Old Jun 17, 2012, 06:17 AM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
looking at the damage.
the shells is only 5 mm thick foam with epoxy glass (49 gr./Mē)
it is hard to say how many G's that have been at play here.
But it is a proof that this way of construction do its job well.
Claus
clausxpf is offline Find More Posts by clausxpf
Old Jun 17, 2012, 08:17 AM
Boogie_ is offline
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
That stinks, sorry.
Boogie_ is offline Find More Posts by Boogie_
Old Jun 17, 2012, 11:17 AM
jweber009 is offline
Find More Posts by jweber009
PH.D in Scratchbuilding
Denmark, Region Zealand, Holbaek
Joined Sep 2005
Sad to see it on video..... again.
We forgot the proper y-cable for the lipo's and had to use the spare. unfortunately the wires are not as thick on the spare and we learned the hard way.
I was considering to land on the pass before but decided to make another full throttle pass and then land afterwards. We landed but not the way it was planned.
I still had to big throws on the ailerons but it was a lot better than on the maiden. It's very easy to handle in the air.
jweber009 is offline Find More Posts by jweber009
Old Jun 17, 2012, 01:05 PM
ksqm is offline
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Clausxpf & Team,
Been watching both of these builds from the beginning. The Draken is one of my ultimate dream builds. Sorry to see the Class A mishap. The Misses thought something was wrong, I yelled so loud watching the vid. Hope you get another in the air soon. You guys are my inspiration.
Ksqm
ksqm is offline Find More Posts by ksqm
Old Jun 17, 2012, 11:55 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
so did the Y harness to the batts melt ? were you using a BEC for the RX? i use a seperate batt for the Rx and servos in all my high powered EDF's...i just think it is a safer way to control the palne.i use a 1100 mah 2s A-123 batt.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jun 18, 2012, 11:42 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
it was stupid me that did not get the right Y harnes with me!
That said ... that was last time ever a plane of mine will take the reciever power from the power pack, the most stupid part is i do have a lot of 2 S lipo's around 1000 mAh and bec's that made for that.
the good thing is that i now can concentrate on the 90 mm draken and the cougar.
and get the parts done for the new crusaider fuselage, and some wings for frank40.
Claus
Old Jun 18, 2012, 06:40 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yep i lost my F-20 prototype to a bad connection .....never again on big power EDf (more than 1000 watts) i use a seperate batt.at least you have control if you lose a motor or esc or lipo 's
Old Sep 07, 2012, 10:09 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Raising from the dust.
I have started to transform my drawings to G-codes now.
I will make one more for 70 mm fan.
using the cnc hot wire cutter.
when it is cut I know how much work there is going into it and how much material, then I can calculate a price for a kit.
Claus
Old Sep 07, 2012, 12:25 PM
Mikael is offline
Find More Posts by Mikael
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
hello Claus
What's happening with the bigger Draken
Mikael
Mikael is offline Find More Posts by Mikael
Old Sep 07, 2012, 12:55 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
as it is at the moment only hand cut it is a little on a Holt
It will come later but with only small money at hand I have to move for the smaller models right now.
And as my skills for cnc cutting improve ... I am close to start the 90 mm or the 110 Draken all over and take advantage of the cnc .
Claus
Old Sep 08, 2012, 11:58 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Sweet looking forward to what you come up with .
Old Sep 09, 2012, 08:52 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
to get rid of overburning
When you hot-wire cut cnc some areas have a tendency to over-burn.
one way to get around it is change a little in the design.
Old Sep 09, 2012, 02:46 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
what kind of dogs are those ...we had one that looked just like them .....oh the cutting looks great 1 what CNC cutter do you have?
Old Sep 10, 2012, 12:26 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
the near dog is Lettie, the mother of White eye. They are Border collies 100 %!
Lettie is 13 years old and White eye is 7 years old.
Claus
Old Sep 10, 2012, 12:54 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
cnc
this is the gear I have borrowed from anton-anton.
It is American made, and it works ok with max. cutting speed at 3mm/ sek.
the G - codes are with normal 1 mm cutting speed.
the wire is 0.15 mm Constantan wire. most cutting is done on 18 volts.
I have 742 mm between towers.
Claus
Discussion Made in Sweden J-35 Draken Jocke Electric Ducted Fan Jet Talk 45 Feb 04, 2008 12:37 AM
Discussion Saab Draken J-35 cyclops2 Japan 1 Aug 10, 2007 02:37 PM
Discussion J-35 Draken from blue fanfold. soarrich Pusher Prop Jet Models 0 Jan 08, 2006 07:27 PM
GWS J-3 Gets Flaperons, Build Photos 4throttles Parkflyers 9 Aug 12, 2002 02:06 AM
