This thread is privately moderated by my c210, who may elect to delete unwanted replies.
Old Feb 11, 2009, 09:11 PM
evan.flatt is offline
Find More Posts by evan.flatt
evan.flatt
evan.flatt's Avatar
United States, IN, West Lafayette
Joined Apr 2008
Will it work
What are your thoughts on this plan?
evan.flatt is offline Find More Posts by evan.flatt
Old Mar 09, 2009, 05:32 PM
scratchbildr is offline
Find More Posts by scratchbildr
Scratch fly,Scratch crash
Roswell, N.M.
Joined Nov 2003
A. Use a metal (aluminum) yardstick for cutting/ drawing long straight lines.
B. Popsicle sticks for mixing epoxy. Craft stores carry them in larger packs.
C. Condiment cups for mixing epoxy/ small parts tray. commercial service stores carry them. 200 cups for $3.
D. Veterenary plastic syringes make great epoxy applicators. I get the small ones with the curved tip for applying in small areas.
E. A Dremel too will pay for itself many times over. Cutting, sanding, drilling, etc.
scratchbildr is offline Find More Posts by scratchbildr
Old Mar 09, 2009, 05:40 PM
Dad_Roman is offline
Find More Posts by Dad_Roman
Twistaholic AMA 134406
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Can of clear spray paint from Wally World.
99 cents....perfect for balancing props
Dad_Roman is offline Find More Posts by Dad_Roman
Old May 08, 2009, 05:17 AM
Drusky is offline
Find More Posts by Drusky
just a rumour
Drusky's Avatar
South Africa, EC, Port Elizabeth
Joined Jun 2006
Which paint would you suggest for protecting the wood work around the engine from fuel damage on a gass model.
Please don't name a brand but rather a chemical name ie Polyurethane.
Andrew
Drusky is offline Find More Posts by Drusky
Old May 08, 2009, 09:46 AM
Rodney is online now
Find More Posts by Rodney
Florida
Joined Aug 2004
Epoxy, epoxy, epoxy.
Rodney is online now Find More Posts by Rodney
Old May 08, 2009, 12:40 PM
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Yep...the old standard is some epoxy maybe thinned a little with alcohol. The new standard is WBPU. Lots of folks using it for glassing and fuel proofing etc...
Water Based Poly Urethane....whatever brand you can find locally. Minwax is accepted as being quickly and readily available at your local Lowes or HomeDepot.
Old May 11, 2009, 09:15 PM
ScaleNVYflyr is offline
Find More Posts by ScaleNVYflyr
Fly it like a rental!
ScaleNVYflyr's Avatar
San Diego, CA
Joined Feb 2009
Wood glue
besides the speed factor and possible weight are there any down sides to using regular exterior wood glue.
I want to use it mostly for joining ply/balsa.. gluing sheeting to horizontal / vertical stabs?
Thanks...
ScaleNVYflyr is offline Find More Posts by ScaleNVYflyr
Old May 11, 2009, 09:36 PM
Arceenut is offline
Find More Posts by Arceenut
Arceenut's Avatar
Canada, BC, Langley
Joined Nov 2007
I use mostly the yellow aliphatic glues (Elmers etc) and only use epoxy and cyanos where their characteristics are required.
Arceenut is offline Find More Posts by Arceenut
Old May 11, 2009, 09:57 PM
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Thanks...
No, theres not.
Lots of guy swear by it and its perfect for model plane applications.
Our good friend ZOR even endorses "filleting" all joints with it for a significant increase in strength.
Old May 11, 2009, 10:11 PM
San Diego, CA
Joined Feb 2009
sweet thanks.. this is my first build, and I'm learning the ropes, being fairlly crafty I figuared I could but didn't want to make a mistake by not thinking RC related..
Old May 12, 2009, 02:33 AM
Drusky is offline
just a rumour
Drusky's Avatar
Joined Jun 2006
Thanks for the input:
Epoxy epoxy epoxy.
Epoxy thinned with ethanol/methanol.
Water Based Polyurethane.
Wood glue.
That is quite a wide range of products is there any type of paint I should avoid?
Old May 12, 2009, 02:49 PM
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Epoxy epoxy epoxy.
Wood glue.
ethanol/methanol.....maybe this is what you guys call alcohol "down there" but here its a little pricey, although a few drops to thin your epoxy wouldnt matter I guess. Also not something we would have just layin around, but for all I know you mix your own fuel and have it there on hand. Normally use rubbing alcohol from the drug store or denatured alcohol form the paint store. Now that I think about it, Ill bet denatured alcohol is more than methanol
Paints are going to be subjected to the outdoor elements and the main one to worry about is Nitromethane. If you fly nitro planes then you will need to coat the paints you use with a clear that is nitro resistant. So the paint you use is not so important as is its compatibility to the nitro resistant clear you will have to use.
I dont know so much about "painting" but most guys go with an automotive laquer for the final protective coat.
Navy....glad to help. Im more than happy to share my feeble knowledge with ya Anything else, ask away!
Old Jun 30, 2009, 05:07 PM
glenn297 is offline
Find More Posts by glenn297
Joined May 2009
Originally Posted by my c210
(1) ALWAYS lay wax paper on your plans before you even open the glue bottle.
(2) ALWAYS have a bottle of acetone on standby.(dissolves CA glue)
(3) ALWAYS work in a well ventilated area.
(4) NEVER rush and build one part at a time.
(5) ALWAYS quit when you get tired.(If not then you tend to leave out parts).
(6) Don't sweat the covering part. it is not as hard as you might think.
P.S. Mr. Moderator could you please make this thread sticky so new guys know what to do and what not to do?
good tips thanks looking to do first build this winter anybody tell me whats a good first build
glenn297
glenn297 is offline Find More Posts by glenn297
Old Jun 30, 2009, 05:49 PM
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
glenn297
Welcome.
By this winter you will want to start thinking about something along the lines of a Sig 4 Star.
Old Nov 16, 2009, 09:50 AM
andrewboktor is offline
Find More Posts by andrewboktor
andrewboktor's Avatar
Canada, BC, Vancouver
Joined Nov 2009
Plans for a trainer needed
Does anybody have plans for a good trainer? something similar to the Nexstar or so?? please post them here or pm me.
andrewboktor is offline Find More Posts by andrewboktor
DAW Extra - Building Tips? Sal C Foamies (Kits) 27 Sep 26, 2001 09:08 PM
Simple 400 Building Tips? 99esq High Performance 4 Sep 10, 2001 07:07 PM
Kavan Parnetavia building tips cruzomatic Foamies (Kits) 28 Sep 09, 2001 09:36 PM
Wattage F-22 Building Tips / Pictures rcfanatic Foamies (Kits) 9 Sep 08, 2001 02:25 PM
IFO Mark3: Any last minute building tips ? volt flyer Parkflyers 13 Jun 21, 2001 03:33 PM
