Old Feb 03, 2008, 08:29 PM
GeneR is offline
Find More Posts by GeneR
Lake City, PA USA
Joined Sep 1999
Program SPektrum DX6I Aero Throttle Hold
Hi All,
New DX6I owner here (came with a Blade 400...). I purchased a couple of 6100 rx's to use with my foamy park flyers I fly indoors. Going from a Hitec Optic 6 to the 6I. The planes fly great with the Spektrum and I am a happy guy.
Anyway, my question is about throttle hold. On the Optic I pushed a button and the throttle was locked so if I hit the stick it did not start the motor. I like to use this when I carry the plane to the flight line.
On the 6I I cannot seem to make this work in the airplane mode. I figured I would need a programmable mix but I cant seem to get it to work. I have tried lots of different things, and even mixed lots of things just to see if I understand how the mixing worked (for example mixing rudder with ailerons worked fine).
So, has anyone with a 6I been able to do this?
Any help appreciated.
Gene
GeneR is offline Find More Posts by GeneR
Old Mar 31, 2008, 08:44 AM
zirconx is offline
Find More Posts by zirconx
Nebraska
Joined Dec 2007
Gene did you ever figure this out? I was wondering how to do the same thing with my DX6i...
zirconx is offline Find More Posts by zirconx
Old Mar 31, 2008, 12:37 PM
GeneR is offline
Lake City, PA USA
Joined Sep 1999
Spektrum support says it cannot be programmed this way. They suggest simply not arming the speed control until the plane is on the flight line.
Gene
Old Sep 08, 2009, 07:10 PM
bill williams is offline
Find More Posts by bill williams
Joined Apr 2008
Thanks guys. I have throttle hold programmed on all my helis. We have normal, stunt, and hold, throttle curves available in the heli mode. I move between normal and stunt curves with my gear/f mode switch on the left of the tx (can call it the "idle up" switch). I can also move between normal or stunt curves to the hold curve with my mix/th hold switch on the right of the tx. I flatline the hold curve at 0.0% so that when I move the switch to the hold position the throttle stick sends 0.0% no matter where I move it. This is a great safety device in case the throttle gets bumped. I just tried do something similar for my first airplane in the acro mode. I tried everything I could think of in the mix area with no luck. At least now I don't feel like such a dunce.
bill williams is offline Find More Posts by bill williams
Old Sep 09, 2009, 05:39 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
You can still feel like this for replying to a 1 year old thread.
The only throttle hold on DX6i is in HELI mode.
Use a rubber band tied to the back brace and wrap around the front and on the throttle stick if you are that afraid of hitting the THR stick.
freechip is offline Find More Posts by freechip
Discussion Spektrum DX7 with Phoenix - Throttle hold questions... mdavenport Simulators 3 Sep 10, 2007 12:21 PM
Discussion Setting up the Spektrum DX6 for Throttle Hold (Heli) HavingFun2002 Radios 2 Sep 03, 2006 01:00 AM
throttle hold setup problem? Futaba 6xh & Voyager E, can anyone help amateur3 Electric Heli Talk 2 Jan 07, 2003 09:14 AM
Throttle Hold johnhlong Electric Heli Talk 10 Jul 16, 2002 06:40 PM
Throttle hold in governor mode dshuen Electric Heli Talk 0 Apr 28, 2002 10:48 PM
