Old Feb 05, 2008, 10:27 AM
Godsbrother is offline
Find More Posts by Godsbrother
Foam Safe CA or Not?
Hi,
I am trying to clarify if I need to but foam safe CA for elapor (Multiplex) ir not?
I have asked a couple of different localish shops and get two different answers?
One says yea becuase its foam and the other says no because its not polysterene?
Can anyone assure me either way please?
I have done some searches but the threads are so large I can't be sure I find the right answer.
Cheers
Harvey
Godsbrother is offline Find More Posts by Godsbrother
Old Feb 05, 2008, 11:43 AM
tofuti is offline
Find More Posts by tofuti
This is glue Strong Stuff
tofuti's Avatar
Palo Alto, CA
Joined Oct 2007
Originally Posted by Godsbrother
Hi,
Cheers
Harvey
Just use regular CA. The manual says specifically to NOT use foam safe CA.
I just built a multiplex gemini, using regular CA throughout, no worries.
The manual also says to use kicker, but this is not required, or desired in my opinon, unless you are building to fly tomorrow. Some of the parts have a close fit and I would not want to use kicker in case my alignment is a bit off. Better to use slow cure and have max alignment time.
Also, be careful about what tape you use to hold parts together while drying. For lack of anything better lying around I used electrical tape, and it pulled some of the coating off the elapor. Not super noticable, but still....
tofuti is offline Find More Posts by tofuti
Old Feb 05, 2008, 11:52 AM
Ok cheers its nice to get confirmation when someone who has done it
cheers
Old Feb 05, 2008, 12:12 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
I have 3 EasyStars and an Easy Glider Electric from Multiplex, and MultiPlex, in it's instructions, specifically states NOT to use foam safe CA.
I get great results with what they recommend, which is regular old CA.
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Question Can you put epoxy or Gorilla Glue over foam-safe CA? Spackles94 Electric Plane Talk 5 Aug 12, 2007 06:58 AM
Careful! FOAM SAFE CA GLUE ....not so safe ! inventing_man Foamies (Kits) 15 Jul 26, 2006 11:01 PM
Discussion foam safe ca not working...need moisture??? yodie001 The Builders Workshop 3 Jan 27, 2006 04:13 AM
Slowstick Repairs: Epoxy or Foam Safe CA? kizzy Beginner Training Area (Aircraft-Electric) 7 Nov 13, 2005 12:09 PM
Question Foam Safe CA... NOT!! craab Foamies (Kits) 12 May 15, 2004 11:28 PM
