Old Feb 20, 2008, 06:36 PM
Luis_Claudio is offline
Find More Posts by Luis_Claudio
Luis Claudio - Rio - Brazil
Luis_Claudio's Avatar
Brasil, RJ, Rio de Janeiro
Joined Apr 2005
Build Log
Embraer Tucano T-27
Hello All,
After so much reading and following the building´s steps from friends, I decided to start building my own project.The planes I built before were some Pipers, one Ugly Stick and a Gee Bee, all from Scotta, but in these cases, were not needed to draw a fuse with a knife, to sandpaper it a lot to get the real draw from the project, either cut with hot wire the wing, let´s say they were easiers projects to build, but wonderfull projects, so that I have all them at home!
The plane is the Embraer Tucano T-27. The theme I´ll use to paint is below, it´s from Air Academy Force, (AFA) from Brasil also. I used two "P3" foam pieces: 100 x 500 x 40mm for the wing and fuselage (a kind of harder foam,
there´s here in Brasil, more dense) and for the tail I used 5mm deprom. The fuse was made by two foam plates with 40mm each one, I printed the draw referring from the top and side´s fuselage and hot wired them to start shaping the fuse. After that, a very sharp knife to cut off a good part of foam, and then, a lot of work to do: sandpaper. As the fuse is in two pieces, the places for servos, battery and receiver were already made with knife, as well as the way from servos wire to reach the esc. I still need to make the firewall. The air duct - bellow the prop -, is already excavated and the exit´s air unit (under the fuse) also. It will keep the equipment inside the plane in a low temperature.
After all this process I applied mass for wall correction, to cover the imperfections. I´ve already finished both wing sides and in
the fuse i need to do one more hand, near the cockpit.
Both wing parts are ready fibered and needs to be glued each other. I will hold the wing in the fuse with screw and a pin.
The tail is ready to be instaled.
The pieces are not already glued, I put it together just to see how it looks!
Any suggestions are welcome!
Specifications:
Wingspan: 100mm
Lenght: 950mm
Weight: between 500 ~ 600gr
battery: Kokam 1500mah 3S
motor: AXI221220
prop: Accept sugestions
servos: HS-55
spinner: dubro 1.3/4"
Luis_Claudio is offline Find More Posts by Luis_Claudio
Old Feb 20, 2008, 07:59 PM
Cubber is offline
Find More Posts by Cubber
Naturally altered
Joined Feb 2005
Great Plane. I love the Tucano. Your looks real nice so far.
I had the oppurtunity of sitting into one some years ago at an air show. Tried to sweet talk the pilot into a ride (he was flying for the show)... didn't work lolll
I also have my own RC Tucano, different beast though. Balsa and ply, 1 meter, 260 watts of power, less than 2 pounds... move over honey!!!
I got some 3views of the markings for your particular scheme, but I can't make out the tiny details, especially in Brazilian. I can help you with a custom made high resolution decal sheet if you'd like and provide me with the details.
Cubber is offline Find More Posts by Cubber
Old Feb 20, 2008, 08:10 PM
skaterkid65663 is offline
Find More Posts by skaterkid65663
plane builder
Traveres City
Joined Apr 2006
WOW!!! Thats probly ranking in the top two best looking scratchbuilt foam airplanes i have ever seen. great work, if i could build as well as you could i wouldn't have to spend money on kits i cant wait to see the maiden video, (video's)
skaterkid65663 is offline Find More Posts by skaterkid65663
Old Feb 20, 2008, 08:39 PM
eduardoaap is offline
Find More Posts by eduardoaap
Florianopolis - Brasil
Joined Oct 2007
Great job
I would like to see how you are going to put the servos and battery... post some pics when done
about the prop, you could use 8" or 9"... 9x3.8 would be great with this battery
eduardoaap is offline Find More Posts by eduardoaap
Old Feb 20, 2008, 10:39 PM
62pilot is offline
Find More Posts by 62pilot
Don't look at me like that....
62pilot's Avatar
United States, AR, Piggott
Joined Aug 2005
Luis_Claudio nice looking plane you have there. Good job.
One small request. I drew the Calvin picture and have let parkjets use it on their web site. If you don't mind please change your avatar.
Tom
62pilot is offline Find More Posts by 62pilot
Old Feb 21, 2008, 05:23 PM
Joined Apr 2005
Cubber,
I also love the Tucano! I have one that I bought some years ago. Thanks by your words! In this weekend I´ll keep on the building.
I already have the decals. I made it in corel draw and went to a bureau to print in adhesive paper (with colors) thanks a lot! But stay here!
Old Feb 21, 2008, 05:27 PM
Joined Apr 2005
Thank you so much my friend!
Old Feb 21, 2008, 05:41 PM
Joined Apr 2005
Thank you Eduardo! I´ll post soon more progress!
bye!
Originally Posted by eduardoaap
Great job
Old Feb 21, 2008, 05:43 PM
Joined Apr 2005
Thanks a lot Tom!
Tom
Old Feb 28, 2008, 07:52 PM
Joined Apr 2005
People, after a lot of sandpaper and fill, to take of all imperfections, bellow some pictures to show you how the painting is going. Still have to look at some tail´s places and repair, fill and paint, also in the cowl. I´ve already painted the wing´s downside (with the original color: orange). Still needs to paint the upside, put the adhesives - fuse and wing - and applly the varnish to complete the process. The canopy is installed but protected with tape.
Until now it the weight from fuse and wing is 337gr, I hope it´s okl Comments and tips are all wellcome!
Best regards!
Old Feb 28, 2008, 10:04 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Dude, this is an excellent build! You sure do got talent. Gives us something to strive for.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Mar 03, 2008, 09:00 PM
Joined Apr 2005
Thank you so much Rusty, take a look now!
Old Mar 03, 2008, 09:05 PM
Joined Apr 2005
All,
Here some progress in the painting. Still have to put the varnish, eletronics, motor and link the aileron, rudder and stabilizer.
Old Mar 03, 2008, 09:21 PM
Kurpal is offline
Find More Posts by Kurpal
Joined Nov 2006
My planes look like a 3rd grader put them together by comparison. Great job, I do not have your patients. The downside is no one will believe it is scratchbuilt without some proof. If I may ask, how did you shape the plane to be even on each side? Sand, check, Sand etc? I am impressed you have skill. I hope it flies as good as it looks and that you never crash it.
Kurpal is offline Find More Posts by Kurpal
Old Mar 03, 2008, 09:50 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Beautiful build, Louis!
My eight years old son playing with the thousands wrong pieces cutted by me!
I love the 1 sock look reminds me of when my son was younger
(also how they could sit like that for hours! hurts my arthritis just seeing the picture)
Gene Bond is offline Find More Posts by Gene Bond
Question Embraer Tucano or Shorts Tucano mamethot Scale Fuel Planes 3 Aug 13, 2007 05:07 AM
Build Log T-27 Toucan Embraer FabrícioMC Foamies (Scratchbuilt) 11 Feb 08, 2007 08:21 AM
Embraer TUCANO 312F from CAM TGSN Slope 8 Feb 08, 2005 01:39 PM
FS: Embraer Tucano ARF NIB gouda Aircraft - Electric - Airplanes (FS/W) 4 Jan 18, 2005 09:28 PM
FS/T: Het Embraer Tucano, typhoon 6/20 & aluminum spinner SeanJ Aircraft - Electric - Airplanes (FS/W) 11 Jan 17, 2005 02:21 AM
