Old Dec 30, 2002, 10:40 PM
Majortomski is online now
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
Turns on a motor????
Hi all. Dumb question no 17. I found a thread talking about eletrifying the sureflight Spitfire which said to use an "endo" motor. Went over to Hobby Lobby found the motor in different numbers of turns. Searched hi and low on this site and the web and couldn't find a simple answer (one not having a diffequ.in it) as to what do the different numbers of "turns" on a dc motor do for its performance. So what do the different numbers of "turns" on a dc motor do for its performance?
TIA
Tom S
Majortomski is online now Find More Posts by Majortomski
Old Dec 30, 2002, 10:49 PM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
lower number of turns=higher kv=hotter motor=lower cell count or higher gearing if geared.....
gregg f is offline Find More Posts by gregg f
Old Dec 31, 2002, 06:23 AM
Joined Aug 2000
Ok thanks for the try but I still don't get it
Tower list the following motors and specs.
Kyosho Terminal Velocity 11x2 Motor
Kyosho Atom Smasher 12x2 Motor
Kyosho Krypton Krystal 14x2 Motor
Kyosho EndoPlasma 16x2 Motor
Kyosho Atomic Force 17x2 Motor
For a given propeller say a 10 X6 and a 1800 6 cell pack attached to each of the above motors what performance differences will I see? What peak RPM and how much duration.
TIA
Tom, I haven't a Clue.
Old Dec 31, 2002, 07:30 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Here's the Kv for those motors; that is rpm/volt -- approx no-load (when Rm is ignored) rpm for each volt applied.
TV = 5930
AS = 5233
KK = 4399
EP = 3785
AF = 3531
TV is hottest, it has the lowest Rm (internal resistance) and highest Io (no-load current).
For same pack and prop, TV will have highest rpm and amps (most watts) with shortest duration.
Checkout www.motocalc.com a try the program free for 30 days.
jrb is offline Find More Posts by jrb
Old Dec 31, 2002, 09:44 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
For a start none of those motors will run a 10x6 prop without a gearbox.
But as everyone has said the lower the turns the more revs you will get for a given prop and battery voltage. But a lower turn motor will also take more current (amps) and so the duration will be less. If you try to use too big a prop the current will be so high it will burn the motor up.
BTW only the 16 turn Endoplasma is called an "Endo". The other motors are not "Endos" they are different Kyosho car motors. People use that specific motor a lot because it's a well built motor with nice balance between revs and current (using a fairly high ratio gearbox).
Steve
steve lewin is offline Find More Posts by steve lewin
Old Dec 31, 2002, 10:49 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Okay, you are aware that a motor is basically a chunk of metal (armature) with wire wound around it, spinning inside a magnet (field). The number of turns indicates how many times the wire is wound around the armature. A 16-turn motor has the wire wrapped around the armature 16 times. The second number indicates how many strands the wire has. A 16x2 motor has a 2-strand wire wrapped around the armature 16 times. It's also referred to as a "double wind" motor.
Assuming the same battery and propeller:
The more turns a motor has, the longer the wire is. The longer the wire, the more resistance it has. The more resistance it has, the less electricity can flow through it at a given voltage. The less the electicity flows, the slower the motor turns. In a nutshell, the more turns a motor has, the less current it draws with a given propeller, and the slower it turns.
You can make a motor draw more current by increasing the size of the propeller. So a motor with a high number of turns needs a larger propeller in order to draw the same amount of Amps as a motor with a low number of turns. In a nutshell, a motor with a high number of turns can spin a big prop slowly, while a motor with a low number of turns can spin a small prop quickly.
Another factor to consider is efficiency. The longer the wires are, the more energy is lost, because the natural resistance in wire converts electrical energy into heat. A motor with fewer turns of wire on the armature will be more efficient, provided you don't overload it. That's where gearboxes come into play. Gearboxes allow you the flexibility to run your motor in the conditions where it's most efficient, and where the propeller size, pitch and RPM match the flying qualities of the plane.
The lower the number of turns a motor has, the "hotter" it is. "Hot" in this case is similar to a "hot car" in that it goes really really fast, not a "hot car" as in stolen.
mkirsch1 is offline Find More Posts by mkirsch1
Old Dec 31, 2002, 06:50 PM
Joined Aug 2000
Thanks troops! That helps a bunch!!
A Safe and happy new year to all
Tom
Old Jan 01, 2003, 08:19 AM
Russell2 is offline
Find More Posts by Russell2
Deer Park, Tx, USA
Joined Feb 2001
Puzzled
I must admit continuing confusion on this same subject. What seems to be the case is low turns = high rpm/volt = needs gearing. For example, if I compare an Aveox to Jeti Phasor, former low turns / high rpm, so gear reduction is used, latter is low rpm, so direct-drive is used. What is very unclear is what choice to make? Presumably if I need 200 watts to fly a plane as determined by watts/sq in wing area or watts/ oz, or other "rules of thumb", prop I need and rpm needed will be determined by the type of plane ( low/hi wing loading ). Having established that, seems I could either gear a low turn motor or run hi turn motor direct. Given comments about electrical efficiency of low turn motor ( and losses in gear reduction unit ), seems geared low turn motor is the way to go ?
