Old Oct 05, 2012, 07:06 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Originally Posted by corsair nut View Post
man that looks great claus! looks like a great way to make plugs too...fully composite 90mm cougar anybody??? haha.
Yes please!
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Oct 05, 2012, 07:09 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
send me the foam parts and ill make plug and molds. and duct plugs
corsair nut is online now Find More Posts by corsair nut
Old Oct 09, 2012, 08:32 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
GregG is offline Find More Posts by GregG
Old Oct 09, 2012, 12:51 PM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
The main problem is that I do not have money enough to buy materials and send it to you.
after I got on pension my income have been 1/3 of what I had before.
But one thing is to make full glass fibre things ... my way of building is much stronger to the weight it have.
Claus
clausxpf is offline Find More Posts by clausxpf
Old Oct 09, 2012, 01:18 PM
tehachapi, CA
Joined Jan 2006
well let me know what it might cost, id like to make a plug with panel lines ect, and perhaps even do composite wings/tails.
Old Oct 09, 2012, 01:37 PM
tehachapi, CA
Joined Jan 2006
claus, how hard would it be to size up to 60" long? id like to be able to use 90 or 100mm fans, and be able to carry up to 12s. the size you mentioned earlier is a hair small. let me know how much it would be to get all the parts, perhaps wing/stab cores as well...
Old Oct 10, 2012, 01:19 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
the tecnics behind the draken now turned into the cougar.
I had to test the concept with much shorter wire and more angles possible.
but it is some huge parts for that plane. the angle is 10 "
but I do have to work some days to have all the drawings ready for CNC.
Claus
Old Oct 11, 2012, 06:36 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Back to Draken II
it is next to impossible to make a wing that much tapered.
there is over-burn in the tip but I compensated that in the drawing, and the rest with a little sanding.
Claus
Old Oct 11, 2012, 07:23 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
looking good my friend
AIR SALLY is online now Find More Posts by AIR SALLY
Old Oct 11, 2012, 10:48 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Draken II
experimenting to do it simple .
the first wing was cut with very low amps/ volts. The wire sacked.
then I tried higher amps, and got more burn.
Then I tried a fan on the short side to cool down the wire a little it works partly.
might need more force on the airflow.
Claus
Old Oct 12, 2012, 01:49 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
just a little progress
those dowels are mostly for alignment, but it will not hurt the assamblement
the holes are done in the fuselage first.
that way you get a good alignment.
Claus
Old Oct 12, 2012, 03:58 PM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Ive been drawing out the center lines from the cad templates onto the foam once each station is cut.This looks much easier.
D_FAST is offline Find More Posts by D_FAST
Old Oct 12, 2012, 09:09 PM
tehachapi, CA
Joined Jan 2006
lookin great claus!
Old Oct 13, 2012, 12:29 AM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
Claus are you using white glue mixed with Lite spackle to glue the sections? And what is the ratio?
unclecrash is offline Find More Posts by unclecrash
Old Oct 13, 2012, 04:45 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
unclecrash.
no it is Gorilla glue. ( PU -glue) it hardens normally by the moisture in the air or in the wood.
it is hard to tell the ratio as the spackle is pasta like and the PU-glue is like the hardener in epoxy.. 60 : 40 will be a good starting point.
Discussion Made in Sweden J-35 Draken Jocke Electric Ducted Fan Jet Talk 45 Feb 03, 2008 11:37 PM
Discussion Saab Draken J-35 cyclops2 Japan 1 Aug 10, 2007 01:37 PM
Discussion J-35 Draken from blue fanfold. soarrich Pusher Prop Jet Models 0 Jan 08, 2006 06:27 PM
GWS J-3 Gets Flaperons, Build Photos 4throttles Parkflyers 9 Aug 12, 2002 01:06 AM
