This thread is privately moderated by my c210, who may elect to delete unwanted replies.
Old Feb 09, 2008, 11:03 AM
Resident giant scale guru
my c210's Avatar
Picayune, MS
Joined Oct 2007
Handy building tips
(1) ALWAYS lay wax paper on your plans before you even open the glue bottle.
(2) ALWAYS have a bottle of acetone on standby.(dissolves CA glue)
(3) ALWAYS work in a well ventilated area.
(4) NEVER rush and build one part at a time.
(5) ALWAYS quit when you get tired.(If not then you tend to leave out parts).
(6) Don't sweat the covering part. it is not as hard as you might think.
P.S. Mr. Moderator could you please make this thread sticky so new guys know what to do and what not to do?
my c210 is offline Find More Posts by my c210
Old Feb 09, 2008, 11:05 AM
your gonna snap the wings
rctoyflyer's Avatar
covina CA
Joined Aug 2007
cool thanks for the tips.im gonna be building my first kit here in alittle while.
(sig smith miniplane)i actually found some of this helpful.
thanks, matt
rctoyflyer is offline Find More Posts by rctoyflyer
Old Feb 09, 2008, 01:01 PM
my c210's Avatar
Picayune, MS
Joined Oct 2007
thanx, i try
Old Feb 09, 2008, 03:17 PM
my c210's Avatar
Picayune, MS
Joined Oct 2007
(7) you also need to make sure you have an x-acto knife and some kicker for your ca when you dont want to wait.
Old Feb 09, 2008, 08:22 PM
Joined Jun 2006
(8) Always use sharp blades.
Flying freak is offline Find More Posts by Flying freak
Old Feb 09, 2008, 08:26 PM
Progress not Perfection
wilscor41's Avatar
Palmdale, Ca.
Joined Dec 2005
(9) Always us a flat level building surface.
wilscor41 is offline Find More Posts by wilscor41
Old Feb 10, 2008, 08:20 AM
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
10) Always measure twice, cut once!
Viper Pilot is offline Find More Posts by Viper Pilot
Old Feb 10, 2008, 09:39 AM
building board
what is the best material for a building board? I have been using pine ready made panels from home depot. they are not bad, I use clamps to hold them true to the work bench. any idea's.
bugerdup is offline Find More Posts by bugerdup
Old Feb 10, 2008, 09:54 AM
Deletedfor proving Nauga wrong
Joined Mar 2005
not wax paper... Saran wrap or other clear plastic wrap. Wax paper was used in the 1930's/40's... But its not as easy to see through as plastic wrap. Also... I have had glue stick to the waxed paper...but never to plastic wrap.
Hobby Lobby craft stores carry low cost CA debonder. Appx 30% less than I have found it anywhere else.
Yellow carpenters glue is great...
Cheap
Easy to use
gives a little time for positioning parts
strong
light (if you use it right) I often have my planes come out UNDER list minimum flying weight.
$5 worth of yellow glue will build a FLEET of planes... $5 worth of CA builds ONE plane.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Feb 10, 2008, 07:15 PM
my c210's Avatar
Picayune, MS
Joined Oct 2007
thanx for the tips i left out.
Old Feb 11, 2008, 07:59 AM
Joined Jun 2006
ONE plane.
Check at home depot or similar and look for acetone. you should be able to find it very cheap and try it out chance are you wont even be able to tell the difference , Its to the point where the lhs admits its probably just repackaged.
Steven
Old Feb 13, 2008, 08:01 PM
my c210's Avatar
Picayune, MS
Joined Oct 2007
yeah, acetone is much cheaper.
Old Feb 13, 2008, 09:58 PM
I'm an English Meatball
Hillsboro,OR USA
Joined Mar 2007
I use the large blue 2'X8' insulation panels that are about 2" thick. They are very flat and pins push into it easily. Its cheap and you can replace it easily if it gets damaged (CA will eat it).
Speaking of CA........Thin CA will go ANYWHERE! It will spray if you open it near your face. It will drip everywhere. It will glue your fingers to whatever you are holding. And to make it really fun.....you will get some on your fingers without realizing it....then you will spay some kicker on it.......It will BURN! I've gotten some pretty good blisters from it. Just be careful and dont say we didnt warn ya!
Chris Elliott
OMAS
castlebravo is offline Find More Posts by castlebravo
Old Feb 16, 2008, 06:47 AM
my c210's Avatar
Picayune, MS
Joined Oct 2007
that too
Old Feb 16, 2008, 08:58 AM
Joined Mar 2005
Applying covering... is mostly just acting like you know what you are doing...
Cut pieces somewhat oversize... tack down a corner... pull tight to opposed corner and tack then stqrt pulling qnd tacking around the edges.
Generally you can shrink out all the wrinkles with a heat gun so don't sweat it too much.
For compound curves, apply heat and pull hard. The coverings stretch very well. I have seen a wheel pant covered in ONE PIECE. (thats kind of like covering an egg)
A good straight edge and a sharp knife and you can cut your own trim stripes. Generally stripes under 1/2 inch wide are annoying to apply and they peel if not stuck down VERY WELL.
Fuel power planes need the seams sealed better than electric models. The fuel will lift a marginally sealed seam that would never cause a problem for an electric model.
All overlaps should be such that airflow won't be trying to blow under the edge. Work from the bottom rear of the model to the top front.
I have yet to actually plan a color scheme out before applying it... I take scraps.. lay them in place.. if it looks good I iron it down.
My latest covering project (rebuild of a smashed model... ) ended up red white and blue with 11 alternating red-white horizontal stripes on the rudder and a big white star on the blue fin. It looks better now than when the ARF was new. (pics when I figure out why my camera's mem card won't transfer images to the computer... or when I find the cable to connect the camera instead of using the card reader)
DAW Extra - Building Tips? Sal C Foamies (Kits) 27 Sep 26, 2001 09:08 PM
Simple 400 Building Tips? 99esq High Performance 4 Sep 10, 2001 07:07 PM
Kavan Parnetavia building tips cruzomatic Foamies (Kits) 28 Sep 09, 2001 09:36 PM
Wattage F-22 Building Tips / Pictures rcfanatic Foamies (Kits) 9 Sep 08, 2001 02:25 PM
IFO Mark3: Any last minute building tips ? volt flyer Parkflyers 13 Jun 21, 2001 03:33 PM
