Old Feb 11, 2008, 09:10 PM
G_Loc is offline
Find More Posts by G_Loc
Miami, Fl
Joined Jun 2005
So I've got lipos, but I don't know how to wire them
I just got 2 Micro T's (2S, 220mah) from CBP. They came with bare leads - red, black, and white.
What charger can I use with them? And what plugs will I need?
G_Loc is offline Find More Posts by G_Loc
Old Feb 12, 2008, 01:35 AM
supi7 is offline
Find More Posts by supi7
supi7's Avatar
CHICAGO
Joined Feb 2004
from their web page:
" Pack comes with three wires. Red and Black are used to wire a plug. The white wire is used as a way to check cell balance. Mapping: Red to White = Cell #1, White to Black = Cell #2. You should try to check balance every couple of charges to insure cells are in balance to each other. "
the wire plug you need is losi part # LOSB0860
one end will be for the battery the other for your LIPO charger, do not use old losi charger it will cause fire if you do.
the white wire is for checking balance as mentioned above, just put a piece od shrink tubbing over it and tape it to the side of the pack so its out of the way.
Best Wishes,
Dan
TrueRC
supi7 is offline Find More Posts by supi7
Old Feb 12, 2008, 02:47 AM
Bogomir67 is offline
Find More Posts by Bogomir67
I'll frame U!
Bogomir67's Avatar
Joined Aug 2006
Or better yet, either get a balancer plug for that, or a separate jack soldered to it.
With the separate jack you can charge the cells individually, preventing cell drift.
Bogomir67 is offline Find More Posts by Bogomir67
Old Feb 12, 2008, 07:48 AM
G_Loc is offline
Miami, Fl
Joined Jun 2005
Thank you!
I'm not quite sure how the whole balancer thing works. Is there a way to balance the cells or check the balance without a balancer?
Old Feb 12, 2008, 09:49 AM
I'll frame U!
Bogomir67's Avatar
Joined Aug 2006
The balancer compares the two cells (the Voltage) and then bypasses the chaging current of the cell that has a higher voltage. With more than 2 cells, it compares cell 1 with cell 2, 2 with 3, 3 with 4, and so on.
The only way to do that without a balancer is to charge them seperately, one after the other.
what you can do is this:
After flight, when you charge them, almost at the end of the charge, just measure the cells. If the voltage from one cell to the other is different mor than .05volts, charge them seperately (only a short while, for now they are almost full). If the difference is less, just continue to charge them normally.
Old Feb 12, 2008, 10:49 AM
G_Loc is offline
Miami, Fl
Joined Jun 2005
Ah makes sense. So in essence I would need 1 plug that is used to charge the battery and power my electronics and then a second plug thats strictly for the balancer? Or Do they make plugs that integrate the balancer cable? That Losi cable only has 2 wires
Old Feb 12, 2008, 11:57 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Integrate balance wires with the power cable? No.
Make plugs to connect balancing charger to balance connector on battery. Yes
If the charger only has 2 wires it is a non-balancing charger. You would have to charge each cell individually or buy a balance adaptor such as the Hyperion, which plugs into the charger and has balance leads that connect to the battery pack.
hoppy is offline Find More Posts by hoppy
Old Feb 12, 2008, 12:48 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
http://www.xushobby.com/servlet/Cate...s%3AConnectors
hall woo is offline Find More Posts by hall woo
Old Feb 12, 2008, 01:19 PM
G_Loc is offline
Miami, Fl
Joined Jun 2005
I found this diagram that puts things into perspective: http://www.3dhobbyshop.com/detail.aspx?ID=1620
I had ordered 2 pairs of JST connectors. So I'd just need to solder on JSTs onto the battery leads and then get a separate one to hook up the the balancer lead to the balancer.
Discussion Want to start night flying but don't know how ! Nigelp Night Flying 4 Jan 07, 2008 11:29 AM
Discussion Don't know how to wire Motrolfly DM2205! Balr14 Power Systems 4 Nov 22, 2007 07:57 AM
Discussion I Have A T-rex Hde But I Don't Know How To Set Up My Radio agapornis Mini Helis 1 Jan 08, 2006 03:51 PM
GLOW TO ELECTRIC (wish but don`t know) Grom Parkflyers 2 Mar 02, 2003 10:19 AM
I'm looking for this book...but I don't know the exact title. rc capo Life, The Universe, and Politics 2 Apr 27, 2001 08:22 PM