Only way I know to approach this now is to use electricalc and motocalc to perform the calculations. However, seems the e-zone experts have feel for these things that would be useful for us neophytes to understand.
Russell2 is offline Find More Posts by Russell2
Old Jan 01, 2003, 11:29 AM
Neil Stainton is offline
Find More Posts by Neil Stainton
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
A lot depends upon the motor and the model. Some motors (eg S400 4.8V) have such a high Kv (RPM/Volt) that you practically always have to gear them, so then the question comes down to what gear ratio.
However generally it depends if you want to go fast (direct drive) or climb fast (high ratio gearbox), or have reasobable performance for a long time (low Kv direct drive, or lower ratio gearbox).
The other consideration is that you ideally want to choose a motor whose max efficiency current is close to your model's average current. If you want to fly for 8 minutes from Hecel 1100 cells, you will actually get about 0.9Ah out of them = 54 amp minutes. So average current will be just 6.75A. Thus you want to choose a motor whose max efficiency is close 6.75A.
> Given comments about electrical efficiency of low turn motor ( and losses in gear reduction unit ), seems geared low turn motor is the way to go?
Not necessarily. In fact the comment that low turn motors are more efficient because they have a lower resistance is incorrect. So long as the high turn motor is packed with the same amount of copper as the low turn motor it will have the same efficiency, but at a lower current (and lower rpm). The reason why low turn motors aren't more efficient is because their no load current is higher.
Take for example S400 motors on 8 cells:
S400 4.8V
Kv = 4681 rpm/V
Rm = 0.10R
Io = 1.2A
Max efficiency = 72% at 7.5A
S400 6V
Kv = 3097 rpm/V
Rm = 0.269R
Io = 0.7A
Max efficiency = 72% at 5.0A
S400 7.2V
Kv = 2332 rpm/V
Rm = 0.338R
Io = 0.6A
Max efficiency = 72% at 3.9A
(I doctored the figures slightly to illustrate the point and match my experience, you may get slightly different numbers if you try it in MotoCalc.)
Thus from the above example you could choose either a 4.8V motor or a 6V motor as either of their max efficiencyes is close to 6.75A. However you would have to gear the 4.8V motor to be able to use a reasonably sized prop, whereas the 6V motor could be run direct drive. Note if I had used 0.5Ah cells in the example the average current would have been reduced, which is why 6V and 7.2V motors have been more popular in the past.
Hope this makes some sense.
Neil.
Neil Stainton is offline Find More Posts by Neil Stainton
Old Jan 01, 2003, 01:40 PM
Russell2 is offline
Deer Park, Tx, USA
Joined Feb 2001
Ok, given numbers mentioned, I can run a 4.8 v at 7.5 amps ( geared ) getting ~ 40 WATTS TO PROP ( 7.5*9.6*50%) OR run a 6 volt at 5 amps direct, getting 75% of 40 or 30 watts to prop. As uninitiated, I would conclude that the former would always be preferred. So why am I usung a 6 v Graupner 3321 instead of the 4.8 volt through a gearbox for my Sport 400? I actually draw (and motocalc predicts) more like 9 amps on 8 cells with a 5x4.
Old Jan 01, 2003, 02:02 PM
Joined Feb 2001
You don't prop for the max efficiency current, you prop for the motor run you want, and the max current the motor can take - about 12A for a Speed 400.
Lets say you are doing 4 min flights and getting .5ah out of 600AE cells, the actual average current is 7.5A. In which case the 4.8V motor would give you its best 72% efficiency, though you would lose up to 10% through the gearbox, and the model would weigh 7% more. OTOH the 6V motor's efficiency is down to 67% at 7.5A, and you would have the simplicity, lightweight, and low cost of a direct drive setup - so at these currents it is a wash. If in fact you were averaging 10A in flight a geared 4.8V motor would be better.
Neil.
Flip switch off-sometimes motor turns on Kenny Sharp High Performance 76 Sep 30, 2006 05:28 PM
Motor Turns On full when i push My Right TX stick to the Left kushal_22 Power Systems 6 Jul 21, 2003 09:21 AM
How many turns on a speed 400 motor stealthy Power Systems 5 Dec 14, 2001 11:34 PM
Why set downthrust on a motor? And can you have too much? rtideas Power Systems 12 Jul 05, 2001 02:54 PM
Oil for shaft on motor after break in ericstac Power Systems 3 Jun 28, 2001 01:58 PM
