Old Mar 03, 2012, 03:19 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
we dont use rudder on the one Clausxpf desinged ..track real well ...just cant see it due to the green color
AIR SALLY is online now Find More Posts by AIR SALLY
Old Mar 06, 2012, 10:44 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i now have a lower pitch fan rotor from Gary at Efflux R/C to see if i can find a better 4s-5s set up .so i need to pull the fan and ESc and get some numbers.
Old Mar 13, 2012, 05:19 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
did some testing out of the plane with the low pitch rotor on 4s and 5s ...the number were about 10% less amps ....with a few percent of watts lost ...so im putting the fan back in the airframe for testing .the super long ducts (22+") may cause the numbers to riase...well see.
Old Mar 17, 2012, 08:44 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
numbers did not change much ,amps when up like 2 on 4s and 3 on 5s ...that could just be the batts. so the fan does'nt seam to mind the long ducts ...neither did the WM400 it worked well with the long ducts too.
Old Mar 18, 2012, 12:50 AM
Mr Pheer is offline
Find More Posts by Mr Pheer
Mister Fear
USA, NV, Las Vegas
Joined Nov 2010
Think you will get longer flight time with the change?
Mr Pheer is offline Find More Posts by Mr Pheer
Old Mar 18, 2012, 03:25 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
thats why i did it .....flight time were good with the WM400 and the JS1400 motor.but the sound was causing proplem at my home field and that is why i change to the Garys Efflux R/C /Mach fan i have 4s and 5s batts so i looked for a motor that i thought would be good .so i chose the mega 3700 kv motor ....my batts were using 4000 mah in a 3 min flight and on 5s it was causing lvc or over temping ..not sure .so Gary had Mach work one of the fans into a lower pitch. it does'nt look like too much od a difference but the blades are not as wide and the air foil is thinner.also it has a hollowed out spinner...all to make a lighter rotor for more rpm. so hoping to see the mah used get back to where i was.i think on 5s it will fly pretty good ...4s might be a bit lazy for the weight of this plane ....a lighter plane should fly very well .i expect a bit more thrust at low speed just not sure what top speed would be .i have a 2.2 tail pipe so that is not for top speed either.hope to fly it at the buttonwillow Jet openhouse at the end of the month.
Old Mar 31, 2012, 10:03 AM
Rocketboy1030 is offline
Find More Posts by Rocketboy1030
Rocketboy1030's Avatar
Canada, ON, Mississauga
Joined Nov 2011
Air Sally here is my scratch built with not enough power . They dubbed it the unbreakable jet as it bounces on landing !
MMFC Scratch built Draken maiden test flight (0 min 31 sec)
Rocketboy1030 is offline Find More Posts by Rocketboy1030
Old Mar 31, 2012, 10:14 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
where was the C/G ? how much does it weigh
Old Mar 31, 2012, 11:36 PM
at-6 texan is offline
Find More Posts by at-6 texan
flyga ho ho sjunga ho ho!
at-6 texan's Avatar
Italia, Toscana, Bagno a Ripoli
Joined May 2009
i'm sorry for OT. Air Sally and clausxpf sorry for disturb but you have an pm.
at-6 texan is offline Find More Posts by at-6 texan
Old Mar 31, 2012, 11:41 PM
at-6 texan's Avatar
Joined May 2009
if they are not in error should be 1/57 inch from the edge of entry
Old Apr 02, 2012, 04:23 PM
Joined Nov 2011
Air Sally ; C of G ahead of the step in the delta,weighed in at 1300g without the battery.(Too much epoxy and Glass) The Eflite delta 70mm and 3600 motor didn't cut it. I may take out my thrust tube as it was very agressive and test again . For sure I needed a little more blast to keep it on plane. I may take the entire unit out and install the e jets 80mm and a 6 s setup.With almost 3KG of thrust it will stay up !
Old Apr 12, 2012, 12:47 PM
Joined Nov 2011
Retested with no thrust tube, results very much similar. I still need more power. Meanwhile the MBS models Draken is nearing completion, and it is much lighter.I think your model would be perfect for a 70mm EPO foamie. Do you have any plans to go further?
Old Apr 12, 2012, 05:10 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i only have the skills to have it done in fiberglass. unless some company would ask Claus for his drawings to do it in foam .i may make molds from mine to do a composite version ...but i still have a day job and several other projects to finish first.
Old Apr 12, 2012, 05:59 PM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Rocket boy and others.
the ducts that rodger have done from my drawings, for the draken are for "jet" speed. the intake that the MBS have done kills all the speed, too short and too hard angles for the intakes.
my xps foam glassed model with intake ducts made for me by "airsally" will be maiden shortly.
mine will fly on wm 400 fan and a 2900 kv velocity motor on 6 S 3300 mAh
it will be flown at the 5. jet meeting in Denmark june together with 4or 5 other models from my hand.
Claus
clausxpf is offline Find More Posts by clausxpf
Old Apr 12, 2012, 08:24 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Sweet cant wait for the flight report ...that velocity 6s WM400 set up is going to be awsome you will have a lot of power .i strip a servo gear on mine ...brand new Hitec's so im having to put in the third set of elev. sevos ....first one were sloppy,and would'nt center. the hitec broke just moving the elev. so i'll try a diff set of mg servos this time.
Discussion Made in Sweden J-35 Draken Jocke Electric Ducted Fan Jet Talk 45 Feb 03, 2008 11:37 PM
Discussion Saab Draken J-35 cyclops2 Japan 1 Aug 10, 2007 01:37 PM
Discussion J-35 Draken from blue fanfold. soarrich Pusher Prop Jet Models 0 Jan 08, 2006 06:27 PM
GWS J-3 Gets Flaperons, Build Photos 4throttles Parkflyers 9 Aug 12, 2002 01:06 AM
