Go Back   RC Groups > Vendors > Millennium R/C
Old Feb 04, 2008, 09:24 PM   #1
Site Sponsor
jkarpy's Avatar
X-Gear Build
X-Gear assembly Part 1
  • Name: DSC02000.jpg
Description: Items needed for X-Gear assembly. Close nip cutters are not shown but are needed. Items needed for X-Gear assembly. Close nip cutters are not shown but are needed. 89.5 KB · Views: 577
  • Name: DSC02004.jpg
Description: Left and Right bottom strut: Left and Right bottom strut: 72.4 KB · Views: 272
  • Name: DSC02009.jpg
Description: With fine grit, sand paper, rough up the surfaces to be glued. With fine grit, sand paper, rough up the surfaces to be glued. 71.5 KB · Views: 260
  • Name: DSC02013.jpg
Description: Cut away all mold flash Cut away all mold flash 46.1 KB · Views: 242
  • Name: DSC02005.jpg
Description: Use close nip cutters to remove the ejector pin bump on part “I”. This pump can prevent the X-Gear from gripping the carbon rods. Use close nip cutters to remove the ejector pin bump on part “I”. This pump can prevent the X-Gear from gripping the carbon rods. 44.5 KB · Views: 302
  • Name: DSC02034.jpg
Description: Test fit before glueing. No air gaps should be present between the two parts . Apply medium CA glue to all surfaces that make contact with joining part. Test fit before glueing. No air gaps should be present between the two parts . Apply medium CA glue to all surfaces that make contact with joining part. 47.0 KB · Views: 255
  • Name: DSC02035.jpg
  • Name: DSC02036.jpg
  • Name: DSC02039.jpg
Description: No air gaps should be present between the two parts before or after clamping. No air gaps should be present between the two parts before or after clamping. 54.9 KB · Views: 202
  • Name: DSC02051.jpg
Description: Clamp the parts while they are drying. Allow the glue to dry completely before removing the clamps and installing part “L” and “J”. Clamp the parts while they are drying. Allow the glue to dry completely before removing the clamps and installing part “L” and “J”. 63.4 KB · Views: 256
  • Name: DSC02014.jpg
Description: Main Strut:
Again, with fine grit, sand paper, rough up the surfaces to be glued. Main Strut: Again, with fine grit, sand paper, rough up the surfaces to be glued. 72.1 KB · Views: 219
  • Name: DSC02016.jpg
Description: Cut away all mold flash Cut away all mold flash 46.2 KB · Views: 213
  • Name: DSC02017.jpg
Description: Apply medium CA glue to all surfaces that make contact with joining part. Apply medium CA glue to all surfaces that make contact with joining part. 50.7 KB · Views: 213
  • Name: DSC02018.jpg
  • Name: DSC02022.jpg
  • Name: DSC02019.jpg
  • Name: DSC02020.jpg
  • Name: DSC02023.jpg
Description: No air gaps should be present between the two parts before or after clamping. No air gaps should be present between the two parts before or after clamping. 57.7 KB · Views: 208
  • Name: DSC02025.jpg
Description: Clamp the parts while they are drying. Clamp the parts while they are drying. 54.4 KB · Views: 182
  • Name: DSC02033.jpg
  • Name: DSC02053.jpg
Description: Wait until the CA glue has set to proceed to the next step. Wait until the CA glue has set to proceed to the next step. 92.1 KB · Views: 205
  • Name: DSC02054.jpg
Description: With fine grit, sand paper, rough up the bottom surfaces of the left and right bottom strut and the inside of part “L” and “J”. With fine grit, sand paper, rough up the bottom surfaces of the left and right bottom strut and the inside of part “L” and “J”. 60.9 KB · Views: 203
  • Name: DSC02055.jpg
Apply medium CA glue to all surfaces that make contact with joining part. 55.5 KB · Views: 216
  • Name: DSC02057.jpg
  • Name: DSC02056.jpg
Description: Install parts L and J:
Hold parts together while applying an accelerator to the glue. Install parts L and J: Hold parts together while applying an accelerator to the glue. 59.2 KB · Views: 222
  • Name: DSC02058.jpg
Description: Do not install the remaining hardware until the CA glue has completely cured. I leave mine to dry over night. Even though the outside of the glue is dry to the touch, the inside is still curing.
