Old May 13, 2012, 02:52 PM
umitv is offline
Find More Posts by umitv
umitv's Avatar
United States, IN, Indianapolis
Joined Sep 2011
I put TGS 12x12 prop on my sundowner yesterday and result was 133mph which is 8 miles slower than apc 12x12. I wish somebody makes 12x12 carbon fiber prop
umitv is offline Find More Posts by umitv
Old May 14, 2012, 12:28 PM
ohnow is offline
Find More Posts by ohnow
United States, GA, Conyers
Joined Sep 2011
SD50 Plans
Hi All;
This thread is awesome! I have a SD50 (#1) but the landing in the tree didn't work out so well I've fixed much worse and thankfully it's not terrible but I need to rebuild the first three bulkheads. Does anyone have plans where I could get a scan of those 3 pieces? Just hoping to save some time.
The SD50 (#2) has only landed on pavement so far, thank fully
I feel like an outsider on this thread since I'm running a Jett .60
ohnow is offline Find More Posts by ohnow
Old May 14, 2012, 01:22 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
You are in good company ohnow! Glad you found the thread
I wish I has some insight into where you might find the plans, you might have to contact Horizon or Hangar 9 directly to find that information...
Where are you flying these days? I fly my SD at Stone Mountain every so often, but also fly at Dunwoody Flying Club and the Pecan Patch. Lets get together sometime and burn some laps
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: New Drone Movie :D
Old May 14, 2012, 05:19 PM
ACKopter is offline
Find More Posts by ACKopter
Branford, Florida
Joined Jun 2010
Nah, I'm with you on the glow power. Couldnt manage funds for the Jett so I went with an OS 50 hyper, gets the job done, just not near as fast as I would like.
ACKopter is offline Find More Posts by ACKopter
Old May 14, 2012, 07:20 PM
ohnow is offline
Joined Sep 2011
Yeah I splurged on this plane. It was a tough choice to go glow or electric but that tuned pipe is hard to beat and I really wanted longer than a few minutes. I ended up squeezing a 24 oz tank in it! I bet it would fly even longer if I could stay out of the trees
Old May 14, 2012, 10:25 PM
olllian is offline
Find More Posts by olllian
olllian
olllian's Avatar
United States, AZ, Chandler
Joined Nov 2011
I noticed that to the apc 12x12 prop is faster and more pull then the TGS 12x12 prop. The apc sounds nice to
olllian is offline Find More Posts by olllian
Old May 30, 2012, 05:54 PM
Elec 1800 is offline
Find More Posts by Elec 1800
Flying 2 Fight Cancer
Elec 1800's Avatar
corona, ca
Joined Feb 2011
Hello fellas,
I don't have a SD but I have WM Nemesis that I am converting to electric. I will be using a Hyperion 4035-500kv which is good for WOT 130A @ about 4500watts. I plan of using a 12 or 13 size prop possibly on 10s. Have any of you used this esc. http://www.hobbyking.com/hobbyking/s...hless_ESC.html
I have used there non hv version on 6s and worked out perfect.
Elec 1800 is offline Find More Posts by Elec 1800
Old May 31, 2012, 10:47 AM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
That's the same as Hobbywing, which I've had great luck with.
Steve C is offline Find More Posts by Steve C
Old Jul 05, 2012, 12:38 AM
olllian is offline
olllian
olllian's Avatar
Joined Nov 2011
Hey guys i am running 10s with the castle series cable 2 to 1 my question is can i leav the one plug plugged I'n to the esc and then attach the 2 lipos??? The reason why is my esc cable is short and it's hard to get to thx
Old Jul 05, 2012, 09:24 AM
Steve C is offline
Steve C's Avatar
Joined Feb 2001
Yes, you can leave it plugged in.
Old Jul 05, 2012, 06:12 PM
olllian is offline
olllian
olllian's Avatar
Joined Nov 2011
aaa
got it
Old Jul 08, 2012, 11:12 AM
twarmbier is offline
Find More Posts by twarmbier
Joined Jul 2012
sd50 so slow
Hi. Great thread! I'm hoping u guys might be able to help me out. Here's the story ...i bought an sd 50 about a year ago and ive tryed every thing and still no speed. I'm missing something some where. looks to be in the 80 to 90 mph range, definitly not 100mph. Any ideas would be greatly appreciated. Thanks! The motor, props and spinner have been balanced there is no vibration at all. the current setup is
Motor eflight power 52 590kv
phenix ice 100 amp esc
battery 6cell Skylipo 40c
12x12 apc e prop
flying wieght 7 lbs
not sure how to post data log on here so here,s the readings
battery 25.0 avg 23.9
amps 89.9
watts 2009
rpm 11090
twarmbier is offline Find More Posts by twarmbier
Old Jul 08, 2012, 11:48 AM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
I'm sure others will chime in, but just for kicks I ran your setup thru the castle creations flight calculator. On a fully charged batt, it predicted 71A, 10975 rpm, 1538W, and 125mph pitch speed. Seems like the rpm is spot on, but your current and power numbers are a lot higher than theirs. Wonder where the difference comes from...?
Seems like you ought to be hitting the high 90's low 100's with that prop and rpm, unless it's stalling when you test it on the ground, and slowing down a bit when it gets up to speed and 'bites' (am I thinking about that correctly?).
J
jgalexander is offline Find More Posts by jgalexander
Last edited by jgalexander; Jul 08, 2012 at 11:50 AM. Reason: Damn you autocorrect!
Old Jul 08, 2012, 07:18 PM
Joined Jul 2012
Thanks for the calc. data logging was done in flight and those are the peak numbers. at the end of the pass amps dropped to 79 and watts drop to 1879 and rpm peaks at the end of the pass at 11090. I,ve tried a ton of prop configs and have noticed any prop smaller than a 12" is way slower. I'm starting to wonder if its an air frame issue, aero ptoblem or somthing out of line. just not sure where to start. the plane just looks like it,s struggling to get thru the air but it flies like a dream
Old Jul 08, 2012, 09:31 PM
umitv is offline
umitv's Avatar
Joined Sep 2011
12x12 apc e prop
flying wieght 7 lbs
amps 89.9
watts 2009
rpm 11090
if you want over 100 mph you should try 8s if your motor handle it. you are definitely on right prop
Discussion Power system for Hangar 9 Sundowner 50 RB51 fan Power Systems 3 Apr 11, 2011 01:03 PM
Discussion hanger 9 sundowner 50 planefixer Fuel Plane Talk 57 Oct 26, 2010 07:59 AM
Cool Hanger 9 Sundowner 50 size cryhavoc38 Sport Planes 10 Feb 17, 2008 10:27 PM
Question Hangar 9 Sundowner 50? GJVO Fuel Plane Talk 0 Aug 23, 2007 02:38 PM
EDF 40/50 Brushless setups/results kd4gfy Electric Ducted Fan Jet Talk 0 Feb 20, 2005 03:11 PM
