Old Jun 21, 2012, 03:07 PM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
New CG
Doing some maintenance on the Pawnee, I checked where my CG was as I never changed it since the first flight. Originally set it up at the most forward CG point and wanted to get it at 3". I would have had to add quite a lot of lead to the tail and decided to change battery position. I was able to move my battery 2 1/4" aft and remove about 3 or 4 oz. of lead from the tail with the CG set at 3" Also moved my BEC behind the CG. Built a "seat" for the new location and looking forward to flying tomorrow.
Harry
Harry H is offline Find More Posts by Harry H
Old Jun 22, 2012, 01:03 PM
evel_knievel34 is online now
Find More Posts by evel_knievel34
Jason Sosa now a DLG junkie
evel_knievel34's Avatar
United States, AL, Clanton
Joined Aug 2010
Was just given a used Pawnee, it had a saito 4 stroke in it but that wasn't included. Servos are in place so I just got to add a new power system and a receiver. I will be using this for aerotowing easy glider pros, cularis, and maybe upto 4m gliders. So I am thinking of going with a power60 or equivalent and use two 3s 4000 in series to have 6s at 4000mah. Want to stay at 6s so I can use 3s packs that I already have. Just got to pick out esc and prop. I typically fly at sod farms and the landing strips are not always that smooth and the grass height is often 3" in height. Thinking I may need to go with a 3 blade prop for Clarence. Anyway I haven't finished reading all theses pages yet sure I will get some insight on what prop to run once I finish reading. Just excited to get this plane towing.
evel_knievel34 is online now Find More Posts by evel_knievel34
Old Jun 23, 2012, 02:36 PM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
You guys are having way too much fun with this plane!
I think that I'll try a Power 60 and 6S with mine. Should easily carry 10,000 mAh.
wuest3141 is offline Find More Posts by wuest3141
Old Jun 23, 2012, 02:56 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
Update on the 3" CG. Flew yesterday in wind changing direction every couple of minutes so not so good of a test. I have flown this plane in worse conditions and it was pretty stable, the new CG is not so stable. I am going to remove all the tail weight which will put it right at 2.75". At least I got to make it a bit lighter.
Harry
Old Jun 23, 2012, 03:00 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
That is going to be a heavy battery. I am using a Power 60 on 6S 5800 and get about 15 minutes and can push it to 18 if I go easy and always returning with 20% in the battery.
Harry
Old Jun 24, 2012, 05:34 PM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
I have my CG at 3/1/8" form the L.E. and a 5000/6S lipo sideways just ahead of the servo's up against the bulkhead the struts tie to. It is on the $ for me. I have a good size 5065 (P80) motor and 100amp ESC under the cowl. This plane is capable of carrying even more weight. Dave/ZEE
zeezee is offline Find More Posts by zeezee
Old Jun 24, 2012, 07:13 PM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
A question for those in the know, i am about to start the build of my H9 Pawnee and will be setting it up for Aero towing. What size motor would i need to accomplish this task? i see a lot going for the e-flite 60 size, has anyone done Aero Tow with this motor? Or would i be better going with the e-flite 90? Or is there another motor that might be a little cheaper than the e-flite ones that will do the job too, eg Turnigy G60 or G110? any help on motor selection would be appreciated thanks
cheers chuck
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Jun 24, 2012, 07:24 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
Chuck, I was following a thread on a Wilga where some were using the Tacon motor. Might want to look into it.http://www.rcgroups.com/forums/showthread.php?t=1564332
Harry
Old Jun 25, 2012, 02:26 AM
Tucson
Joined Nov 2009
This is a big plane and has a lot of wing. It will easily carry 10,000 mAh of 4S batteries.
But with the 6S batteries, I think that I'll use 2 x 3700 mAh batteries.
Old Jun 25, 2012, 12:11 PM
DavidN is online now
Find More Posts by DavidN
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
I am sure it will fly with all the extra weight. However lighter flies different, usually better, unless you need the penetration for wind.
DavidN is online now Find More Posts by DavidN
Old Jun 25, 2012, 12:18 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
I think it would fly with a brick attached to it but would fly like a pig with wings
Harry
Old Jun 26, 2012, 08:27 PM
*Voodoo* is offline
Find More Posts by *Voodoo*
*Voodoo*'s Avatar
Granby,Quebec,Canada
Joined Aug 2009
Hi,how do i reverse the shaft on the power 60 to put a http://www.horizonhobby.com/products...52-60-EFLM1934
thank you
*Voodoo* is offline Find More Posts by *Voodoo*
Old Jun 26, 2012, 09:20 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
Here you go.
Reversing the Shaft:
This Outrunner motor has a shaft, which exits through the rotating part of the motor. If you want to reverse the shaft to exit through the fixed part of the motor, follow these instructions carefully for changing the shaft installation.
1. Loosen the set screw on the shaft collar and remove the collar from its location against the bearing.
2. Remove the small black donut washer that rests against the bearing.
3. Loosen the two set screws in the rotating part of the motor.
4. Slide the shaft through the motor. It may be necessary to use a small hammer to lightly tap the shaft. It is very important that
you do not bend the shaft in this process so use extreme caution to assure this does not happen.
5. Re-install the donut washer against the bearing.
6. Re-install the shaft collar back against the washer and bearing.
7. Retighten all setscrews making sure you line up with the flat spot on the shaft.
Harry
Old Jun 26, 2012, 09:35 PM
*Voodoo* is offline
*Voodoo*'s Avatar
Joined Aug 2009
Originally Posted by Harry H View Post
Here you go.
Harry
Great Thank you
Old Jun 26, 2012, 09:39 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
Do you already have the motor mounted? I want to get the same prop adaptor, just wondering what the difference in standoff distance will be.
Harry
Discussion New EPP Super Zoom 4D from SoaringUSA.com build thread hybris 3D Foamies 2467 May 09, 2012 09:24 PM
MicroBipe from Dynamoelectrics.com - Build Thread badbill Parkflyers 116 May 28, 2008 06:48 PM
Micro Flash (from MiBo Modeli) Build Thread Neil Walker Electric Sailplanes 45 Jul 04, 2005 01:38 AM
NIB Hangar 9 Piper Cub 80" WING RJ Reinhard Aircraft - Fuel - Airplanes (FS/W) 0 May 27, 2003 04:07 PM
