Old Aug 05, 2011, 01:33 AM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
This one would be a bolt on job
http://www.greathobbies.com/producti...d_id=SCOS40002
the 4025 is longer so you would have to shorten the 4 standoff spacers
http://www.greathobbies.com/producti...d_id=SCOS40006
your 100 amp esc should be fine 5 to 6 minutes flying with throttle control
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Old Aug 05, 2011, 07:05 AM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
Thanks Adrian!
1500 vs 2000 watts... So what kind of prop would I use with each motor? And I suppose this would be based on a 6s 4000 -5000 mah...
ViperZ is offline Find More Posts by ViperZ
Old Aug 05, 2011, 04:28 PM
Adrian_M is offline
Joined Dec 2010
Originally Posted by ViperZ View Post
Thanks Adrian!
Viper don't look at watts too much, i have gone faster with less watts as far as props go you will have to try different ones you could start with 12 x 8 and go from there, always check you amp drew any of those motors are good for 120 mph + and 6s 5000mAh 35c lipo
Old Aug 05, 2011, 04:59 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
Okay, sounds like a power/watt meter needs to be placed in the tools to get tab as well
Thanks for that information. I may try the 4020 10T motor then. Sweet!
Old Aug 05, 2011, 05:13 PM
Adrian_M is offline
Joined Dec 2010
I use the 150 amp eagletree datalogger it's a great too, that motor will be sweet on 6s, you could eve go bigger mAh wise as lond as yo use 35c up lipos the weight won't matter much
Old Aug 05, 2011, 05:36 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
That is cool.. I never realized the amp draw numbers would be real flying data, and thought it was more bench test extrapolation... Cool!
The long I stick around here, the more I learn. So while my head is filling with info, my bank account is draining A good trade off I think
Old Aug 05, 2011, 05:43 PM
Adrian_M is offline
Joined Dec 2010
I brought the datalogger when i was doing rc boats i don't really use it in flight just for static amp draws but it is nice to be able to use it in flight now and then
Old Aug 05, 2011, 06:33 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
I was thinking a bench top unit to test and measure as well, however my understanding was I could also grab the data after flight from the Phoenix Ice ESC data log... Whats cool about yours is you can actually telemetry that to your DX8 or other unit (I assume).
I was going to get a Scoprion ESC, however the Phoenix Ice Data logger sucked me in
Old Aug 05, 2011, 06:56 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
@Adrian~
Earlier you suggested the Scorpion ESC; I have never given their ESCs any consideration before. Would you say they are of equal or better quality than Castle Creations?
Bradley
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: Please kill isis
Old Aug 05, 2011, 07:57 PM
Hossinarizona is offline
Find More Posts by Hossinarizona
More Speed Indeed!
Hossinarizona's Avatar
USA, AZ, Tucson
Joined Nov 2007
Hello guys,
I have read the entire 53 pages about various set up's, here is what I currently have: Neodym 46-580, Castle Creations Phoenix Ice 75, and all Hitec HS485HB's. I am running this on a 5S 4000 mAh 45C battery. I want to get more out of it however, I really don't want to run more than 1 pack. So that being sais, what motor, prop, ESC and battery would someone suggest? It flys nice now but I want to push it a bit more, any help would be greatly appreciated.
Hossinarizona is offline Find More Posts by Hossinarizona
Old Aug 05, 2011, 08:11 PM
Adrian_M is offline
Joined Dec 2010
Originally Posted by bsbauman View Post
@Adrian~
Bradley
Hi Bradley
i don't have any experience with Castle Creations escs for aircrafts in my Boats days some of the guys in my club used them and i did see many go up in smoke i used MGM & Schulze and they where bulletproof
I use the Hyperion ATLAS 90A 12S ESC, OPTO (same esc as the Scorpion) in my Sundowner and have pushed it really hard up to 140 amps still going strong
So in my book they are a great esc
Old Aug 05, 2011, 08:15 PM
Adrian_M is offline
Joined Dec 2010
Originally Posted by Hossinarizona View Post
Hello guys,
Hi Mike the setup suggested to ViperZ would be a nice & fast
Cheers
Adrian
Old Aug 05, 2011, 08:22 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
Hi Bradley
Can't go wrong with a Scorpion, I wanted one just because I planned to run a Scorpion Motor... Maybe another time
Cheers
Adrian
+1 I'm liking it and will most likely go withthat set-up
Old Aug 06, 2011, 06:58 AM
Adrian_M is offline
Joined Dec 2010
you really want to know what amperage you pulling before your flight so you should do it static amp draw then dload the data from your esc and take a look at it before you fly the plane
Old Aug 06, 2011, 07:06 AM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
Right! Thanks for reminding me
Discussion Power system for Hangar 9 Sundowner 50 RB51 fan Power Systems 3 Apr 11, 2011 01:03 PM
Discussion hanger 9 sundowner 50 planefixer Fuel Plane Talk 57 Oct 26, 2010 07:59 AM
Cool Hanger 9 Sundowner 50 size cryhavoc38 Sport Planes 10 Feb 17, 2008 10:27 PM
Question Hangar 9 Sundowner 50? GJVO Fuel Plane Talk 0 Aug 23, 2007 02:38 PM
EDF 40/50 Brushless setups/results kd4gfy Electric Ducted Fan Jet Talk 0 Feb 20, 2005 03:11 PM
