Old Oct 13, 2012, 11:15 AM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
the art of the impossible.
to cut thin and tapered .. with cnc hot-wire can be very demanding.
clausxpf is offline Find More Posts by clausxpf
Old Oct 14, 2012, 08:45 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Alinement of wings.
to have the wing sitting as a straight line on both sides, I use this old trick from my day as carpenter.
Old Oct 15, 2012, 10:09 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
I have to make the duct now.
I am doing an other variant for a area ruled duct just to see the difference
Old Oct 15, 2012, 10:10 AM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yep those are some of the longest ducts
AIR SALLY is offline Find More Posts by AIR SALLY
Old Oct 15, 2012, 10:28 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
it is some 4-5 inch too long at the picture
Claus
Old Oct 15, 2012, 06:26 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
my plug was about 2" long i think ,it allows you some adj as to where you want your motor/fan.mine needs the motr a bit further fwd of where you had it shown on your drawing ,to keep the batt out of the cockpit.
Old Oct 18, 2012, 09:41 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Making ducts
to make plugs ready for making ducts takes some time!
it have now got its final epoxy coating.
Old Oct 18, 2012, 02:42 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yes it does ,i was lucky and got just one to work well enough for both sides.
Old Oct 19, 2012, 02:35 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Ready to glass
they have got sealer, sander and epoxy primer, 4 times of wax and one coat of pva.
Old Oct 19, 2012, 05:24 PM
jweber009 is offline
Find More Posts by jweber009
PH.D in Scratchbuilding
Denmark, Region Zealand, Holbaek
Joined Sep 2005
Looking good Claus.....
jweber009 is offline Find More Posts by jweber009
Old Oct 19, 2012, 05:46 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yep looking good ,are you installing landing gear in this one ? or are you flying from a bungee?
Old Oct 19, 2012, 05:56 PM
Mr Pheer is offline
Find More Posts by Mr Pheer
Mister Fear
USA, NV, Las Vegas
Joined Nov 2010
I just got my hands on a HO scale train transformer.
Time to cut some foam
Mr Pheer is offline Find More Posts by Mr Pheer
Old Oct 19, 2012, 06:03 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yippee ..it's a fun plane to build ...very shapley...you know the rules post some pics when you get started.
Old Oct 20, 2012, 09:02 AM
D_FAST is online now
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Air Sally,Claus,
Whats the average layup time for this style of ducting, i mean making the plugs,filling, sanding, sanding more, the waxing the pva, to the final product?
Im getting into glass more and more with my builds, and Im thinking of tackling some ducting on my next project. Just want kinda of know what im getting myself into and how deep its going to go into my wallet. :P
I have seen that scratchbuilding isnt as cheap as just going out and buying a airframe.
But who wants the same airframe that a dozen other flyers at the local field have. Its one of the motivating factors that drives me to my creations
So approx time/budget would be some great info.
D_FAST is online now Find More Posts by D_FAST
Old Oct 20, 2012, 09:51 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Making ducts
I have spend 12 hours or so.. plus drying time on this three parts.
to keep the glass in tight contact with the plug I use vacuum bags sealed with my foil iron and wax around the tubes.
vacuum comes from a simple fish-tank pump where we revised the pump direction.
Discussion Made in Sweden J-35 Draken Jocke Electric Ducted Fan Jet Talk 45 Feb 03, 2008 11:37 PM
Discussion Saab Draken J-35 cyclops2 Japan 1 Aug 10, 2007 01:37 PM
Discussion J-35 Draken from blue fanfold. soarrich Pusher Prop Jet Models 0 Jan 08, 2006 06:27 PM
GWS J-3 Gets Flaperons, Build Photos 4throttles Parkflyers 9 Aug 12, 2002 01:06 AM
