Old Feb 05, 2008, 11:45 PM
molenjin is offline
Find More Posts by molenjin
Serbia Moderator
molenjin's Avatar
Australia, SA, Adelaide
Joined Oct 2006
My scratch built "STICK" balsa plane
This is the my new balsa project, an aerobatic model for a 400-class brushless motor, 3S battery and 9x6 prop.
I wanted to have a park-flyer capable of performing fast loops and low passes, but solid and easy to build. I wanted it to have ailerons, symmetrical airfoil and modern powertrain.
It all started with balsa sheet sides. I checked the postion of the motor and battery.
The motor is Hang-IT R/C XTRM XTRM 2212/15 (http://www.aussiemodelforum.com/Main...Article&id=441)
The battery shown here is an Align 2S / 1900 mAh, but the one that goes in the model will have three cells, of course.
The picture also shows the plywood firewall (4 mm) and two plywood sides as a protection for the motor. This will be a bit unusual nose shape - closed from three sides, only opened at the bottom. People normally build their "sticks" with motor exposed from all sides.
Now, the wing. It's flat, no V-shape. Altogether I've cut 14 ribs, 4 of them are a bit thicker and will be used for the central section. The airfoil is symmetrical, S8035 14% (another good airfoil is NACA 0015). Using a symmetrical airfoil makes the building a bit more difficult.
molenjin is offline Find More Posts by molenjin
Old Feb 06, 2008, 12:07 AM
molenjin is offline
Serbia Moderator
molenjin's Avatar
Joined Oct 2006
Central section, Servos
Three E-flite S75 micro servos. They are pretty much the same as Hitec's HS-55. There is a minor issue with these servos, though, the cable makes the installation a bit tricky, especially if you use thicker plywood for mounts. The servo simply does not want to go through. Oh, well...
Here you can see the end of the fuselage and the wing's central section. I used two carbon tubes as spars - very light but very stiff at the same time. The wing will be fixed using nylon bolts. The aileron servos will be mounted upside-down.
Old Feb 06, 2008, 12:26 AM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Wow.... you do nice work!!!
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Feb 06, 2008, 11:37 AM
GDR is offline
GDR
Find More Posts by GDR
GDR
Joined Dec 2007
More pics please...
I just completed my own scratch stick so this is very interresting to me. Mine is not nearly as pretty and cleanly built as yours.
What are your dimensions?
Mine is a true stick fuse (I used the stongest peice of balsa I could find-light but fragile.)
30" x 8 1/2" wing (ailerons 2"). Flat bottom airfoil. I used 10 ribs instead of your 14 and wood dowels instead of your carbon. I was going for cheap and easy on this one.
I have not maidened mine yet but I'm hoping for good slow performance w/ a very "lifty" wing that lets me do low speed rolls and such with a 2 cell battery.
Please keep us updated.
GDR is offline Find More Posts by GDR
Old Feb 06, 2008, 05:22 PM
molenjin is offline
Serbia Moderator
molenjin's Avatar
Joined Oct 2006
Hello NoFlyZone & GDR, thank you for your comments!
Might be good, but I still think this sort of model screams for power, so a 3S battery is necessary.
I fly my "Robina" e-glider: http://www.aussiemodelforum.com/Main...Article&id=405 on a 2S battery, and it's not bad, but, again, not much better than a Speed 400 with Nicads. 2S is only good, IMHO, for very small or indoor models.
I will soon post a scheme with all important dimensions. At this stage, I can say that the wing span is about 96cm and projected weight would be 500g (50% for the airframe, 50% for motor, battery & RC).
Cheers,
Miroslav, Brisbane
Old Feb 06, 2008, 08:57 PM
AmateurE is offline
Find More Posts by AmateurE
AmateurE's Avatar
Joined Feb 2003
Miroslav, my word, congratulations, that has got to be the cleanest model in progress and work area I have ever seen. The wood, the cuts, and the joinery look excellent. Where is the traditional piles of tools that slowly will occupy every square inch (or centimeter) of work space? Let alone all the sawdust, random bits and pieces of balsa, the blood splatters from Xacto blades gone wild and the traditional thumbprint on the fuselage that happens when thin CA meets skin. Looking forward to the build. Excellent work!
AmateurE is offline Find More Posts by AmateurE
Old Feb 06, 2008, 10:19 PM
molenjin is offline
Serbia Moderator
molenjin's Avatar
Joined Oct 2006
>..that has got to be the cleanest model in progress and work area I have ever seen.
Well... my garage and my work table is a pigsty, like any one else's, I guess ..
But when I need to make photos of the current progress, I do it on my car's trunk:
Old Feb 07, 2008, 01:15 PM
GDR is offline
GDR
GDR
Joined Dec 2007
I still can't get over how clean your wing ribs are. How do you cut/shape them? I stack mine like you did then shape them on a belt sander. Works well and it's fast and easy.
I maidened mine today and I was very pleased. Did exactly what I had hoped. Flew and was controllable at a walking pace. At full throttle it could climb ALMOST verticle from level flight (I used a 11/4.5 " prop). If I did a dive to get a little extra speed I could do some nice verticle rolls. The big ailerons really helped it do very quick horrizontal rolls at slow/medium speed. This is just what I was shooting for, now I have something to fly my stupid 2cell batteries with and still have fun. This was my first attempt at scratch building so I'm thrilled the thing got off the ground at all.
Can't wait to see your final product.
Old Feb 07, 2008, 01:20 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
I agree. Great work. Following closely.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Feb 07, 2008, 07:35 PM
oldschoolvdub is offline
Find More Posts by oldschoolvdub
oldschoolvdub's Avatar
Santa Maria, CA
Joined Oct 2007
You're quite the photographer also. Very nice...
oldschoolvdub is offline Find More Posts by oldschoolvdub
Old Feb 08, 2008, 12:29 AM
groundfx is offline
Find More Posts by groundfx
Delta, BC, Canada
Joined Oct 2003
It's great to see a quality, hand-cut balsa build. Great work. Thanks for sharing.
groundfx is offline Find More Posts by groundfx
Old Feb 08, 2008, 08:00 PM
zikaslika is offline
Find More Posts by zikaslika
Belgrade
Good work!
zikaslika is offline Find More Posts by zikaslika
Old Feb 08, 2008, 08:10 PM
molenjin is offline
Serbia Moderator
molenjin's Avatar
Joined Oct 2006
Me too.
But with a full-time job and three kids, it does not go that fast...
Old Feb 08, 2008, 09:15 PM
TommyB is offline
Find More Posts by TommyB
Central PA
Joined Dec 2005
That is just awesome craftsmanship!!
Looks heavy, what's it weighing like that?
TommyB is offline Find More Posts by TommyB
Old Feb 08, 2008, 10:09 PM
Arrow is offline
Find More Posts by Arrow
Crash happens! :)
Utah
Joined Jun 2002
Arrow is offline Find More Posts by Arrow
My scratch built Erez-E Parkflyers 1 Nov 24, 2002 11:00 PM
My Scratch built Micro F-16 chiefwinston Electric Ducted Fan Jet Talk 6 Nov 10, 2002 05:13 PM
Started my scratch built mimi heli Gonflyin01 Electric Heli Talk 1 Apr 30, 2002 07:16 PM
My scratch built trainer Tyson Beginner Training Area (Aircraft-Electric) 2 May 28, 2001 01:44 AM
My scratch built Lite/dusk stik. Dandi6065 Parkflyers 4 May 13, 2001 11:51 PM
