Old Aug 19, 2012, 12:30 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
has anyone tried the 65/130c nano packs?
brushless55 is offline Find More Posts by brushless55
Old Aug 20, 2012, 08:55 AM
Madmax1965 is online now
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
If I can get 6 minutes running then this would be great. As for the Motorcal not being able to match up this motor I can't figure. I fly most times using Hacker motors and I know the Hackers can have quite a bit of headroom as far as going over the manufactures recommended voltage and amps............so maybe the Hyperion motor can do the same thing. At any rate I do like this setup and I did find some use for a motor which I had sitting around with no use.
Thanks guys for the help. This motor will end up in a new Hyperion 40E P-51 Mustang.
Madmax1965 is online now Find More Posts by Madmax1965
Old Aug 20, 2012, 08:58 AM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
brushless55 :
I have been using the Gen Ace packs in all my planes including my large EDFs and they work really well.......no problems, prices are great and if you subscribe to their site you can catch great sales on their lipos.
Old Aug 21, 2012, 06:05 AM
ACKopter is offline
Find More Posts by ACKopter
Branford, Florida
Joined Jun 2010
Originally Posted by Madmax1965 View Post
brushless55 :
I havent really been keeping up but are the 25C Gens Ace still the best ones to get?
ACKopter is offline Find More Posts by ACKopter
Old Aug 21, 2012, 08:50 AM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Yes I like the 25C Gen Ace.........I have used the 3000Mah(35C) and the 5300mah packs in 4s and 6s and never a problem. Hobby Partz has sales quite often ....order a pack and try them.
Old Aug 21, 2012, 12:27 PM
big ignore list
Joined Nov 2011
brushless55 :
Just throwing this question out again to those who may have tried the newer 65/130c Nano packs
I have some gens 30c packs and I'm not all that impressed with them..
I race FE boats and my smaller setup pulls 45 to 55 amps cont on 5000mah
and my big 4s boat pulls about 95 to 110 amps cont on 10,000mah
I'v been doing some amp testing on a rig I have up
started out with 30amp cont
then went to 45amp cont
I will put something together that pulls closer to 80amps cont to try my 6 different branded lipo packs against each other..
so far the 30 and 45 amp testing has brought some interesting finds..
Old Aug 21, 2012, 03:23 PM
Darthwonga is offline
Find More Posts by Darthwonga
May the Farce be with you
United Kingdom, Scotland, Dundee
Joined May 2006
Thought that folks might be interested in my Sundowner setup. This is my second attempt, my first used a dirt cheap motor which burnt out on a full throttle climb out - was just a bit exciting seeing an electric model leave a smoke trail like a nitro slimer, never landed so fast in my life! Could feel the heat from the motor through the cowl, windings were charcoal! Anyway, the new setup works beautifully.
I'm using a Scorpion HK3-4025 550kV Motor running an APC 11x14 prop on a pair of 6S 2650 Turnigy Nanotech 45/90C packs in parallel. I'm using a HobbyKing Super Simple 90-100A ESC, running the radio gear off an HV UBEC (again from Turnigy). Had to add a little ballast to the tail to get the CoG right.
The Eagletree GPS sensor has logged a best speed of 149.6mph, although I think that was with a good tail wind, seeing 130-140mph peak speeds on most flights, with ~100A current spikes when taking off with the prop stalled - really snarls until it gets a bit of airspeed. Makes a fantastic howl on those fast'n'low passes! Typically getting 6-7 minutes of flight time with careful throttle management.
I've got a flaperon mix running to help slow her down for landing, and I've fitted a set of BrainCube lights to help orientation when the wing is edge-on as I was losing track of the bank angle against the horizon on approach (full disclosure - I run BrainCube Aeromodels, the Sundowner is one of our demonstrators). Managed to rip out the undercarriage a couple of times before I got the hang of bringing her in.
I'm well pleased with the beast, the only thing faster round these parts are the jets!
Cheers,
Oliver
Darthwonga is offline Find More Posts by Darthwonga
Old Aug 21, 2012, 05:29 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Oliver, that sounds awesome. I have a very similar scorpion setup in my Sundowner (4025-10 515kv) and I think that 11x14 prop is calling my name If you get a chance, can you snap a pic with your lights on? I'd love to see the setup.
Brushless, some interesting reads here:
http://www.rcgroups.com/forums/showthread.php?t=1453525
http://forums.openpilot.org/topic/12...ech-batteries/
http://www.helifreak.com/showthread.php?t=429538&page=2
Josh
jgalexander is offline Find More Posts by jgalexander
Old Aug 21, 2012, 07:50 PM
olllian is offline
Find More Posts by olllian
olllian
olllian's Avatar
United States, AZ, Chandler
Joined Nov 2011
I have! When i was running 6s i used 4400mah!
olllian is offline Find More Posts by olllian
Old Aug 21, 2012, 08:06 PM
big ignore list
Joined Nov 2011
did you like them?
Old Aug 22, 2012, 12:33 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
well... what did you think?
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Aug 23, 2012, 09:26 AM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
brushless:
did you like them?
Why don't you do a "search"?
Old Aug 23, 2012, 10:08 AM
big ignore list
Joined Nov 2011
Kinda what im doin....
Old Aug 23, 2012, 05:38 PM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Not working very well huh?
By the time you get an answer here I will have tried the packs as I just ordered some today......I will let you know how they work.....or you could read at least 50 post on the packs on line if you do a "search".
Old Aug 23, 2012, 07:14 PM
big ignore list
Joined Nov 2011
not so sure you understand how some things work?
we are free to ask questions to anyone on these forums looking for possible answers!
I don't live in the make it quick life style...
don't need the answer two days ago... rather have honest answers from folks who have run these lipos to get there honest feelings
so ya, it's working just fine..
I'm not going to shell out some big bucks for 4s 5000mah packs if they are not worth it.. no reason to spend the cash and have them sit
Discussion Power system for Hangar 9 Sundowner 50 RB51 fan Power Systems 3 Apr 11, 2011 01:03 PM
Discussion hanger 9 sundowner 50 planefixer Fuel Plane Talk 57 Oct 26, 2010 07:59 AM
Cool Hanger 9 Sundowner 50 size cryhavoc38 Sport Planes 10 Feb 17, 2008 10:27 PM
Question Hangar 9 Sundowner 50? GJVO Fuel Plane Talk 0 Aug 23, 2007 02:38 PM
EDF 40/50 Brushless setups/results kd4gfy Electric Ducted Fan Jet Talk 0 Feb 20, 2005 03:11 PM
