Old Sep 27, 2011, 07:10 AM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
Okay thanks Adrian, i'll stick to the 25 C
ViperZ is offline Find More Posts by ViperZ
Old Sep 28, 2011, 07:50 PM
Hossinarizona is offline
Find More Posts by Hossinarizona
More Speed Indeed!
Hossinarizona's Avatar
USA, AZ, Tucson
Joined Nov 2007
Adrian,
Curious, have you tached your set up, I am just wondering how many RPM's you are getting on your 10s set up? Since this is an electric set up, I guess I can use my regular tach that I use for my nitro engines According to UPS my transmitter should be here Friday, if so all systems are go for a maiden this weekend
Hossinarizona is offline Find More Posts by Hossinarizona
Old Sep 28, 2011, 10:57 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
funny you ask; I tried to tach mine out at the field a week ago and I have concluded...
...my tach is broken. At least that is what I assume, it read only 120rpm
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: Please kill isis
Old Sep 29, 2011, 01:53 AM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
Originally Posted by Hossinarizona View Post
Adrian,
Hi Hoss no idea on the rpm i have a rpm sensor for my eagletree but i have never used it must be time to try it lol i would say around 14.500 rpm
there is no reason why it woldn't work but be careful getting your hand close to that prop
by the way my Sundowner ready to fly is bang on 3.7 kg
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Old Sep 30, 2011, 04:55 PM
More Speed Indeed!
USA, AZ, Tucson
Joined Nov 2007
Hey Adrian,
Thanks for the update, I will check my weight, I think I am right around 8 1/2 pounds or 3.8 kg. My radio according to UPS is due Saturday, so I might be able to maiden it Sunday, not sure
Have a good weekend,
Old Sep 30, 2011, 05:22 PM
Adrian_M is offline
Joined Dec 2010
Hey Adrian,
Cheers Hoss i hope all goes well
Old Oct 07, 2011, 03:41 AM
Adrian_M is offline
Joined Dec 2010
Hi Guys i got 3 more flights today after work with the new Sundowner first flight i did a few level passes recorded 233Kph (144mph) and did some dives with the two other lipos 0ne @ 259kph and the other @ 258Kph (160Mph)
The Scorpion S-4035-460 is a good performer just warm to the touch after each run (no spinner) so i guess it gets better cooling I'm running 5deg timing and 8kHz drive frequency
Hopefully tomorrow is a nice day and should get a few more runs i will up the timing and see what happens
I'm still having problems with the plane wanting to roll to the right at full throttle, still using the same prop i was using in my first Sundowner TSG 12 x 12E just cant work out why
Old Oct 07, 2011, 10:05 AM
mattyhawk is offline
Find More Posts by mattyhawk
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Very nice! (except for the issue with the rolling, looking at it from the back or the front?)
mattyhawk is offline Find More Posts by mattyhawk
Old Oct 07, 2011, 10:57 AM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
What a great data tool Adrian! Weird that on the left rolls, it can't believe it would be caused by a prop, but STD her things have happened.
I may need to add a Scorpian 4035 to my shopping list for future considerations
Old Oct 07, 2011, 12:16 PM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Viper, your avatar changed, I'm gonna miss the bipe pilot. Fortunately, it was replaced with a SD50
Old Oct 07, 2011, 12:57 PM
Adrian_M is offline
Joined Dec 2010
Hi Matty it rolls to the right going away from me so from the rear i will try another prop today but i can't see it being a prop problem
Old Oct 07, 2011, 02:52 PM
E-speed buff is offline
Find More Posts by E-speed buff
186mph Funjet Ultra
E-speed buff's Avatar
nieuw vennep, the netherlands
Joined Feb 2010
Hi Adrian
My flying buddy had the same problem! It was caused by the wing incidence being slightly off, Measure your wing incidence on both sides and correct any slight difference by filing the holes from the rear wing alignment slightly oval until both wings line up exactly!
Up to 140mph you can trim it out, but with higher speeds the wings start to twist because of the slightly deflected ailerons.
Grtz René
E-speed buff is offline Find More Posts by E-speed buff
Old Oct 07, 2011, 03:05 PM
USA, GA, Atlanta
Joined Nov 2008
Rene, that may just be the answer to his probs, I did not think about that. What would you suggest is the best tool on the market for measuring incidence?
Robarts got one, Hangar 9, and a bunch of others... have you found one you like more than others?
Old Oct 07, 2011, 04:34 PM
Adrian_M is offline
Joined Dec 2010
Originally Posted by E-speed buff View Post
Hi Adrian
Grtz René
Thanks for your imput what would be the best way to check ?
Old Oct 07, 2011, 05:29 PM
186mph Funjet Ultra
Joined Feb 2010
Hi Adrian
Take the wheels off, put it on a flat surface as level as possible and measure the height from the leading and trailing edge to the flat surface.
These measurments should be equal on both wings!
You can also use an incidence meter but I found that less accurate.
The higher the speed you want to fly the more precise you have to align it.
I also discovered that because of wing twist you lose roll controle above 150-160mph.
My M8 was flying with a Powercroco modified hyperion motor 3.5KW+ with an APC12x14 pattern prop on 6S, 170A!
Grtz René
Discussion Power system for Hangar 9 Sundowner 50 RB51 fan Power Systems 3 Apr 11, 2011 01:03 PM
Discussion hanger 9 sundowner 50 planefixer Fuel Plane Talk 57 Oct 26, 2010 07:59 AM
Cool Hanger 9 Sundowner 50 size cryhavoc38 Sport Planes 10 Feb 17, 2008 10:27 PM
Question Hangar 9 Sundowner 50? GJVO Fuel Plane Talk 0 Aug 23, 2007 02:38 PM
EDF 40/50 Brushless setups/results kd4gfy Electric Ducted Fan Jet Talk 0 Feb 20, 2005 03:11 PM
