Ressurection: Royal 1/2A P-51
I built this around 12 yrs ago. Originally for .10 size engine. Flew it for two yrs, until 1998 when I came into the light and started being a totally electric modeler. The plane had and interesting maiden flight. At that time, I would often recruit other knowledgeable modelers to do the first handlaunch. A club member, who was in the hobby since I was a boy, volunteered.
The plane was initially nose heavy, slightly. I have a finger and thumb grip on the wing's bottom @ the CG. The gentleman claimed to have handlaunched "hundreds" of airplanes. I told him it was nose heavy, but to fight the "feel" and launch it level. He took a run of about 10 steps( it was probably the fastest he has moved in 50yrs), STOPPED DEAD, and proceeded to throw it almost vertically. The little .10FSR sagged, labored. And my new Mustang torque rolled, headed to the ground. It pulled out inches from the ground and chased my veteran handlauncher back into the pits.Me being a safe type of person, I rolled it into the ground. Wing saddle, nose broke. My veteran handlauncher vowed he would never again launch one of my planes. I agreed with him adamately...and since then I do my own launches.After repairs, it flew well. And was one of my favorites. It had droppable wing tanks. The tubes are still in the wing for the release cords. I may hook it up someday. I still have the glass tanks I made. The Royal Mustang had a lot of issues. Rudder profile was way off. Tip chord too wide. And the nose built into a funky shape, from too low of a thrust line. While changing the vertical shape, I made the surfaces built-up. Horizontal also. Fin and stab covered w/1/32". Rud&elev covered in silk. I fully planked the wing. Originally C-Tube cap stripped. After completeting the A-20, I needed another plane to get ready for the spring. Most of my airforce being sold off to financially survive. I studied either this or and old Guillows P-47(I have a /5 Mega for that). I changed the thrust line and made a new chin block. More scale in outline. The new power plant is a Mega 16/25/4. With a 8-6SF and 3s it draws 25A @ 255W. About twice the thrust of the .10. And less weight. Searching the web, I could not decide on a color scheme of any single model. So.. I will do it in a proto-typical fasion. And yes Doug, it will have a mouth with teeth! Fuzz
It should fly many X's better, this way Tom.
Worked seven days, this week. But did get a little done. Now to work on the "mouth". Bottom of 51 done in Krylon smoke grey. Top in Italion Olive w/ Model Master Euro Grey I. I'm using most stuff I had on hand. If you have never considered using Krylon Acrylics, try them. $2.97 a can. And the pigments are fantastic for a light finish. Dry to touch in no time. Can be masked in a few hrs. Fuzz |
Now that’s a good-looking bird! Can’t quite figure out exactly what it is about it; just something about the nose area…………..
That Krylon really does seem to work well. Good color, and depth. Should be a fine flyer. What is the auw? I’ve got to get outside now and push around 8 inches of spring. I think this year we’re gonna go directly into summer (of course, mud season should be something to behold this year.) Doug |
Hi Doug! The AUW is 29oz with a Hyperion 2200 3s. 27oz with a 1500-3s. It balances perfectly, now. It was over 30 oz and nose heavy, when an I.C. (can I say that here?) model. It took a good heave to get it airborne with the .10 FSR and 7-4 prop. Now it has over 1-1 thrust with the 8-6SF. I may go to a 8-6E, to lower the amp draw and get the top end a little faster. Still will have over 1-1 thrust. 25A @ 255W. Whats that about 180w per Lb? ooooo.... Thats a good number for an EDF!
Fuzz |
United States, TN, Blountville
Joined Oct 2002
Nice job Fuzz.
My what big teeth you have grandma! I think you need to redo it with a cutdown canopy and slender turtledeck added to make her a racing P51...the slenderness of the fuse and curves of the rear fuse suggest a faster airplane... RAFster David P.S. What other jewels do you have to re-breath life into? |
Great Work Steve,
I was never able to get the IC thing to work. Electric makes so much more possible. I have rescued a couple of Guillows, One worked (P-51) and one did not so far (P-40). I hope you bring the P-47 back to life. I just finished mine and I think it flys better than the Alfa faomie. Good luck getting your sharkstang back up. Love those teeth. Cheers, Mark |
Hi David! The Royal canopy is not sized correctly for this plane. Definetly kind of cartoonish.. What other jewel's? Hmmm..
Mark, I had problems with the P-40 also. I even enlarged it to 36". It always acted like the tail surfaces were stalling. Even at high speed. But that was IC. Maybe with a larger "E" prop, the problem will go away. Danbury, ehh.. I go through there on my way to N.Y. on my deliveries. Then I go north on 22 up to Pawling, Rhinebeck, and across the Hudson on the Kingston bridge. Beautiful scene, there. Every thursday, usually. The rest of the week, I only go as far as Wallingford, or Southington. Amazing; CT has a lot of "Fords" and "Bury's". Mass has there "Boro's". And R.I. has the "Tucket's"... Fuzz |
Fuzz,
Can I call you that? (just trying to sound that out in a RI accent) LOL’s on the bury’s and such, Don’t forget about “ding’s”, "ports" and of course “field’s”….. I work right off of 84 exit 2A. I will keep and eye out on Thursdays. Does your vehicle have shark teeth on it? That sure is a nice drive up 22. Drop in for a fly if you like at one of our “fields”. Yea the Guillows P-40 has been elusive, But I will be taking another shot at it soon. Thanks for sharing your experience. Looking forward to hearing about your Mustang electrified remaiden. Mark |
Hey..CT has a "tucket", too! Shetucket! I'se be gowin to "Nue Yawk" tamarra mawning, Mock...down't know me root yet. But, I'se uses root I-84 all da' time.. I'se drives a Carbone Floral truck. Isuzu, cube. I usually goe through Danbury around 9am. But If I have deliveries in Waterbury or Naugatuck, it may be later. I never know till I see my manifest and log.
I'm sure the Mouthstang will fly great. It was excellent when nose heavy, with the .10. I think I'm going to give a 7-5E prop a try. See what I get for readings. I just don't see the need for 255W of consumed power. Fuzz |
| Thread Tools | |
| Sold New HERR 1/2A P-51 MUSTANG Kit | PFTrvlr | Aircraft - Fuel - Airplanes (FS/W) | 1 | Feb 05, 2006 03:46 PM |
| NIB Royal 40 size P-51 Mustang | Tony D. | Aircraft - Fuel - Airplanes (FS/W) | 0 | Dec 05, 2002 05:56 PM |
| Pica 1/12 P-51 | TONY DENTON | Sport Planes | 1 | Sep 28, 2001 04:01 PM |
| House of Balsa 1/12 P-51 as a Sloper? | Foxtrot | Electric Sailplanes | 9 | Jul 12, 2001 09:54 AM |