Do not install the remaining hardware until the CA glue has completely cured. I leave mine to dry over night. Even though the outside of the glue is dry to the touch, the inside is still curing. 78.8 KB · Views: 248
jkarpy is offline Find More Posts by jkarpy   Reply With Quote
Old Feb 06, 2008, 10:33 PM   #2
Site Sponsor
jkarpy's Avatar
X-Gear Build Part 2
Final assembly
  • Name: DSC02064.jpg
Description: Now that the CA glue has completely cured, you are ready to install the carbon and hardware. Now that the CA glue has completely cured, you are ready to install the carbon and hardware. 92.1 KB · Views: 258
  • Name: DSC02067.jpg
Description: Start by pushing the hex nuts into their sockets. Start by pushing the hex nuts into their sockets. 60.1 KB · Views: 199
  • Name: DSC02069.jpg
Description: Use a blunt tool to push the hex nut into the socket. Use a blunt tool to push the hex nut into the socket. 55.8 KB · Views: 199
  • Name: DSC02070.jpg
Description: Install screws as per instructions. Do not tighten at this time. Install screws as per instructions. Do not tighten at this time. 80.7 KB · Views: 198
  • Name: DSC02071.jpg
  • Name: DSC02072.jpg
  • Name: DSC02073.jpg
  • Name: DSC02074.jpg
  • Name: DSC02075.jpg
  • Name: DSC02076.jpg
  • Name: DSC02078.jpg
  • Name: DSC02079.jpg
  • Name: DSC02080.jpg
Description: All the screws have been installed but not tightened. All the screws have been installed but not tightened. 70.1 KB · Views: 203
  • Name: DSC02081.jpg
Description: Install the wheels. Note: the X-Gear does not include wheels. Install the wheels. Note: the X-Gear does not include wheels. 61.1 KB · Views: 250
  • Name: DSC02082.jpg
  • Name: DSC02083.jpg
  • Name: DSC02084.jpg
  • Name: DSC02087.jpg
Description: Cut off the excess screw length. Cut off the excess screw length. 76.1 KB · Views: 217
  • Name: DSC02089.jpg
Description: Grind off the sharp edge of the cut screw. Grind off the sharp edge of the cut screw. 73.9 KB · Views: 236
  • Name: DSC02091.jpg
  • Name: DSC02094.jpg
Description: Round off the tips of carbon Round off the tips of carbon 83.0 KB · Views: 221
  • Name: DSC02095.jpg
  • Name: DSC02093.jpg
Description: Insert the carbon into the lower strut
Do not use a twisting action when you install the carbon into the plastic. It also helps to wrap a little Teflon tape around the end of the carbon before you insert it. Insert the carbon into the lower strut Do not use a twisting action when you install the carbon into the plastic. It also helps to wrap a little Teflon tape around the end of the carbon before you insert it. 76.3 KB · Views: 221
  • Name: DSC02096.jpg
  • Name: DSC02099.jpg
Description: Align the wheels as close as possible to there final position and insert the carbon in the main strut. A slight toe in is preferred. Avoid twisting the carbon once it is inserted in the strut. The strut walls have ribs that help hold the carbon in place. Align the wheels as close as possible to there final position and insert the carbon in the main strut. A slight toe in is preferred. Avoid twisting the carbon once it is inserted in the strut. The strut walls have ribs that help hold the carbon in place. 77.8 KB · Views: 247
  • Name: DSC02100.jpg
Description: Tighten all the screws until the carbon is secure. Never adjust the wheel position with the carbon tight. Tighten all the screws until the carbon is secure. Never adjust the wheel position with the carbon tight. 68.7 KB · Views: 209
  • Name: DSC02104.jpg
Old Feb 07, 2008, 11:44 PM   #3
Site Sponsor
jkarpy's Avatar
X-Gear Mounting option B strut.
X-Gear Mounting option B strut. (Work in Progress)
Old Feb 07, 2008, 11:48 PM   #4
Site Sponsor
jkarpy's Avatar
X-Gear for AP (Work in progress)
Old Mar 04, 2008, 07:37 PM   #5
Silver Member
Site Sponsor
Diggs's Avatar
Send a message via Yahoo to Diggs
Thanks for this thread James. I just finished up my first set of the new gear following this. Pretty simple build. Although I didn't sand nor trim the excess. I couldn't find any to trim off It is very solid, good improvement over the previous X-Gear!
