Old Feb 18, 2008, 10:10 AM
guyg is offline
Find More Posts by guyg
Israel, Ness Ziona
Joined Sep 2004
Building my A\P EZ* -- Updates
HI ALL
Got today the EZ STAR from the mail
all is ok and i need it for air videos and pic.
seems like a very small rudder plate .
Do i have to extend it ( the rudder ) as biger for better control
or as is to fly well
TX
guy
guyg is offline Find More Posts by guyg
Old Feb 18, 2008, 10:21 AM
JimKallinen is offline
Find More Posts by JimKallinen
JimKallinen's Avatar
New Ulm,MN,USA
Joined Nov 2007
Guy, this is what did to my Easy Star rudder and elevator.
I did not trust the foam hinges they used by just compressing
the foam. I cut it out. Gorilla glued the smaller clevis pinned hinges
into foam that I cut slits and slid them in.They real solid now and
move far easier then the foam did.
Take a look in my blog how did it.
JimKallinen is offline Find More Posts by JimKallinen
Old Feb 18, 2008, 11:25 AM
quailbird is offline
Find More Posts by quailbird
quailbird's Avatar
Rich Hill Missouri 64779
Joined Nov 2003
A lot of guys extended the rudder but the elevator seems to do the trick. I have extended the rudders on all my ez*'s. Looking forward to seeing pictures of you ez*. My friend, Randall1959 just put airlerons on his ez* and he said he loves it. Much more stable for taking pictures. He said he could control it much betterif there is a little wind.
quailbird is offline Find More Posts by quailbird
Old Feb 18, 2008, 03:54 PM
CoastalTom is offline
Find More Posts by CoastalTom
United States, AL, Foley
Joined Nov 2005
Built and flown 2 EZ Stars (one for AP) and on both I made a new rudder from 1/4" balsa about 3 times the width of the stock foam rudder. Just cut a typical trapezoid rudder shape with a slant up (from leading to trailing edge) on the bottom to clear the elv. Use nylon strip hinges (3 ca glued).
Makes it turn when YOU want it to!
good luck
CoastalTom is offline Find More Posts by CoastalTom
Old Feb 18, 2008, 04:25 PM
guyg is offline
Israel, Ness Ziona
Joined Sep 2004
THanks allot all !!
things are running fsat here for me
the bird is allmost done!!!!!!
all in place
i have mounted a 2 times bigger - wider rudder to it
to fly it--
mount the both servos in.... pushrods are in and glued....
mount both horns on rudder and elevetor..
antena was mounted in the fuse before glueing it.
brushless motor plate -- just to mount in place.... motor is here redy and prop too
controller is in place
a few houres..it will be done!!
THEN ..NEED TO THINK ABOUT MOUNTING MY CAM AND VIDEO IN FRONT
AS i see it
This coming froday.... TEST FLIGHT
I will post a few pic ..from building it
TX
guy
Old Feb 18, 2008, 10:59 PM
fmkit is offline
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
front mounted rudder
fmkit is offline Find More Posts by fmkit
Old Feb 18, 2008, 11:51 PM
guyg is offline
Israel, Ness Ziona
Joined Sep 2004
Thanks allot for the time to you all
Will keep updating
tx
guy
Old Feb 19, 2008, 03:03 PM
guyg is offline
Israel, Ness Ziona
Joined Sep 2004
Photo Updates...
I HOPE THIS BIGGER rudder will do the JOB
should i extend it more????
both servo mount should be reanforce-- tommorow
Rudder horn \ pushrod link- tommorow
wing--- done
vent for the motor- OK front air inlet back- mounting plate holes..
will finish all tommorow night
test flight- coming FRIDAY
Guy
Old Feb 19, 2008, 06:04 PM
tsmart is offline
Find More Posts by tsmart
lady lake florida
Joined Mar 2004
Rudder looks good enough, will give you better control.
I mounted my cam vertically; so it is centered. I just use Photo Shop to turn the pics around. You have far less drag that way, you are balanced laterally, and the cam would still look directly out over the nose.
tsmart is offline Find More Posts by tsmart
Old Feb 20, 2008, 12:10 AM
guyg is offline
Israel, Ness Ziona
Joined Sep 2004
TSMART
TX allot
i will try that in the air
what will be the bet ....WILL BE!!
Will post some pic later-- test flight this friday
TX
GUY
Old Feb 20, 2008, 12:13 PM
guyg is offline
Israel, Ness Ziona
Joined Sep 2004
OK!!
THE BIRD IS DONE!!
HALF WAY THRUTLE CRAZY MOTOR.. (no need more then 1/2 way TH)
Pulling like a crazy mule....
at 1/2 thrutle curent was 5A
that with 3s lipo 1700 Ma
At this curent ..i will put in my 1000 Ma 3s lipo.
test flight-- this friday..
Tx
guy
Old Feb 20, 2008, 12:31 PM
MarkJayne is offline
Find More Posts by MarkJayne
Part-Time Super Hero
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Looks real good Guy, although the decals on the wings look upside down to me
Looking forward to the vid.
Mark
MarkJayne is offline Find More Posts by MarkJayne
Old Feb 20, 2008, 12:42 PM
Gray is offline
Find More Posts by Gray
Smile & wave
Gray's Avatar
Lancing West Sussex
Joined Jun 2005
Looks fine to me too Guy. Good luck with your first flight.
Gray.
Gray is offline Find More Posts by Gray
Old Feb 28, 2008, 11:36 AM
wayne is offline
Find More Posts by wayne
Millarville,Alberta,Canada
Joined Jun 2000
Originally Posted by guyg
OK!!
THE BIRD IS DONE!!
Tx
guy
Guy
Great job and I am looking for a new Aerial plane. Question which engine did you use. I want to order a kit also. I just don't know what is the best engine and easy to get for aerial on this platform.
Wayne
wayne is offline Find More Posts by wayne
Discussion Air Hogs F-16 info needed. . . 2Sunny Foamies (Kits) 7 May 12, 2006 11:20 PM
Info Needed re X-Wing from SoaringUSA screamin' eagle Slope 3 Mar 20, 2005 11:39 AM
HB Pilots running Direct Drive Tails. INFO Needed JIMJAM Micro Helis 12 Nov 28, 2003 12:39 AM
Info for all scandinavian pylon pilots! Erik Johansson High Performance 0 Sep 28, 2002 01:29 PM
ESPRIT plane from esprit.com info. needed? speedo Sport Planes 5 Aug 26, 2002 03:45 PM
