This thread is privately moderated by my c210, who may elect to delete unwanted replies.
Old May 25, 2008, 02:43 PM
Brother2 is offline
Find More Posts by Brother2
from another mother
Brother2's Avatar
Plumas Lake, CA
Joined Nov 2007
Don't be cheap. Replace your razor blades and sandpaper often. It will save you some frustration, and it will make your model better.
Brother2 is offline Find More Posts by Brother2
Old Jun 10, 2008, 04:19 AM
Baba Booey is offline
Find More Posts by Baba Booey
Yes it's a taildragger...
Baba Booey's Avatar
Canada
Joined May 2008
To keep sawdust, sanding dust ETC from getting into your fuel lines during construction, if you have a few spare fuel filters open them up and fill with paper towel. Instant dust plugs!
Note that mine are master airscrew and pull apart some may not
Baba Booey is offline Find More Posts by Baba Booey
Old Jun 10, 2008, 09:14 AM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
Or get fuel line plugs...
Or just use short pieces of solid brass rod...
Or... use whatever else seems to work to plug the fuel lines
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Jul 14, 2008, 12:14 PM
turnbub is offline
Find More Posts by turnbub
S. California
Joined Jun 2008
Plan Protection
See also Great Planes Building accessories, Plan Protector Roll $*.99 (+)
at Tower Hobbies.
http://www3.towerhobbies.com/cgi-bin...&I=LXK313&P=SM
For a building board, I bought a 2' X 4' sheet of plywood, and stuck a same size ceiling tile on it, soft side up - can stick pins in it, will absorb spills, etc.
Very cheap @ Loews or Home Depot........
Wish I could say I've built a bunch, but just getting re-started.
turnbub is offline Find More Posts by turnbub
Old Jul 31, 2008, 10:54 PM
Arceenut is offline
Find More Posts by Arceenut
Arceenut's Avatar
Canada, BC, Langley
Joined Nov 2007
Robart hinge points make excellent fuel ine plugs. Used intact they will plug both the fuel line and the pressure line and keep them together at the same time.
Arceenut is offline Find More Posts by Arceenut
Old Aug 16, 2008, 01:15 PM
jim_ag3y is offline
Find More Posts by jim_ag3y
Hagerstown, MD
Don't push pins through balsa sticks such as used in vertical and horizontal stabs . Instead, lay the parts on the plans (covered as indicated above ) and pin OVER the sticks in a criss-cross pattern. You use a few more pins, but you won't split the sticks!
If you are stick building, lay out both sides of the chassis at the same time, one over the other. This will result in both sides being as close to identical as possible.
These are old tricks, but if you are re-constructing vintage planes, or working with any kind of stick construction, they are good to remember!
Cheers, Jim
jim_ag3y is offline Find More Posts by jim_ag3y
Old Aug 25, 2008, 07:04 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Always use a sanding block whenever possible. Use your fingers to run over the surface to find imperfections, or high spots. Think of sculpting.
Have everything at hand so you'll be more apt to use the correct tool (clamps, pins, various knife blades) and not make do with what you have which often leads to less than desireable results.
Covering won't hide imperfections in the final surface... think of painting a wall.
mv
Thermalin is offline Find More Posts by Thermalin
Old Aug 27, 2008, 11:30 PM
turnbub is offline
S. California
Joined Jun 2008
Landing gear hold-downs
Trying to fix a mildly crashed trainer - the nylon landing gear hold-downs had all ripped (GOOD THING - cheap and easier than if the screws had ripped out).
Local hobby shop did not have replacements that would fit, so I bought a cheap plastic container, of good quality ($.85), and cut my own. They worked ...... if only I could get it flying again......
Old Sep 07, 2008, 12:14 AM
littlewing78 is offline
Find More Posts by littlewing78
I meant to do that
littlewing78's Avatar
Eagle Mountain, Utah
Joined Jul 2004
Use wet wipes when building your ARF. They are the best thing for wiping off excess epoxy. Your plane will come out much cleaner looking.
littlewing78 is offline Find More Posts by littlewing78
Old Sep 07, 2008, 10:35 AM
Xanadu is offline
Find More Posts by Xanadu
Xanadu's Avatar
Canada, MB, Winnipeg
Joined Nov 2006
Buy a few pieces of self sticking sandpaper used on power tools. Various grits if you want.
Stick them right to the top of your bench, or onto a board, and voila', you have a nice flat large sanding surface
Xanadu is offline Find More Posts by Xanadu
Old Oct 09, 2008, 05:41 PM
Dad_Roman is offline
Find More Posts by Dad_Roman
Twistaholic AMA 134406
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
I could wax poetic for hours but.....
Here is 122 Tips Sorry...these appear to be gone. The other two links are still working.
Here is a few
Here is a Library with a Wealth of Information
Dad_Roman is offline Find More Posts by Dad_Roman
Old Oct 29, 2008, 05:31 PM
dweeb7944 is offline
Find More Posts by dweeb7944
Dweebster
dweeb7944's Avatar
United States, MA, Charlton
Joined Sep 2008
For a building surface, I use Homosote. You can find it at any Homedepot or Lowes. I took it from Model Railroad building. It's pretty tough to take a beating. You can cut on it, yet are still able to stick pins into to hold plans or parts or whatever.
dweeb7944 is offline Find More Posts by dweeb7944
Old Nov 13, 2008, 09:44 AM
n00b-E is offline
Find More Posts by n00b-E
n00b-E's Avatar
Joined Sep 2007
at Tower Hobbies.
Ditto on the ceiling tile for a building board. I've never built a model without one, they're great!
n00b-E is offline Find More Posts by n00b-E
Old Nov 24, 2008, 08:36 AM
SKromfols is offline
Find More Posts by SKromfols
Stankromfols
Valley Springs, CA
Joined Jun 2006
In addition to the other tools, I've found that someitmes a drywall knife works well. It uses razor blades, so it makes sharp smooth cuts, but it's stronger than an exacto knife.
SKromfols is offline Find More Posts by SKromfols
Old Jan 26, 2009, 11:16 AM
wzak29 is offline
Find More Posts by wzak29
wzak29
ny
Joined Jan 2009
Waiting for delivery of my first plane, PT-40 from Tower Hobbies
the great thing about them is that I was abel to download
the manual so I could study it before I receive the plane.
(read it three times)
wzak29 is offline Find More Posts by wzak29
DAW Extra - Building Tips? Sal C Foamies (Kits) 27 Sep 26, 2001 09:08 PM
Simple 400 Building Tips? 99esq High Performance 4 Sep 10, 2001 07:07 PM
Kavan Parnetavia building tips cruzomatic Foamies (Kits) 28 Sep 09, 2001 09:36 PM
Wattage F-22 Building Tips / Pictures rcfanatic Foamies (Kits) 9 Sep 08, 2001 02:25 PM
IFO Mark3: Any last minute building tips ? volt flyer Parkflyers 13 Jun 21, 2001 03:33 PM