Diggs
Diggs is offline Find More Posts by Diggs   Reply With Quote
Old Mar 04, 2008, 08:08 PM   #6
Site Sponsor
jkarpy's Avatar
Diggs
Thanks Diggs, it brings you back to the old plastic model day’s doesn’t it?
P.S.: Just don’t stick a firecracker in it!
Old Mar 05, 2008, 12:26 AM   #7
Silver Member
Site Sponsor
Diggs's Avatar
LOL, Yeah it did. And I got glue all over the place, just like the old days
Diggs
Old Mar 05, 2008, 09:39 PM   #8
East Coast Slacker
mbragdon's Avatar
Very helpful thread, the glue is drying now.
mbragdon is offline Find More Posts by mbragdon   Reply With Quote
Old Mar 22, 2008, 10:03 PM   #9
ein flugel schplinterizer
seanpcola's Avatar
I saw these at the Perry swap meet, came home and ordered a set for my Eratix. Did a little beef-up on it and think it is going to work fine. I know it was made for a smaller, lighter model but pretty sure I won't have any problems. IF it does not take the weight then I suggest we bombard Millenium with emails till they make us a bigger size too!
seanpcola is offline Find More Posts by seanpcola   Reply With Quote
Old Mar 22, 2008, 10:16 PM   #10
Site Sponsor
jkarpy's Avatar
We are considering smaller and larger sizes.
James
Old Mar 22, 2008, 10:29 PM   #11
seanpcola's Avatar
James
Works for me!
Actually, after looking it over I was wondering about maybe even a version for quite a bit larger models. The problem I am seeing on rougher fieds is that most gear does not allow much "cushion". I wanted to experiment with your gear to see how much it flexed. I was even think things like making the fittings out of aluminum, of course much larger and longer rods and so forth. You may have really started something here.
I know it may be pushing it using the X gear on the Eratix but after comparing it more and more to the stock gear I seriously think it should work.
Plus, you can't beat the "bling" factor either!
Old May 28, 2008, 01:32 AM   #12
ok_flyer's Avatar
The X-Gear is a sweet upgrade. Nothing like getting rid of those flimsy, music wire rods that come stock from GWS. The foam wheels are just the right size and look great!
I would like to see a tail dragger mod similar to the X-Gear. I was trying to come up with one myself and decided to use the spare parts from my X-Gear kit to make one. Here's a link to the thread:
http://www.rcgroups.com/forums/showthread.php?t=865847
ok_flyer is offline Find More Posts by ok_flyer   Reply With Quote
Old May 29, 2008, 11:11 PM   #13
I beat Pud 3-4 days a week
rcproptester's Avatar
Send a message via AIM to rcproptester
I finally got the floats finished for my SSX. Just got them mounted tonight. I hope to do a dry run with them tomorrow after work, then down the road to the pond to try them out. Anything I should know before starting?
Wish me luck
rcproptester is offline Find More Posts by rcproptester   Reply With Quote
Old May 30, 2008, 01:03 AM   #14
Site Sponsor
jkarpy's Avatar
Wish me luck
Make sure the front half of the floats are in front of the CG.
Old May 30, 2008, 06:20 AM   #15
I did that. the CG is right about 1 1/2 inches in front of the "step" in the float
Also, How did I post this in the x-gear thread? I meant to put it in the ssx thread
Looking into Warbird, Racer, w/gear build- Suggestions? SoulTag High Performance 3 Jul 07, 2005 05:09 PM
ARK X 400 build problem thanhTran Mini Helis 22 May 13, 2005 10:05 PM
[spam] Re: Eduard 1/48 Bell X-1A Build-Up teh insane Gaymer rec.models.rc.helicopter 0 Mar 07, 2005 11:11 AM
[spam] Re: Eduard 1/48 Bell X-1A Build-Up teh insane Gaymer rec.models.rc.soaring 0 Mar 07, 2005 09:13 AM
[spam] Re: Eduard 1/48 Bell X-1A Build-Up teh insane Gaymer rec.models.rc.air 0 Mar 07, 2005 09:11 AM
Bored? Want to fight?
Join the RCGroups clan!
