Scratch built Sterling 63'
Hi all I have some pictures of my scratchbuilt Sterling 63' in progress. I started this project in September of last year and this is the progress so far. As the project moves along I will have more pictures. I know that I will need and welcome suggestions from more expirenced builders. Thanks for looking
Doug
Doug |
Thanks Pete great picture with lots of good information. It will come in handy when I get to that point. Now that you found your plans, maybe it is time to build another new scratch built 63' eh what? I just started building the lower cabin, not much to look at right now though.
Doug |
Sterling '63 pictures
This is the latest progress on my 63' . It is starting to like a boat now. I have also included some pictures of my Charles Adams DDG 2. She has been in the water a few times but not finished. Right now it just sits on the bench gathering sanding dust from the other projects waiting for me to get back . to finish the detail work. Please forgive the dust. Thanks for looking.
Doug |
tinknocker, the orginal kit called for the use of alot of balsa, I was wondering if you replaced that with basswood? On my "to do" list, I have a scratchbuild 50'CC Catalina in basswood and mahogany. I think by replacing the balsa with basswood would produce a heavier, more substancial model.
Predredadnut you are right about the balsa. I did replace some of the balsa with basswood. The chines and and the sheers are bass. All of the removable rear deck framing was replaced with bass. The lower cabin formers are bass. Anything that will be handled on a regular basis will be basswood. Basswood is considerable stronger than balsa but does not add that much weight overall. I like the look of the solid mahgonany, the drawback that I am finding out is that it splits very easily. You have to very careful and not put undue pressure on it.
Minnetonka Minnesota
Joined Aug 2007
. I'll bet there aren't a lot of doll houses with heating ducts. At one point I got the idea of putting a bunch of fans up in the superstructure of the DD I'm building, drew it all up, I had ducts running all over the ship, to ventilate all the heat from the steamplant and engine, I've since rethought that out but will still have some fans.The boat looks great, it's going to be a beaut. How are you planning on sealing and painting the inside of the hull? Cap |
Bonita Springs,Fl.
Joined Sep 2007
Hey tinknocker. Looking good there sir. Kinda like building an airplane wing huh? Got a tip for you.Try and find a SINGLE piece of wood to cover the cabin top and the bridge top. In my kit the tops were of two pieces of wood and I have never been able to keep the seam from openng up over the cabin. I have sealed it several times with all kinds of stuff including epoxy pushed into it and the wood split again next to the epoxy. The crack keeps coming back. Must have ten coats of paint on it too and it's still there. Pete
As for sealing the inside of the hull, it is coated with two coats of clear epoxy so it is well waterproofed. Some boats Have been painted over the epoxy but most have been left natural. Thanks for the nice comments good luck with your project. Doug |
Thanks for heads up Pete. You have a good idea. Plywood would be about the only wood wide enough to cover that in one piece. I have a piece of 1/16th inch ply cut cross grain for easy bending but the lower roof has a compound curve so I don't know how that will work out. Definitely something to think about. Doug |
| Thread Tools | |
| Scratch-built (meat trays) Parkflyer flies! | pullin-gs | Parkflyers | 30 | Sep 17, 2001 01:02 PM |
| Anybody used firebird wings for scratch built slowflyer? | kit basher | Parkflyers | 5 | Jul 29, 2001 08:27 PM |
| My scratch built trainer | Tyson | Beginner Training Area (Aircraft-Electric) | 2 | May 28, 2001 01:44 AM |
| My scratch built Lite/dusk stik. | Dandi6065 | Parkflyers | 4 | May 13, 2001 11:51 PM |
