Old Aug 23, 2012, 07:28 PM
Darthwonga is offline
Find More Posts by Darthwonga
May the Farce be with you
United Kingdom, Scotland, Dundee
Joined May 2006
As requested, here's a handful of photos of my Sundowner with the lights on. They're running off a separate 4.8V NiMH pack under the battery tray at the moment, might install a UBEC for them and run them off the flight pack. Draw too much current to run them off the receiver's UBEC.
Haven't managed to get any pics of it in flight yet, being the pilot and the photographer at the same time is a bit tricky!
Cheers,
Oliver
Darthwonga is offline Find More Posts by Darthwonga
Old Aug 23, 2012, 07:37 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Very very cool!
brushless55 is offline Find More Posts by brushless55
Old Aug 23, 2012, 07:51 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
That's awesome Oliver. Thanks for sharing. I was poking around on web and checked out their setup - its actually pretty affordable, which is nice.
Thx again,
Josh
Brushless, you might try posting your question in the battery forum - much higher chance of finding other Nano users if you broaden your reader base.
http://www.rcgroups.com/batteries-and-chargers-129/
Best,
J
jgalexander is offline Find More Posts by jgalexander
Old Aug 23, 2012, 07:52 PM
MarkF is offline
Find More Posts by MarkF
Battery Puffer
United States, NV, Las Vegas
Joined Nov 2001
Brushless why don't you try the Dinogy packs. There 65C and have a warranty but I think you already know that. Some of the EF-1 pylon racers ( I'm also the sponsored battery for that class ) are using them and I'm getting great feed back from them. I don't think you will find a better battery for the price. Check them out at performancerclipos.com
Mark
MarkF is offline Find More Posts by MarkF
Old Aug 24, 2012, 09:51 AM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Cool work Wonga!
I would keep your setup as it sits. Personally I do not like to power my lights off of flight or receiver batteries- If at all possible, carry the extra weight of a separate battery.
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Aug 24, 2012, 07:42 PM
FunQBass is offline
Find More Posts by FunQBass
France, IdF, Chelles
Joined Jul 2011
Originally Posted by Darthwonga View Post
I'm using a Scorpion HK3-4025 550kV Motor running an APC 11x14 prop on a pair of 6S 2650 Turnigy Nanotech 45/90C packs in parallel.
Oliver
Hi Oliver, could you post a pic of your motor with the mount please ?
I've got a HK4025-740 in my Pulse XT-40 (5s - 1200W setup, a little one compared to those in this thread... but very nice anyway ) , I had to reverse the shaft and cut the excessive length of it, i am curious to see how you proceeded with yours.
Phil
FunQBass is offline Find More Posts by FunQBass
Old Aug 25, 2012, 10:35 AM
Joined May 2006
This is how I've mounted the HK3-4025. I machined it out of aluminium myself, didn't look very practical to reverse the shaft, I guess because the motor is meant to go in a big heli. I've added washers to some of the stand-offs to tune the down and right thrust to get it flying straight at full throttle. Probably a bit industrial!
Cheers,
Oliver
Old Aug 25, 2012, 10:56 AM
FunQBass is offline
Joined Jul 2011
Great job !
I suppose this mount handles the huge amount of power rather well, without bending, otherwise the rotor may touch the mount, as there is very few space left between the two !
Heli motors can do the job on airplanes, for sure !
But I keep asking myself what stress may damage bearings most on these particular kind of heli motors. Heavy 3D heli flying, or big 12 inch prop on a airplane ?
Phil
Old Aug 25, 2012, 12:28 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
The heli gears put side load on the shaft. I would think that wears the bearing out before a well balanced prop would.
Steve C is offline Find More Posts by Steve C
Old Aug 25, 2012, 01:23 PM
Joined May 2006
There is certainly no give in the mount, the firewall will give way well before the alloy bends. The mount is such a tight fit to get the motor right to the end of the cowl - I didn't want a lot of overhang or a long prop adapter that could waggle around! There is about 1mm of clearance on each of the four struts - I milled flats on them to clear the motor bell.
Regarding the bearings, I am a little concerned about that - although a heli will put side loads on them, that is exactly what a ball bearing is designed to handle. There is a bit of axial float on the motor, and I don't like the idea of all that prop thrust acting through normal ball bearings - I might open it up and fit a thrust bearing between the bell and the stator if the bearings start complaining.
You can certainly feel the motor torque - got to have an active rudder thumb on the takeoff roll, the tail squirrels around alot, and at one point I had to do a go-around, flicked the throttle wide open and the plane did a quarter roll! Such a steep prop pitch also makes it tricky to accelerate if you let the speed bleed off too much - you really don't get much thrust when the blades are stalled, it usually takes ten seconds or so after takeoff before the model gets up enough speed for the prop to really bite. I'm really going to have to get some video of it in action, I love it! Now, how can I make it faster.... ;-)
Old Aug 27, 2012, 02:09 PM
USA, GA, Atlanta
Joined Nov 2008
Have you done anything to reinforce your firewall/motor box Wonga?
If not, I would be sure to check it every month or two at least. I was lucky enough to see the wood separating before it gave out; most are not that fortunate... This is my second SD 50 and this model has been going for over a year before I noticed that.
Before my maiden, I had soaked the entire firewall/mount with wood glue to sure up the joints and bonds, but I should have gone the extra effort and fg'd as well. It would have saved me some trouble a little later down the road.
Old Aug 27, 2012, 04:21 PM
mattyhawk is offline
Find More Posts by mattyhawk
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
+1
Might consider adding some angle wood to the inside of the box.
mattyhawk is offline Find More Posts by mattyhawk
Old Aug 27, 2012, 07:09 PM
Joined May 2006
I just checked the motor box and firewall, and it looks nice and solid. I don't know if they've changed how they build it, or if I added it and have forgotten (wouldn't be the first time!), but there is already some triangular hardwood gussets epoxied into the corners of the motor box. I'll keep an eye on it, cheers for the head's up!
Cheers,
Oliver
Old Sep 05, 2012, 08:45 PM
Webmaister is offline
Find More Posts by Webmaister
I like Fast Warbirds
Webmaister's Avatar
United States, GA, Atlanta
Joined Nov 2011
Phil
I'm assuming you have to reverse the shaft on all the HK Motors? What about the S motors? If I want to go FAST, is HK with reversing the shaft the way to go?
Webmaister is offline Find More Posts by Webmaister
Old Sep 06, 2012, 03:40 AM
Joined May 2006
I looked at reversing the shaft, but on the Scorpion HK3-4025 at least there is no groove for a retaining C-clip or anything on the shaft to stop the motor bell pulling away from the stator if the shaft was reversed (because it's really a heli motor I guess). So I made up a custom prop adapter and motor mount instead, which has worked fine so far.
I stuck a Replay XD camera on the Sundowner last night and had a couple of flights with it before the light got too poor, I'll post the video once I've had time to clean it up a bit (still getting the hang of the camera settings).
Cheers,
Oliver
Discussion Power system for Hangar 9 Sundowner 50 RB51 fan Power Systems 3 Apr 11, 2011 01:03 PM
Discussion hanger 9 sundowner 50 planefixer Fuel Plane Talk 57 Oct 26, 2010 07:59 AM
Cool Hanger 9 Sundowner 50 size cryhavoc38 Sport Planes 10 Feb 17, 2008 10:27 PM
Question Hangar 9 Sundowner 50? GJVO Fuel Plane Talk 0 Aug 23, 2007 02:38 PM
EDF 40/50 Brushless setups/results kd4gfy Electric Ducted Fan Jet Talk 0 Feb 20, 2005 03:11 PM
