Old Sep 10, 2012, 02:32 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
looks very nice from here
AIR SALLY is offline Find More Posts by AIR SALLY
Old Sep 14, 2012, 10:10 AM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
the bird of felix.
I am almost at the finish line cutting a couple of new Saab Drakens.
clausxpf is offline Find More Posts by clausxpf
Old Sep 14, 2012, 10:20 AM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Looks amazing!
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Sep 14, 2012, 10:36 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
nice ...alot faster than me
Old Sep 18, 2012, 04:55 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
making progress
it is a bit of a job to keep track on what one have cut and what have to be cut.
Claus
but I had to clean the building table ..
Old Sep 19, 2012, 04:24 AM
jweber009 is offline
Find More Posts by jweber009
PH.D in Scratchbuilding
Denmark, Region Zealand, Holbaek
Joined Sep 2005
Get some glue on it while all the part are ready and you still have the space.
jweber009 is offline Find More Posts by jweber009
Old Sep 19, 2012, 08:55 PM
Rocketboy1030 is offline
Find More Posts by Rocketboy1030
Rocketboy1030's Avatar
Canada, ON, Mississauga
Joined Nov 2011
My mods to MBS Draken
I flew this many flights on 5s 2700 65C/130C with the velocity RC blade and the HET 2W20 . The Velocity Rc housing gave way and twisted the mount , it pulled out he wires and I dead sticked in OK.
Maiden #3
Draken MBS models maiden3 (2 min 5 sec)
Rocketboy1030 is offline Find More Posts by Rocketboy1030
Old Sep 19, 2012, 10:33 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
Originally Posted by Rocketboy1030 View Post
I flew this many flights on 5s 2700 65C/130C with the velocity RC blade and the HET 2W20 . The Velocity Rc housing gave way and twisted the mount , it pulled out he wires and I dead sticked in OK.[/url]
3200kv on 5S in the WM400 Mk2 fan draws about 90-100A. The HET 2W-20 is 3350kv with a max current rating of 50A! You may have overheated the motor and melted the housing!
Site Sponsor
Old Sep 20, 2012, 03:29 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
im with you ,the wm shroud is one of the strongest out there ,you need a mega motor or one of the velocity motors they are longer and have the weight to make bigger power.
Old Sep 20, 2012, 03:02 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
If you did not flow corrected the MBS intake you will have problems with temperature as the fan does not get enough air.
the flight pattern looked very much like it had the original MBS intake.
Claus
Old Sep 21, 2012, 08:50 PM
Joined Nov 2011
I have cut out the old housing , but I am trying to decide what to put in in its place, maybe the 4s het on the 2w20 will have enough torque to move this bird. I also have the fandrive 3300 on the knock off velocity rc blade that might work on 5s... any ideas?
Old Sep 22, 2012, 01:36 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
the het will need a bit hotter motor than the 2-20 ...it only does @700-800 watts ....mine had 1400+ moves out pretty good ,what ducts do you have?
Old Sep 29, 2012, 07:50 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
once more a Draken build.
To adjust the parts and glue it together.... 1 hour for one side .
Claus
Old Sep 29, 2012, 11:27 AM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
sweet! is this another 70mm or is this a 90mm version?
once of these days, i need to order a 90mm cougar from you!
corsair nut is online now Find More Posts by corsair nut
Old Sep 29, 2012, 12:07 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
this is a 70 mm version.
I have to have one of the original ones!
I would be happy to make a cougar 90 mm version for you.
it means a bit of design work but ok ..
Claus
Discussion Made in Sweden J-35 Draken Jocke Electric Ducted Fan Jet Talk 45 Feb 03, 2008 11:37 PM
Discussion Saab Draken J-35 cyclops2 Japan 1 Aug 10, 2007 01:37 PM
Discussion J-35 Draken from blue fanfold. soarrich Pusher Prop Jet Models 0 Jan 08, 2006 06:27 PM
GWS J-3 Gets Flaperons, Build Photos 4throttles Parkflyers 9 Aug 12, 2002 01:06 AM
