Hey all . Im new here . Got a sundowner to get the saito 115 it had on it . Now im thinking of electrifying it . I do mostly 3d so im not up on what to get for electronics . I thought running an 11" prop on a 40 size plane sounded crazy till I looked through some of these threads .
I have a motrolfly 3615 custom wound to 850kv on a 4.5lbs profile plane . I run it on 4s4000 with a 14x7apc pulling about 85amps . I was looking at where I got it for a sundowner motor (subsonicplanes). They have a 3615-1250 on a 8x6 that puts out 1800 watts on a 6s setup . Is that too small of a prop ? Im sure they could wind me one at a lower KV to use a bigger prop . I would like to get at least 6min of flight too . How many watts are you guys pulling to get 110+ mph ? Also how do your planes balance with all that battery weight ? I see some of you are running up to 10s . Not sure of the mah's but thats gota be the weight of a brick . http://www.subsonicplanes.com/Motrolfly_Motors.html |
I am going to try to log, gps, or radar a few flights this week, but I think I am only around 90-100mph (possibly a little faster) on Power 46, 6s 4000mAh, 10x10, CC80amp esc.
I will get it on the WattMeter before I take it up, and will post results and data from my setup. BTW~ Welcome to the thread, there is a ton of great info in here-especially if you are interested in fast electric setups. Be sure to post some pics of your new bird, it is one of the best looking on the market IMO |
Latest blog entry: Burned Retina Shorts
THe 8x6 is too small. It might get the plane moving, but it will fly scale or not be very efficient for the airframe. Try to keep it over 10". A guy used a 9" prop on a 60LX JETT engine and got to 130mph, but it got there SLOW and with a dive. http://www.jettengineering.com/sundowner.html Most people around here run between 11" and 12", seems to be the sweet spot for the 1500-4000W setups to get up to 140mph. The 12" prop gives instant thrust to punch out and get to speed without a dive. The battery weight is actually minor. The plane has a gentle stall speed and is fairly light wing loading. It flies nice and lands pretty slow even loaded with huge batteries ( I have run 3lbs of batteries in mine). Planebldr has a similar setup you might be looking for. He used a 580kv 50-55 Turnigy on 8S and a 11x7.5 (i believe) and got to 110mph. I think he was at about 1800W, you should look back about 6-12 months to double check that. If you want to do a 6S setup for 100mph, stay in the 600-700kv area. For 8S use a 500-600kv, and 400-500kv for 10S. Also consider staying above 40mm diameter can size for high power. You will probably see the amps in the 65-90A propped for speed for each level. If you need help choosing a motor, let us know.
![]() I just tried some 5s 5000mah 20c packs and even those will fit when I move the brace more forward... so 4s 5000mah 30c is what I will get.. I'm needing these for a test and tune this Sat. for my Race Boat, so I hope they come in by Thurs-Fri that's why I needed fast answers!!
Anyways, since turnigy's are just XYH rebranded, and XYH make the majority of cheap brushless motors these days, so it can be hard to find a replacement to those motors, especially since these are higher efficiency than most of the chinese competition. Suppo might be an option, you could try the A4120/6 620kv on 6S and 11x12 prop, might get you the 110mph you are looking for coming out of a dive, but the motor will be at it's limit, so limited WOT pulls would be advised. I am attaching a loose ecalc for this motor for an 11x12 apc. You could also go with the EFlite knockoff series of motors, which is the Tacon Big Foot or MonsterPower or Turnigy Easymatch G46 Series 670kv. They don't handle as much power as comparable motors though. I don't think you can hit your 110mph mark with one. If you want a cheap option with highest payoff, you should really reconsider using a Turnigy 50-55 or 42-60, but use loctit 410 to flow between the mags before first use: http://www.gobrushless.com/shop/inde...ref=LOCTITE410 Stuff works like a charm to keep the mags in and handles more heat than the mags themselves can handle. Or, save your cash and go Scorpion, Hyperion, etc. You cannot go wrong with these motors and have excellent resale value even if you fry it, which is pretty much impossible even if you are at the limit. You might find some really good prices in the RCG Classifieds if you keep your ear to the ground. eBay is not great, I have a saved search running for about a year now for Scorpions, and they don't show up much, mostly just the Heli versions over 800kv. Matt |
Latest blog entry: VIDEO: Real Helicopter Rescues Hangar 9...
While back on 15S, probably the 8000w Adrian mentioned needed. It was doing 180mph, but slicker airframe. I'm sure you could do it if you have a $1k laying around just for the power system, and don't think you will find the power system at Hobby King... hehe... |
| Thread Tools | |
| Discussion Power system for Hangar 9 Sundowner 50 | RB51 fan | Power Systems | 3 | Apr 11, 2011 01:03 PM |
| Discussion hanger 9 sundowner 50 | planefixer | Fuel Plane Talk | 57 | Oct 26, 2010 07:59 AM |
| Cool Hanger 9 Sundowner 50 size | cryhavoc38 | Sport Planes | 10 | Feb 17, 2008 10:27 PM |
| Question Hangar 9 Sundowner 50? | GJVO | Fuel Plane Talk | 0 | Aug 23, 2007 02:38 PM |
| EDF 40/50 Brushless setups/results | kd4gfy | Electric Ducted Fan Jet Talk | 0 | Feb 20, 2005 03:11 PM |
