Old Feb 23, 2008, 06:09 AM
sumomo is offline
Find More Posts by sumomo
sumomo's Avatar
Japan, Kanagawa Prefecture, Hadano
Joined Dec 2006
Build Log
Curtiss Flying Boat
I would like to post building of Arizona Model Curtiss Model F Flying Boat.
I have got it at end of last year and started building today. I start this thread to force me to complete building without giving up on the way.
Actually this kit is not an easy one to me, but I hope I can complete it by spring.
sumomo is offline Find More Posts by sumomo
Old Feb 23, 2008, 07:04 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Fabulous project. We will make sure you do! (finish it)
Old Feb 23, 2008, 08:18 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
I'll second that
charlie
portablevcb is offline Find More Posts by portablevcb
Old Feb 23, 2008, 10:41 AM
MattZC is offline
Find More Posts by MattZC
I just love flying
MattZC's Avatar
Traverse City ,MI
Joined Dec 2005
What's the wingspan on yours? I see on Arizona M. Website that there are 4 sizes, and the 1/12 doesn't list a wingspan. {around 40.5 in} Good Luck!
Checkin in.
~Matt
MattZC is offline Find More Posts by MattZC
Old Feb 23, 2008, 03:36 PM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
I will be watching too! If you have problems, there are some very good model builders here who will help, so you WILL be successful!
GeoffinIN is offline Find More Posts by GeoffinIN
Old Feb 23, 2008, 08:52 PM
sumomo is offline
sumomo's Avatar
Joined Dec 2006
Thank you everyone for your encouragements.
Mine is 1/12 scale. Wing span is about 40" and fuse is 27".
I can't squeeze bigger scale into with my car, therefore 1/12 is only my choice.
I am wondering what motor should be used. Because it is a museum model kit, even small metal parts are included. Especially, engine faithfully reflects Curtiss 1OX engine. Because I wold like to use electrical, I am wondering which motor is suitable to fit into the engine and has suitable power enough to take off her from water surface. (Engine is mounted just below the upper wing and whole engine is exposed. I do not want to spoil the scale mood by using outer-rotor motor. )
I will decide it later when expected weight become clearer.
Old Feb 23, 2008, 08:58 PM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
75 watts per lb will ROW , maybe even less with those airfoils.
lake flyer is offline Find More Posts by lake flyer
Old Feb 23, 2008, 09:29 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
1/12 scale is big enough to produce a model that will fly well, so be happy! Your model's wingspan will be about 61 inches. I am building a 1/12 scale seaplane also. It seems big enough!
Old Feb 24, 2008, 03:36 AM
sumomo is offline
sumomo's Avatar
Joined Dec 2006
Thanks Lake-Flyer. It will help when I decide motor.
Geoffinpdx, I measured the drawing and noticed that I forgot to add center part previously. Total wing span is 114.3cm=45". This is correct.
I spent half day to decide how to build aileron servo assembly. It will be mounted at center of fuse and pull-pull wire linkage will be connected to each aileron. Small pulleys are included to the kit.
Old Feb 24, 2008, 07:22 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Go for about 150W for that. 3s 1500 pack, and something that will drive a sensible diameter prop.
You may find that a 16/15/7 ot 16/15/8 from Mega will be suitable - theyare low KV inrunners. And should maybe drive a 7-8" prop, though to be honest, I can't remember.
Old Feb 24, 2008, 10:31 AM
Al Offt is offline
Find More Posts by Al Offt
Boston, MA subburb
Joined Sep 2004
I chose a Scorpion S2212-22 (http://www.innov8tivedesigns.com/pro...products_id=34 ) to use with a 3S battery for my (not to exceed) 32oz, 36 inch WS flying boat; not sure of your target weight. It consumed 155 watts with a APC 9x4.5E prop on 3S and produced 27 oz of thrust at 8900 rpm on a test stand without even getting warm. The motor is good for 200 watts so it would leave you a little head room if you needed a larger diameter or pitched prop.
Alan
Al Offt is offline Find More Posts by Al Offt
Old Feb 25, 2008, 03:08 AM
sumomo is offline
sumomo's Avatar
Joined Dec 2006
Thanks Vintage1 and Al. Previously I thought to use Model Motor's Mini AC1215/Extreme, because of it's small diameter which can go inside the dummy Engine. But it seems it is too powerful (and expensive). From drawing, it seems 7" is the maximum prop' can be used. Maybe I choose one of the small out-runner.
Old Feb 25, 2008, 05:51 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Mmm. How much space have you got?
a 7" prop is in range on a small inrunner, and if this is light you wont need much more than 70W or so.
Ive got something of similar size running on a 7x4 wood on a United Hobbies 1300KV motor..There is JUST clearance for it inside a 30mm diameter cowling tube.
Its this one, tho mine didn't have a heat sink.
http://www.hobbycity.com/hobbycity/s...idProduct=5427
Run that off somethiong like 3s 800mAh nd you will be fine.
The other option is to use a gearbox with a long shaft, and bury the motor somewhere in the 'crankcase'
Old Feb 25, 2008, 08:57 AM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
If you won't mind the cost an inrunner with a planetary (inline) gearbox might work.
chalie
Old Feb 25, 2008, 01:51 PM
thewildweasel is offline
Find More Posts by thewildweasel
Beware the Axis of Weasel.
thewildweasel's Avatar
Plymouth, Devon
Joined May 2007
Hey vintage1, cheers for that link, I've been looking for a pilot figure for my SU-26, and there's a perfect one there for $4! How reasonable is their shipping to the UK do you know? Don't mind if it's not the cheapest, think I may end up buying quite a lot from them all in one go...
thewildweasel is offline Find More Posts by thewildweasel
Link Glenn H. Curtiss Flying Boat 1914 America jimsp Waterplanes 0 Jun 21, 2007 11:01 PM
Opinions on flying boat TomM Electric Plane Talk 14 Aug 19, 2002 10:17 PM
Flying boat lothlean Fuel Plane Talk 1 Jun 28, 2002 11:20 AM
3000NiMh vs2400 NiCad-Worlds biggest electric flying boat. Dick Curtis Electric Plane Talk 5 Mar 17, 2002 01:48 PM
Who sells the Aventura flying boat in Europe? Fredrik Wergela Electric Plane Talk 3 Feb 17, 2002 11:37 AM
