Old Sep 06, 2012, 06:17 AM
FunQBass is offline
Find More Posts by FunQBass
France, IdF, Chelles
Joined Jul 2011
Originally Posted by Webmaister View Post
I'm assuming you have to reverse the shaft on all the HK Motors? What about the S motors? If I want to go FAST, is HK with reversing the shaft the way to go?
You have to reverse the shaft on HK series, only if you can not or do not want to use a special mount.
For fast setups with HK series without shaft reversing, a custom mount like Darthwonga's seems to do it well !
I looked at reversing the shaft, but on the Scorpion HK3-4025 at least there is no groove for a retaining C-clip or anything on the shaft to stop the motor bell pulling away from the stator if the shaft was reversed (because it's really a heli motor I guess). So I made up a custom prop adapter and motor mount instead, which has worked fine so far.
To be able have the motor with the reversed shaft, I made a new groove at the 8mm end of the shaft, hoping the single C-Clip will be strong enough to withhold prop+ spinner + rotor.
Recently, i read another solution on the Scorpion Thread, which is to change the shaft for a s4035 series, 8mm all along, with flats on it and long enough to allow a collar on the rear side, stronger that a single C-Clip for sure...
FunQBass is offline Find More Posts by FunQBass
Old Sep 06, 2012, 03:08 PM
mattyhawk is offline
Find More Posts by mattyhawk
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
No way I would trust a c-clip. I have made my own notches for motors, but all in the less than 500w range.
This is most desired. Notch the shaft and throw a c-collar on it, then you won't have to worry about it at WOT
mattyhawk is offline Find More Posts by mattyhawk
Old Sep 07, 2012, 07:29 AM
Darthwonga is offline
Find More Posts by Darthwonga
May the Farce be with you
United Kingdom, Scotland, Dundee
Joined May 2006
I'd have to agree, I wouldn't trust one of those little C-clips to take all the motor strain by itself! I guess I could have made a new shaft rather than the mount, but I like that my mount keeps the prop as close to the motor bearings as possible, less overhang means less strain on them (I think).
Here's the first video that I've managed to get from my Sundowner in flight, unedited. Still trying to get the camera settings right, so the colours are a bit off, and I didn't really go balls-to-the-wall, wanted to get comfortable with the handling change after bolting the camera on. Plenty of throttle management meant the batteries where only about 50% down by the end. Please ignore the landing, it was truly crap (forgot to use my rudder thumb enough, really need to on this model to keep it lined up on the runway)!
Sundowner 50 - First Video (4 min 48 sec)
Cheers,
Oliver
Darthwonga is offline Find More Posts by Darthwonga
Old Sep 07, 2012, 10:20 PM
olllian is offline
Find More Posts by olllian
olllian
olllian's Avatar
United States, AZ, Chandler
Joined Nov 2011
Boys i have been loving the SD50 on 10s 4035-400kv Scorpion motor with a 12x12. I am doing a little project thats cheap and i think will be fun and fast at low cost. I try to stay away from HK inmy big planes but check this out. i got this moter And got this shaft that fits perfict in it. I pushed the shaft out the other side. The moter looks good and planning on running on 10s still with a 12x12 prop. We will see how the bearings hold out wish me luck.
http://www.hobbyking.com/hobbyking/s...ize_heli_.html
http://www.innov8tivedesigns.com/pro...0c6259cb90fa52
olllian is offline Find More Posts by olllian
Old Sep 07, 2012, 10:22 PM
olllian is offline
olllian
olllian's Avatar
Joined Nov 2011
http://www.youtube.com/watch?v=SXP0w7BYMsE
Cheers,
Oliver
Nice vid
Old Sep 10, 2012, 07:24 AM
Webmaister is offline
Find More Posts by Webmaister
I like Fast Warbirds
Webmaister's Avatar
United States, GA, Atlanta
Joined Nov 2011
Wonder if this shaft would serve if I wanted to reverse the shaft and not make a custom mount?
Webmaister is offline Find More Posts by Webmaister
Old Sep 11, 2012, 08:10 AM
olllian is offline
olllian
olllian's Avatar
Joined Nov 2011
That's what I am doing but the stock shaft has a flat spot all the way down so that's why I had to get a new one. I wont be needing a special mount. I don't like adding to much to the nose.
Old Sep 11, 2012, 03:45 PM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Probably the original shaft won't work, but if you are in the US, MCMasterCarr is an excellent place to pickup 6mm shaft stock in 1 foot lengths. They work great.
Old Sep 11, 2012, 03:46 PM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
I was looking at those motors, look really good, but the price is a bit high for me right now. Hope the motor works well for you, give a report, ok?
Old Sep 13, 2012, 10:44 AM
olllian is offline
olllian
olllian's Avatar
Joined Nov 2011
Will do just got the shaft today
Old Sep 13, 2012, 02:28 PM
Ep0wer is offline
Find More Posts by Ep0wer
Joined Jan 2012
you probably would have been better off buying the S 4035 8mm shaft i have used it myself on a Hyperion HS 4035-500kv motor with great success
Ep0wer is offline Find More Posts by Ep0wer
Reply With Quote  (Disabled)
Old Sep 13, 2012, 06:24 PM
olllian is offline
olllian
olllian's Avatar
Joined Nov 2011
I alredy have a nice trueturn spinner that is 6mm at the end thx anyway man. This shaft i got has the same clip distance and right demintions!
Old Oct 10, 2012, 11:05 AM
Webmaister's Avatar
Joined Nov 2011
Borrowed your setup advice for my Foam P51
Although not a Sundowner, I wanted to incorporate some of the power setups you guys are running into an Airfield 1450 mm P51 EPO Foam Plane. Here's the results...
Here's the maiden flight of an AirField EPO 1450 MM P51 Marie with a Scorpion 4025 - 740 running on 8S. The prop was a 11 x 8. Voltron measured 119.3 MPH. Still have 2 more cells to add but I need to upgrade to an HV ESC and those things are expensive. This thing is a knee shaker for a foam plane..
World's fastest Airfield P51 Project (3 min 2 sec)
World's fastest Airfield P51 Project GPS Speed Check (0 min 42 sec)
Old Oct 10, 2012, 02:56 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Goodness! That's a big chunk-o-foam to be dragging thru the sky!!! Good job managing all that torque, and good luck with 10s. Oughta be nuts.
Oh, and nice landing. I didn't see that groundloop at the end
Josh
jgalexander is offline Find More Posts by jgalexander
Old Oct 10, 2012, 03:38 PM
Webmaister's Avatar
Joined Nov 2011
Josh
hehe. thanks man.
Discussion Power system for Hangar 9 Sundowner 50 RB51 fan Power Systems 3 Apr 11, 2011 01:03 PM
Discussion hanger 9 sundowner 50 planefixer Fuel Plane Talk 57 Oct 26, 2010 07:59 AM
Cool Hanger 9 Sundowner 50 size cryhavoc38 Sport Planes 10 Feb 17, 2008 10:27 PM
Question Hangar 9 Sundowner 50? GJVO Fuel Plane Talk 0 Aug 23, 2007 02:38 PM
EDF 40/50 Brushless setups/results kd4gfy Electric Ducted Fan Jet Talk 0 Feb 20, 2005 03:11 PM
