Old Jan 01, 2003, 08:39 AM
thor4944 is offline
Find More Posts by thor4944
thor4944's Avatar
Joined Feb 2002
If I buy a astro 020 motor do I have to do anything if I put it in a pusher
I am probably going to buy a astro 020 for my zagi....with esc....do I have to do anything before I put it on my zagi..I guess I have a couple questions:
1. You can buy the astro 020 motor reversed timmed for pushers for 40 bucks more....what the heck is that? Cant you reverse it buy switching the wires?
2. If I do buy a reg. 020 astro motor with esc...how do I install in on my pusher (Zagi)?..thanks...
thor4944 is offline Find More Posts by thor4944
Old Jan 01, 2003, 10:20 AM
Greg Covey is offline
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
Hi,
I think you may be a bit confused.
Simply swap any two of the three wires from the motor to the controller to reverse the direction of rotation.
There are no timing considerations to change on the 020 and anyplace that charges $40 more for this, I would be sceptical of.
When viewed from the rear of the plane, your pusher motor should spin the prop clockwise.
Good luck!
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Jan 01, 2003, 11:04 AM
crashman is offline
Find More Posts by crashman
Seattle, WA
Joined Jan 2002
Re: If I buy a astro 020 motor do I have to do anything if I put it in a pusher
Only the sensored versions needed to be timed for reverse rotation. The sensorless versions that are sold now just need to have any two of the leads swapped.
You can put in the stock battery tray. Trick RC also sells versions for larger battery packs at https://ecsvr.com/zagi/shopdisplaypr...r+Spare+Parts. You can also build your own mount. Take a look at www.yourzagi.com for a whole bunch of modifications.
I have a low use 020 set up for a Zagi if you are interested in saving a few bucks. Let me know.
crashman is offline Find More Posts by crashman
Old Jan 01, 2003, 03:00 PM
thor4944 is offline
thor4944's Avatar
Joined Feb 2002
sent
Sent you a pm
Old Jan 01, 2003, 03:01 PM
thor4944 is offline
thor4944's Avatar
Joined Feb 2002
amazing
That is amazing......really if you go to some sites...they will sell the astro 020 for 169 dollars with controller..then 180 dollars for the pusher version......crud...cant remember where I saw that at...
do I have to reset voltage if I want to set brake phon 10 steve ypsi mi Castle Creations 0 Oct 29, 2004 05:43 PM
10 cell kans on an astro 020 motor can it take the heat!!! thor4944 Batteries and Chargers 9 May 09, 2003 01:31 AM
Corona w/ Astro 020 motor.. Battery Selection.. Tram Electric Heli Talk 1 Mar 13, 2003 11:14 PM
400C pinion on a Astro 020 motor boomerace Power Systems 3 Feb 18, 2003 05:45 PM
Does anybody have a ASTRO .020 motor on their ZAGI??? funflyer Foamies (Kits) 1 May 17, 2001 10:45 AM
