Old Nov 24, 2010, 06:02 AM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Brent
Naturally but i have to finish my cnc mill and hotwire cutter first.
then i can surply precut foam blocks and drawings for it .
or if the interest is big enough make an epoxy/glass version of it.
Claus
The Velocity-RC team .
clausxpf is offline Find More Posts by clausxpf
Old Nov 24, 2010, 06:51 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
heck, even a pre cut foam piece kit would be really cool. and light. thats for a 90mm right?
corsair nut is offline Find More Posts by corsair nut
Old Nov 24, 2010, 07:39 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Brent
Right now i am making the 70 mm
But it could be done for the 90 mm i have done the shells for that one already .
it is only a matter of the box size sendt.
Claus.
Old Nov 24, 2010, 09:24 AM
tehachapi, CA
Joined Jan 2006
90 would be sweet!
Old Nov 24, 2010, 11:35 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
last 3 parts of Rhight side.
i think i can glue them together tonight.
Claus
Old Nov 24, 2010, 07:51 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i see ...after you have glued it together you sand it to shape ..you left it over sized so you could get a nice curve between the station lines.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Nov 24, 2010, 09:23 PM
kcaldwel is offline
Find More Posts by kcaldwel
The post-truth world
kcaldwel's Avatar
Joined Jan 2007
kcaldwel is offline Find More Posts by kcaldwel
Old Nov 25, 2010, 09:07 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Kevin.
I use the outside of the shell where the templates were.
But i do control the inside to make sure it fits good as it makes fiber glassing easier that way. Sanding inside is more throublesom than on the outside.
the extra outside material is to ensure enough room to have the sanding do a soft curve using the assambly line as "former"
I shall take pictures of the process and post them.
Claus
Old Nov 26, 2010, 02:41 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Beta saab Draken
now all parts are fine ajusted and glued together with mix of gorilla glue and light spackle.
notice that i placed the midle part first to have as little diviation in the final plane.
Total work time is 10 hours now.
Old Nov 26, 2010, 05:56 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
could not help it
glue was hard ..
had to rough sand it - both inside and outside.
Claus
The velocity-RC team
Old Nov 26, 2010, 07:16 PM
denispeters is online now
Find More Posts by denispeters
denispeters's Avatar
Joined Apr 2006
IŽd like to know the current weight of the shells and the average wall thickness
many thanks in advance
cheers
denispeters is online now Find More Posts by denispeters
Old Nov 26, 2010, 07:24 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Nice work Claus ...alot faster than the way i did it ,less glue too ,should be lighter for sure
Old Nov 26, 2010, 07:25 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
the weight is 75 grams ... and the thicknes is 5 mm or a little less.
Claus
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
no glass at the moment.
Claus
Old Nov 26, 2010, 09:20 PM
Joined Apr 2006
75 gramms for both shells
....simply awsome, I admire your skills
regards
Discussion Made in Sweden J-35 Draken Jocke Electric Ducted Fan Jet Talk 45 Feb 03, 2008 11:37 PM
Discussion Saab Draken J-35 cyclops2 Japan 1 Aug 10, 2007 01:37 PM
Discussion J-35 Draken from blue fanfold. soarrich Pusher Prop Jet Models 0 Jan 08, 2006 06:27 PM
GWS J-3 Gets Flaperons, Build Photos 4throttles Parkflyers 9 Aug 12, 2002 01:06 AM
