Old Jan 01, 2003, 03:16 PM
Mihelich is offline
Find More Posts by Mihelich
Troy, Michigan
Joined Jan 2003
1/96 scale Torpedos
Hi all,
Does anyone know of any 1/96 scale propel torpedo designs or kits you can purchase. I was thinking about designing some for my new Thor Sturgeon class boat.
Tom
Mihelich is offline Find More Posts by Mihelich
Old Jan 02, 2003, 09:18 PM
JIMJAM is offline
Find More Posts by JIMJAM
JIMJAM's Avatar
Columbia, South Carolina, United States
Joined Feb 2000
I made some 1/32nd scale for my U-Boat. Pretty neat wow effect but a pain in the ***. I used some hollow aluminum tube,glued in a aluminum rod with a hole drilled though and added a shraeder valve. My front wtc has a spare servo I used to pull a pin out the rear of the torp sending it on its way. Go to RC_submarines.tripod. Look around and you will see plans for a propel type which I use. I got pics and all just let me know.
JIMJAM is offline Find More Posts by JIMJAM
Old Jan 02, 2003, 09:22 PM
JIMJAM is offline
JIMJAM's Avatar
Joined Feb 2000
The pic is an early operational mock up. When the pushrod pulls back, it pulls the pins out the torpedoes releasing the gas. Each ring attached to the end of the pin are at different lenghts so I can fire off each one at a time. Here is a pic of a earlier torp.
Old Jan 03, 2003, 06:58 PM
Mihelich is offline
Troy, Michigan
Joined Jan 2003
Thanks for the reply JimJam.
It will be quite a feet to make 1/96 scale torpedos work right.
I have just created some Catia (cad) solid models and at 1/4" diameter, it is the same size as a Schrader valve itself minus the theaded valve stem. Very light weight aluminum is in order here with as minimal floatation as possible. I will post some pic's of my design this weekend. It is the same basic concept as everyone else that uses the propel gas theory. But I have a little (and I mean little) cleaner package.
Tom
Old Jan 03, 2003, 08:42 PM
JIMJAM is offline
JIMJAM's Avatar
Joined Feb 2000
Its a real hassle to get the torpedo and its delivery system to work consistantly. Also kinda scary toting around a charged torp waiting to go off. The only reason I attemped it was to please my freinds. I go on and on about how complex my sub is, how many gizmos and thingies it has and how scale it is. But the first thing people say is, " Cool, but will it shoot torpedoes?"
Old Jan 03, 2003, 09:31 PM
Mihelich is offline
Troy, Michigan
Joined Jan 2003
Ya gotta try.
Old Jan 06, 2003, 08:40 AM
U-96 is offline
Find More Posts by U-96
Western Australia Perth
Joined Jul 2002
Gas Torpedo's
You could try using the body of a small pen blow torch from an automotive store as they already have a filler valve fitted to them.
They are also smaller in size than the 1/32 scale torpedo's
Regards Keith
U-96 is offline Find More Posts by U-96
Old May 30, 2004, 02:58 PM
PLANE FREAK is offline
Find More Posts by PLANE FREAK
Got CAD ?
PLANE FREAK's Avatar
Canada
Joined Mar 2004
I read about these in a magazine and the article mentioned when you put your sub into the water since it is colder the pieces contract and the torpedo could "cook off" by accident.
Never point your sub towards anyone it could be very embarrasing / dangerous if you torpedo someone.
PLANE FREAK is offline Find More Posts by PLANE FREAK
Old May 30, 2004, 07:31 PM
JIMJAM is offline
JIMJAM's Avatar
Joined Feb 2000
Overall I felt it just was not worth the hassle both in setup, torp construction,filling them and chasing them down and getting wet. Most run propel but I adapted my sub and torps to use the stuff you blow electronics off with under various names like Dust Off. Propel is expensive and sometimes hard to get unless you order it. You can easily find this stuff everywhere and runs $4 or less a can. I do not think my torps had the velocity to hurt anyone but watching that liquid money spew out the backs of em hurt my wallet.
Old May 31, 2004, 07:11 AM
Merriman is offline
Find More Posts by Merriman
Virginia Beach, VA
Joined Mar 2004
http://www.rc-submarines.com/id47.htm
Merriman is offline Find More Posts by Merriman
Old Oct 04, 2005, 12:02 PM
TMSmalley is offline
Find More Posts by TMSmalley
Apple Valley, MN 55124
Joined Aug 2003
Or; if to amuse your pals a Timex will do, in lieu of a Swiss watch...
http://www.rc-submarines.com/id284.htm
TMSmalley is offline Find More Posts by TMSmalley
1:96 scale GATO class CG Bob Submarines 10 Jan 09, 2009 09:14 PM
1/96 scale Russian Typhoon model for sale. Nemo Submarines 1 Aug 21, 2005 03:35 PM
1/96 scale nuke flasks Ghost 2501 Scale Boats 2 Feb 13, 2005 01:22 PM
1/96 scale fittings Wing Zero Scale Boats 5 Nov 05, 2004 03:18 AM
