Espritmodel.com Heli Air
Old Dec 31, 2002, 01:13 PM
Texas
Joined Aug 1999
Lead Sled Alley - December 2002
By Russ Thompson
You may have noticed the name of this column changed from "Crunchie Corner" to "Lead Sled Alley". This is because the word "crunchie" encompasses all non-foam airplanes, but "lead sleds" are, for the most part, what will be covered in this column. This month however, the column will cover something a little different. new
dave_lilley is offline Find More Posts by dave_lilley
Old Dec 31, 2002, 03:23 PM
Lifes 2 short, go sloping
colorado @ 5500feet
Joined Sep 2001
I use 110v to dimmer switch to 24v door bell tranformer (in a protective case) with great success then when I am doing different density foams (EPP, white foam) I get the voltage just right.
I also use a simple bow with fishing leader and it works great everything to cut a wing for 15$...it does take practice but the sled way does as well.
Good article, very complete.
Vinnya42 is offline Find More Posts by Vinnya42
Old Dec 31, 2002, 08:08 PM
Uber Alles Again
SchiessCo's Avatar
North Hills
Joined Nov 1999
Very nice article. My buddy and I built a foam cutter, but never had much luck with it. This gives me the incentive to go out to the garage (tomorrow) and cut some cores.
Pete
SchiessCo is offline Find More Posts by SchiessCo
Old Dec 31, 2002, 10:40 PM
That Freeking Laird Guy
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
these work great. I've been using one for almost 20 years now. But mine cost way less that Russ'.
1 nail (free)
6' of stainless steel fishing leader wire (.016" from Cabelas, $6 I think for 50')
1 old electric train transformer for power (free)
6" off the end of a broom as the handle (free)
I just drove the nail into the end of the workbench.
TFLG
PS if you ever bought a Slope Scale warbird kit the wing was cut this way!
TFLG is offline Find More Posts by TFLG
Old Jan 01, 2003, 09:53 AM
No fuse too fat
slopeiron's Avatar
USA, CA, Redondo Beach
Joined Apr 2002
Yes, I think the stainless steel fishing leader wire is a good alternative to nichrome because it is much cheaper and much easier to find. Unfortunately, the charger I used in this project did not put out enough power to heat more than about 18" of it. I guess that's one more bullet in the list of benefits of using a better power supply - it would allow you to use the cheaper wire.
If you can find one, the electric train power supply is perfect for this application because it already has a variable DC output. Do you happen to know what the max output voltage/amps is on yours Brian?
Vinny,
I also like your idea of using a dimmer switch with a doorbell transormer. A 24 volt output would really help in heating a longer section of wire. My only concern is having AC on the wire. Can you touch the outputs without getting a shock?
Russ.
slopeiron is offline Find More Posts by slopeiron
Old Jan 01, 2003, 08:22 PM
Jim in San Diego
Pismo's Avatar
San Diego
Joined Nov 2002
If you would like an excellent solution to powering up your wire go check out Fry's. The one in San Diego has variac's for around $25 to $60. I can't remember all of the spec's but I think the cheapest one would do the trick.
It's in a nice metal case with rubber feet, plugs into your AC outlet, has an on/off switch, and a dial to dail in any voltage within it's voltage range. I bought mine over the Internet (search for Variac's and you should be able to find one for sale near you) and paid a bit more but it may be higher quality. I may have also just paid too much
Happy cutting.
Pismo is offline Find More Posts by Pismo
Old Jan 01, 2003, 08:51 PM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
We consider <30 volts to be non-hazardous in normal conditions. (Don't stick it in yer mouth and go stand barefoot in the rain, ya know... )
mw (electrician)
Mark Wood is offline Find More Posts by Mark Wood
Old Jan 02, 2003, 08:35 AM
No fuse too fat
slopeiron's Avatar
Joined Apr 2002
Thanks Mark. I wasn't really sure what the threshold was.
Russ.
Old Jan 03, 2003, 08:24 PM
Dances With The Wind
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
I tried the type of setup that Russ and Brian use, however I was not successfull. It was quite a while ago and I don't remember now what went wrong, all I remember is that my cores were unusable.
Later, I got a good deal on a feather-cut clone, and I have cut some good cores with it. Making four templates (Two for each end), setting up the cutter, getting all the pulleys arranged exactly right etc, is a real pain. The best part is that after it is all set up, you just hit the power switch and watch the machine make the cut for you.
Brian sure makes it sound so simple and easy to cut cores his way! I think the simple setup might outweigh the advantage of the hands off cut. I might just have to grab a nail, some wire, and broom handle and try it again.
I use a 10 amp car battery charger as a power supply, with a light dimmer switch attached to control the power. This setup provides more than enough juice to heat up a 40" cutting bow with stainless wire attached. I only use about 2/3 of the available power.
Brian Courtice is offline Find More Posts by Brian Courtice
Old Jan 07, 2003, 10:38 AM
No fuse too fat
slopeiron's Avatar
Joined Apr 2002
I just ran across this thread in 'The Workshop' forum. I has a link to some cool foam cutting tools. They also have a couple of fairly inexpensive power supplies.
http://www.rcgroups.com/forums/showt...threadid=82448
Russ.
Article Lead Sled Alley - April 2003 Russ Thompson Thermal 0 Apr 16, 2003 12:00 PM
Lead Sled Alley - February 2003 dave_lilley Sailplane Talk 0 Feb 14, 2003 12:29 AM
Lead Sled Alley - February 2003 dave_lilley Slope 0 Feb 14, 2003 12:29 AM
Lead Sled Alley - December 2002 dave_lilley Sailplane Talk 0 Dec 31, 2002 01:13 PM
Article Lead Sled Alley - December 2002 Russ Thompson Sailplane Talk 0 Dec 31, 2002 12:00 AM
