Old May 15, 2011, 01:35 PM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
time tag 49 hours
that is my sanding sealer water based and very nice to sand with 240 - 400 grit paper.
Claus
clausxpf is offline Find More Posts by clausxpf
Old May 15, 2011, 02:50 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Claus
Looking good!
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old May 15, 2011, 10:21 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
that cougar looks AWWWWSOME!!!!!!!!!!
corsair nut is offline Find More Posts by corsair nut
Old May 16, 2011, 03:21 PM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
Man that looks sooooo nice
frank40 is offline Find More Posts by frank40
Old May 18, 2011, 11:50 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
time tag 53 hours of building.
paint and sanding takes hours.
But i got my vacumformed canopy for draken a few hours ago.
Old May 18, 2011, 09:10 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
That looks about right ...wax on wax off for a few days for you . i did a lot of sanding on mine ...now it's your turn
AIR SALLY is offline Find More Posts by AIR SALLY
Old May 19, 2011, 08:44 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
had to
as my draken will be red i could not resist to paint the canopy.
Claus
Old May 19, 2011, 09:35 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
man, that looks nice. good job Claus.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old May 19, 2011, 12:16 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
oh man .....i love the red ......i need mine red too
Old May 19, 2011, 06:17 PM
marell01 is offline
Find More Posts by marell01
marell01's Avatar
Sweden
Joined May 2006
Nice build Claus!
marell01 is offline Find More Posts by marell01
Old May 19, 2011, 08:47 PM
Lmeano_from_MO is offline
Find More Posts by Lmeano_from_MO
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
Looking good Claus,
It looks like it will be very lite weight. Will you be adding retracts?
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old May 20, 2011, 06:41 AM
5teve 5 is offline
Find More Posts by 5teve 5
Hampshire UK
5teve 5's Avatar
Joined Mar 2011
Just finished reading this thread from start to today, took me a month of lunch times and I have been inspired by your build methods. I have just converted a 1.5m glider into a twin 76mm ducted fan beastie. Both ducts cut from foam giving both the internal tube and the external profile. Keep the pictures coming
5teve 5 is offline Find More Posts by 5teve 5
Old May 20, 2011, 08:59 AM
jumpy is offline
Find More Posts by jumpy
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Very nice Claus. Quick question, is it best to paint the canopy on the inside or outside?
Phil
jumpy is offline Find More Posts by jumpy
Old May 20, 2011, 09:57 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
most of the model cars are painted on the inside...
but in this case i have painted outside as i want it to be the brightness as the rest of the model.
this one will not have retracts as i have not found the right electric retract that can work with only 70 degree of movement.
there is room for that kind of installation as ducts and fuselage is designed for retracts.
Claus
Old May 20, 2011, 01:44 PM
Joined Jan 2009
could you not make your own, like the Crusader build and actuate them with a servo, or linear actuator of some kind? might be better than a commercially available piece that doesn't do exactly what you want it to do.
I'm still considering using an electric screwdriver as the basis of operating the retracts on the Jaguar. I wonder if you can use this method to make bigger planes like that? then again, I'de need to make better templates and I have no means to do that, since I'm not computer savvy at all when it comes to CAD programs.
Discussion Made in Sweden J-35 Draken Jocke Electric Ducted Fan Jet Talk 45 Feb 03, 2008 11:37 PM
Discussion Saab Draken J-35 cyclops2 Japan 1 Aug 10, 2007 01:37 PM
Discussion J-35 Draken from blue fanfold. soarrich Pusher Prop Jet Models 0 Jan 08, 2006 06:27 PM
GWS J-3 Gets Flaperons, Build Photos 4throttles Parkflyers 9 Aug 12, 2002 01:06 AM
