http://www.aeolianmotor.com/ If it is a 270kv, and on 10S, a 16x16 would be 90A peak and 130mph PS and 11lbs of Static thrust (more dynamic thrust available). 12S on 14x14 prop would be 10.5lbs thrust at 145mph PS at 75A |
Yeah....that's why I can't find any on the calculators either. Maybe a new motor??
This is the same...not where I got mine but it is available.... http://www.ebay.com/itm/Aeolian-2012...item1c261dcf79 |
I have the motor....but not the ESC. The box the motor came in said 370KV as well. It looks to be the same as the Monster Power series motors or EMP. It has the rough black can, but the bearing race is completely different than I'm used to seeing. It is VERY large. Of course the whole motor is huge....probably overkill
I do have a 14X14 pattern prop I will probably try on 8s, then 10s, and maybe 12s depending on the watt meter. Its just weird I can't find any info on it......
I typically fly with 6s 4000 and 6s 5000 batteries, with both I push them all the way forward about 1mm shy of the firewall.
Latest blog entry: Burned Retina Shorts
Adrian, How did the flight go? |
Well I had a chance to power up that motor today.....ummmmm don't think its gonna work for what I want. I had two props drilled up to that size shaft on hand....a 14X14 and a 18X10. On only 6s it was 85A on the 14X14 and just over 1000 watts, and over 100A (my watt meter only goes to 99.9A) and 2400watts on the 18X10. So....on 10 or 12s? maybe the 10X4 is correct afterall?? Anyway hope to take the black Sundowner out not this coming Sunday but the following. I haven't flown it yet and its killing me!
I'll see if I can get someone to take video while I'm out. Our field is almost dry again after the 4" of rain.
If you're using a plug in type amp meter, then your motor could very easily pull more amps when it's not plugged in. Years ago I found this out with my F5D stuff when I decided to also tach the prop while testing. It turned a lot more rpm without the Watt meter plugged in, so I bought a clamp amp meter and found the amp draw to be quit a bit more than the watt meter was telling me.
| Thread Tools | |
| Discussion Power system for Hangar 9 Sundowner 50 | RB51 fan | Power Systems | 3 | Apr 11, 2011 01:03 PM |
| Discussion hanger 9 sundowner 50 | planefixer | Fuel Plane Talk | 57 | Oct 26, 2010 07:59 AM |
| Cool Hanger 9 Sundowner 50 size | cryhavoc38 | Sport Planes | 10 | Feb 17, 2008 10:27 PM |
| Question Hangar 9 Sundowner 50? | GJVO | Fuel Plane Talk | 0 | Aug 23, 2007 02:38 PM |
| EDF 40/50 Brushless setups/results | kd4gfy | Electric Ducted Fan Jet Talk | 0 | Feb 20, 2005 03:11 PM |
