This thread is privately moderated by my c210, who may elect to delete unwanted replies.
Old Nov 17, 2009, 12:41 PM
Hewey19 is offline
Find More Posts by Hewey19
Hewey19's Avatar
USA, MI, Lansing
Joined Aug 2009
I never realized that servo horns aligned differently depending on which arm you have facing out. This is why Futaba's horns have a little number on each arm. I always just slapped a horn on there and then adjusted it with the sub trim on my radio. No need to do that anymore.
Hewey19 is offline Find More Posts by Hewey19
Old Dec 23, 2009, 01:39 PM
lightninjim is offline
Find More Posts by lightninjim
absorbing info - albeit slowly
scotland
Joined Apr 2007
Pins: Use upholsterer's pins, They're around 40mm long (1 1/2") and have a tee shaped head. They don't kill your fingers when pinning a lot of pieces. They are also very easy to grab with pliers for the next bit.
If you're pinning wood together (skinning for example) and trying to remove the pins after the glue has set; Give them a twist first, this will break the glue bonded to the pin before you pull them out. (saving the hard work you've just done)
Actually it's a good habit to twist any pin before you remove it !
lightninjim is offline Find More Posts by lightninjim
Old Jan 05, 2010, 12:01 PM
ARillos is offline
Find More Posts by ARillos
Scratch Builder
ARillos's Avatar
United States, KS, Overland Park
Joined Aug 2009
Just do not buy an ARF! My 2c.
ARillos is offline Find More Posts by ARillos
Old Feb 20, 2010, 07:41 PM
warbirdvic is offline
Find More Posts by warbirdvic
REDONDO BEACH, CALIFORNIA
Joined Jun 2006
Hello everyboby Victor here, I've been in the hobby for few years , but I just started to scratch build. does anybody knows couple of airfoils for sport planes? Either symetrical or semisymetrical. I have compufoil but they have almost only sailplanes. Any information is useful.
Thank you
Victor
warbirdvic is offline Find More Posts by warbirdvic
Old Dec 02, 2010, 01:04 AM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
helpful stuff
hemostats are great for reaching into the fuse for dropped parts
xacto saw blades for the hobby knife
unwaxed dental floss for wrapping push rod ends etc
spray polyurathane clear for fuel pruffing firewalls , inside of the fuse bottom
save the clear backing from Monokote its thicker/ better that Saran wrap
dollar store for clamps
learn to solder
paint stir sticks with sandpaper glued on are GREAT for shaping
old coro plast signs ( the ones to small for building planes) make good boxes
salvaged foam from the electonics store (softer = better) for padding the Rx, battery and for holding the plane off the table while covering or repairing to stop scratches.
build with a friend(s)
ozmo01 is offline Find More Posts by ozmo01
Old Apr 16, 2011, 03:23 PM
rolex24hrs is offline
Find More Posts by rolex24hrs
Canada, MB, Winnipeg
Joined Apr 2011
Drywall
Built my first scale kit on my dining room table, with a 1/2 inch sheet of drywall on top. T pins go into it very well, and hold tight!
rolex24hrs is offline Find More Posts by rolex24hrs
Old Apr 18, 2011, 01:34 PM
n00b-E is offline
Find More Posts by n00b-E
n00b-E's Avatar
Joined Sep 2007
Well sure, but now you have to fill all those holes and repaint!
n00b-E is offline Find More Posts by n00b-E
Old Apr 18, 2011, 03:57 PM
Xanadu is offline
Find More Posts by Xanadu
Xanadu's Avatar
Joined Nov 2006
And those numbers mean or correspond to?
Xanadu is offline Find More Posts by Xanadu
Old Apr 20, 2011, 03:00 AM
garciaj is offline
Find More Posts by garciaj
United States, KS, McPherson
Joined Apr 2011
Just take all your horns off, mount your servo's, hook them up to the radio and let the radio center them and then put the horns on to line up with your control surface, that's the way i do it.
garciaj is offline Find More Posts by garciaj
Old Apr 20, 2011, 07:18 AM
Xanadu is offline
Xanadu's Avatar
Joined Nov 2006
That is the way I have always done it. There is a better way?
Old Apr 22, 2011, 10:43 AM
garciaj is offline
Joined Apr 2011
Its the only way that seems to make sense to me idk.
Old Nov 30, 2011, 10:47 AM
jbswear is offline
Find More Posts by jbswear
Plane crasher
jbswear's Avatar
United States, MD, Bowie
Joined Nov 2011
Originally Posted by jim_ag3y View Post
Don't push pins through balsa sticks such as used in vertical and horizontal stabs . Instead, lay the parts on the plans (covered as indicated above ) and pin OVER the sticks in a criss-cross pattern. You use a few more pins, but you won't split the sticks!
If you are stick building, lay out both sides of the chassis at the same time, one over the other. This will result in both sides being as close to identical as possible.
These are old tricks, but if you are re-constructing vintage planes, or working with any kind of stick construction, they are good to remember!
Cheers, Jim
To do this, do you lay on and glue up the first one, then lay plastic over that and the lay on your second half?
And to add to the info:
www.woodenwonderstx.com sells CA and accelerator pretty cheaply. I turn pens on a lathe and use CA for my finish, so I go through a lot of it.
jbswear is offline Find More Posts by jbswear
Old Dec 01, 2011, 03:14 AM
ozmo01 is offline
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Yep, put sumpin' non stick between the two sides. Saran wrap, waxed paper etc.
Old Dec 03, 2011, 08:24 AM
OFS835 is offline
Find More Posts by OFS835
OFS835's Avatar
Australia, WA, Bullsbrook
Joined Nov 2010
The following web site has a large amount of information and tips for the builder.
http://www.airfieldmodels.com/inform...d/fixtures.htm
Transparent book covering film is also very good for covering plans, and it can be re used!
When building frames, such as fuselage sides etc, make sure to build square. Spend a little money on a good engineers square, a 6 inch one is very useful, both on the hobby bench and also in the workshop. A smaller 3 inch square will handle all the wing ribs and most of the fuselage frames, and is not too bulky to fit in between the ribs and frames on the larger models.
Yes, sharp knives and tools are a must!
Sharp tools can be stored in a block of EPS foam for safety.
OFS835 is offline Find More Posts by OFS835
Old Jan 24, 2012, 03:35 PM
sweatybetty is offline
Find More Posts by sweatybetty
sweatybetty's Avatar
United States, OR, Roseburg
Joined Jan 2012
something i learned today while trying to sheet a very sharp radius with 3/32 balsa.
i wet the wrong side ok so off to the wood stove to dry the balsa and wet the right side. heat to a wet piece of balsa makes it curve even more dried it out, wet down the right side, and back to the wood stove. perfect fit.
string line levels work great for leveling the stab to the wing.
sweatybetty is offline Find More Posts by sweatybetty
DAW Extra - Building Tips? Sal C Foamies (Kits) 27 Sep 26, 2001 09:08 PM
Simple 400 Building Tips? 99esq High Performance 4 Sep 10, 2001 07:07 PM
Kavan Parnetavia building tips cruzomatic Foamies (Kits) 28 Sep 09, 2001 09:36 PM
Wattage F-22 Building Tips / Pictures rcfanatic Foamies (Kits) 9 Sep 08, 2001 02:25 PM
IFO Mark3: Any last minute building tips ? volt flyer Parkflyers 13 Jun 21, 2001 03:33 PM
