Old Jan 10, 2011, 11:48 AM
Pisaneli is offline
Find More Posts by Pisaneli
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
I finished the wings yesterday and it took me only two hours two assemble them.
I tried to use the original spinner but found out that the folding props don't match. I will order the new spinner. Left is Graupner and right is chinese folding prop.
Glued the 2mm carbon rod into the canopy.
Pisaneli is offline Find More Posts by Pisaneli
Old Jan 10, 2011, 12:07 PM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
Hey pinaseli, nice work, be carefull with the prisioners they tend to slip :P just put a drop of CA on the nut to secure them
EZ
Old Jan 10, 2011, 01:21 PM
Greywing is online now
Find More Posts by Greywing
USA, CA, Pismo Beach
Joined Oct 2007
Looking better all the time, pisaneli. Looks like you'll be flying it soon.
You probably already know it but Graupner does make blades that will fit that hub - 6mm. You can see them here but I'm sure you probably have a better source closer to where you live.
Greywing is online now Find More Posts by Greywing
Old Jan 11, 2011, 05:27 AM
ggergk is offline
Find More Posts by ggergk
ggergk's Avatar
Australia, NSW, Dubbo
Joined Dec 2009
Originally Posted by Straight Up View Post
I use a KD A20-22L outrunner, Turnigy Plush 40A ESC, ARCED D591 digital servos on the V-tail, Rhino 1050mAh 3S Lipo. RTF weight is 690g. ESC is mounted immediately behind the motor, with the battery immediately behind the ESC. The receiver (Futaba R617FS 2.4GHz) is mounted under the front of the wing, while the V-tail servos are in-line under the wing (rotated to 45 from vertical to clear the wing). I don't use any lead, and the CG is perfect for me. I balance it just behind the wing joiner.
Straight up, what is the distance in mm from the LE to the CG?. I am just finishing a Xmas build kit and I am interested in your CG as it seems to work for you.
Gregg
ggergk is offline Find More Posts by ggergk
Old Jan 11, 2011, 05:20 PM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
A little update.I glued in the fuselage blind nuts for fixing the wing. I had to cut out bigger hole to easily adjust and glue the nuts. I am looking for a maiden this weekend if everything works out as planned.
Old Jan 15, 2011, 07:10 PM
kapeti2108 is offline
Find More Posts by kapeti2108
kapeti2108's Avatar
Joined Oct 2007
Passer Servo Tray
Hi Passer Fans!
I've got mine also before Xmas. Now I have found time to assemble it.
There were interesting solutions for the tail servo placements.
Here is mine:
It's made of 4mm ply, I can let cables run under it to my RX.
Regards
Peter
kapeti2108 is offline Find More Posts by kapeti2108
Old Jan 15, 2011, 07:25 PM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
My Passer is finished. Today I will maiden it. Weight is 650g with Rhino 1250 mAh 3s. I tried to fit in 1600 mAh but had problems with CG. It is too heavy. I balanced it on 66mm from the leading edge.
I made servo cable extensions for ailerons.
I put Rx into shrink tube to easily mount it under the wing.
In front the battery is all the way back with Esc.
Old Jan 16, 2011, 03:24 AM
kapeti2108's Avatar
Joined Oct 2007
Hi Pisaneli,
nice work, grats. Hopefully I've got also maiden today. I've got the same receiver. Did you let the aerials out of the fuse?
Peter
Old Jan 16, 2011, 08:13 AM
Vertical Unlimited
Joined Mar 2007
Gregg
Hi Gregg,
Sorry for delayed response. I just had to get my Passer assembled and do the CG check (accurately, using a proper balancer rather than my fingers). My Passer balances almost spot-on 70mm behind the LE. I've attached a pic to show the layout of the gear too. V-tail works but the rudder is not all that powerful - I typically only use it during the vertical climbs under power.
Old Jan 16, 2011, 09:12 AM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Originally Posted by kapeti2108 View Post
Hi Pisaneli,
Peter
Hi Peter!
I made holes on both sides of the fuselage and let the aerials out.
I successfully maiden my Passer today. Luckily we're having unusal warm weather for this time of the year. Temperature hit almost 15 deegres. Anyway maiden was a success. First throw without motor and then full throtle. The Passer goes almost vertical. A few clicks on the elevator trim and I am flying straight. The plane has no bad habits and is very responsive.
Rudder has enough authority to make circles in a thermal and even some mild aerobatics. When using spoilers for landing I had to compensate small amount of down elevator. It is very sensitive.
Can't wait to hit the slope. I'll upload pictures in the evening and if I'll have time even a video.
Old Jan 16, 2011, 12:14 PM
kapeti2108's Avatar
Joined Oct 2007
Hi,
I also did the maiden flight, without any problems. We had also 10+ celsius.
Good plane, I also had to trim only the elevator.
My AUW is 628g...
Regards
Peter
Old Jan 16, 2011, 04:50 PM
Pisaneli is offline
iSlope
Pisaneli's Avatar
Slovenia
Joined Mar 2008
Here are pictures from todays maiden flight as promised.
Old Jan 16, 2011, 05:11 PM
kapeti2108's Avatar
Joined Oct 2007
Nice pics, nice landscape, nice plane
Here some details of mine:
regards
Peter
Discussion Passer X just came! yaitsfast Electric Sailplanes 35 Aug 11, 2011 01:05 AM
Discussion Passer X question please roundthebend Electric Sailplanes 1 Jan 08, 2008 03:16 PM
Discussion Just bought a Passer X. roundthebend Electric Sailplanes 2 Dec 05, 2007 12:29 PM
Discussion electric glider Passer X. tardis Electric Sailplanes 6 Aug 19, 2007 05:34 AM
Discussion Passer-X on ebay skymaster2000 Electric Sailplanes 0 Aug 14, 2006 05:38 PM
