Old Feb 11, 2008, 10:42 PM
GorillaBob is offline
Find More Posts by GorillaBob
Re-Kitting Expert :o
Bullhead City, Arizona
Joined Jan 2005
Video
CR28M Contra Rotating Brushless Motor
CR28M Contra Rotating Brushless Motor running on 1 40 amp ESC.
Added the 2nd video. CR28M Contra Rotating Brushless Motor running on Two 40 amp ESCs. Packs weren't charged and really couldn't keep Up. Motors had a couple problems I had to work out but seem to be doing great now.
GorillaBob is offline Find More Posts by GorillaBob
Old Feb 12, 2008, 05:12 AM
K9000wner is offline
Find More Posts by K9000wner
Thatsright I drankthe rum
K9000wner's Avatar
USA, MN, Robbinsdale
Joined May 2006
So, just so I can understand it better ..
you are running (two) 200watt or better bl motors off (one)
40 amp brushless esc?
cool...I was told for 2 bl motors I needed 2 esc's
K9000wner is offline Find More Posts by K9000wner
Old Feb 12, 2008, 08:17 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Nice noise, I can now get rid of all my 2 stroke glow engines!
Andy.
AndyOne is offline Find More Posts by AndyOne
Old Feb 12, 2008, 09:22 AM
Wingtips24 is offline
Find More Posts by Wingtips24
Mr. ExperiMENTAL
Joined Apr 2004
Pretty neat!
Tips
Wingtips24 is offline Find More Posts by Wingtips24
Old Feb 12, 2008, 11:47 AM
Lost in PA is offline
Find More Posts by Lost in PA
Crash n'glue!
Joined Jul 2006
ESC's
I'm looking forward to trying a twin... I notice Bob's stay in perfect sych, which they would have to do to run on one ESC. Seperate esc's give that whaw-whaw-whaw beat frequency. Beat frequency Hz = difference in Hz between two motors.
Roger
Lost in PA is offline Find More Posts by Lost in PA
Old Feb 12, 2008, 01:09 PM
Vitter is offline
Find More Posts by Vitter
Gas Monkey Vic
Vitter's Avatar
Snohomish, WA
Joined Jan 2005
Thant is cool! Now make the Convair XFY-1 Pogo and install your set up in it.
Vitter
Vitter is offline Find More Posts by Vitter
Old Feb 12, 2008, 01:27 PM
dayhead is offline
Find More Posts by dayhead
SlingWinger
San Bernardino, California, United States
The Bugatti racer used two V-8 engines driving counter-rotating co-axial mounted pros using a gear box. I think the gear box synchronized the prop speeds.
It would be a very interesting experience to see if having one of the props running faster than the other would be beneficial. Or even maybe one prop should be larger/smaller more/less pitch , etc.
Definitely a lot of food for thought here.
The Bugatti (beautiful plane!) used counter-rotating to reduce or eliminate torque/P-factor so as to allow for smaller tail surfaces to reduce drag.
It was designed to take the speed record back from the Germans, who had set it using a ME-209.
Then war came and the un-finished plane was hidden in a barn. It wasn't re-discovered until many years later.
So perhaps it would work well for a 3D plane for the same reasons Bugatti wanted to try it.
Anyway that's what I thought of upon seeing this.
dayhead is offline Find More Posts by dayhead
Old Feb 12, 2008, 01:39 PM
dayhead is offline
SlingWinger
My post above has some errors.
http://www.bugattiaircraft.com/kalempa.htm
Old Feb 12, 2008, 02:18 PM
ericdod is offline
Find More Posts by ericdod
ericdod's Avatar
United States, SC, Simpsonville
Joined Jun 2001
Is there any cost / performance advantage in doing this, or just the COOL factor?
ericdod is offline Find More Posts by ericdod
Old Feb 12, 2008, 02:38 PM
Joined Jan 2005
Well there is definit COOL factor here and the sound is great. Being able to run the two motors on 1 ESC helps bring the cost down but this motor isn't cheap. But then again, two motors aren't exactly cheap either I ran the motor for a few minutes on 2 ESC's and the sound is very differant on the 2 ESCs because they aren't synched.
Old Feb 12, 2008, 06:59 PM
cloud-9 is offline
Find More Posts by cloud-9
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
I'm totally confused. How can one motor spin in both directions?
Jim
EDIT: OK, so I guess you are running two motors. How do their shafts have the same centerline? Could you provide some photos or something?
Jim
cloud-9 is offline Find More Posts by cloud-9
Old Feb 13, 2008, 02:49 AM
Basingstoke Roy is offline
Find More Posts by Basingstoke Roy
http://roys-rc-tv.webs.com/
Basingstoke Roy's Avatar
United Kingdom, England, Basingstoke
Joined Oct 2005
Hi Jim
Hope these photo's and my video help.
The Contra Motor Project (1 min 39 sec)
The shaft of the back motor runs though the centre of the front motor, which is mounted on bearing.
Roy
Basingstoke Roy is offline Find More Posts by Basingstoke Roy
Old Feb 13, 2008, 03:08 AM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
Originally Posted by Basingstoke Roy
Hi Jim
http://uk.youtube.com/watch?v=md_99-WGSEA
Roy
Thanks, that helps a lot.
So, are the propellers actually blowing against each other? Can you get a prop made to work in the reverse of the usual direction?
Jim
Jim
Old Feb 13, 2008, 09:58 AM
Joined Jan 2005
Jim the rear prop is a pusher prop, it is designed to turn the opposite direction of a normal prop and still push air the same direction. So both props push air to the rear of the motors. With glow powered models, a pusher prop is used when mounting a glow power engine facing the rear, which makes it turn the wrong way with a normal propellor. And boy oh boy do those twin props push air!!!
Old Feb 13, 2008, 10:12 AM
ericdod is offline
ericdod's Avatar
Joined Jun 2001
This is very interesting - do you have any numbers?
Thrust, amp draw, etc...
Idea contra rotating prop brushless Eljimb0 Power Systems 1301 Jul 18, 2016 03:35 PM
Discussion contra-rotating motor from AEO Technology AEOTech Power Systems 130 Oct 27, 2015 04:00 PM
Pogo #2, Contra-Rotating Motor Ed Couch Scratchbuilt Indoor and Micro Models 8 Nov 30, 2004 11:05 AM
Direct drive rotating core sensorless brushless motor for 99.00$. AXI 2820/10 modest-master Electric Plane Talk 1 Jan 09, 2002 02:08 PM
tiny brushless motor and i mean tiny tiny Spin_Doctor Electric Plane Talk 1 Apr 30, 2001 04:07 PM
