Old Apr 23, 2009, 11:08 PM
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Wait till we put the 5S 3200 in it
rvincent is offline Find More Posts by rvincent
Old Apr 23, 2009, 11:14 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
yeah, but it might stay up for about 3 minutes with throttle management in a airfrmae like this. its going to take a soild 50-60% power to keep cruising at a good pace, and a model this size wont benifit a whole lot from the extra power. with the 5000 4s, flights should be about 5 mintes or so, thats not bad. just look at the skyray for instance...we doubled the wattage, and performance was better, but it wasnt that amasing. these larger 70mm airframes just get to a point where the more power you stick to it..dosnt make that much change...now, a HP F-16 on a 5s 3200...we could spank that record no problem...
corsair nut is offline Find More Posts by corsair nut
Old Apr 24, 2009, 09:19 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
weather not looking good for tomarrow
AIR SALLY is offline Find More Posts by AIR SALLY
Old Apr 24, 2009, 10:50 AM
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
But its going to be really nice Monday !!!
Blue Skies............R Dub
RWCLOUD is offline Find More Posts by RWCLOUD
Old Apr 24, 2009, 12:03 PM
Thomas Nelson's Avatar
Calgary, Alberta, Canada
Joined Sep 2002
Best wishes on the maiden, Roger! Or Brent!
Thomas Nelson is offline Find More Posts by Thomas Nelson
Old Apr 24, 2009, 01:59 PM
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Great job!
Good luck on the first flight.
Cheers--Stacker
stacker is offline Find More Posts by stacker
Old Apr 24, 2009, 03:16 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
we might get this done this eveing as winds are forcast for sat
Old Apr 24, 2009, 03:31 PM
rvincent's Avatar
Joined Jul 2004
GET VIDEO!!! please
Old Apr 24, 2009, 05:14 PM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
sitting here 7000 km away and waiting for the maiden video.... man that takes power..
i wish i was there to see it first hand.
Claus
clausxpf is offline Find More Posts by clausxpf
Old Apr 24, 2009, 07:21 PM
Turn n Burn's Avatar
Joined Aug 2007
Good luck AS she really looks great....
Turn n Burn is offline Find More Posts by Turn n Burn
Old Apr 24, 2009, 08:10 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
looks like a blow out tonite .....im not in that big a hurry to trash it due to gusty winds ....i c/g it at 25 1/4 inches from the nose ...im just fwd of the c/g shown on your drawings claus(about 3/4 to 1: fwd ...sta. 650 is where you have it im a tad fwd of that .....the kicker is if you move just a 1/4" one way or the other it goes tail heavy or nose heavy im not real happy with the balance on the fan but i had to glue the alum hub to the rotor to keep it from spinning ..its real rough in the mid rpm's . the alum washer on the adaptor does'nt seem to touch the rotor much ...it pushes up to the alum cone but no pressure is on the rotor...i may have to counter bore the washer a bit to cure this proplem ....right now i can not get the hub off the adaptor .i'll have to get a puller i guess.(the rotor come off when the ca glue joint fails i believe it has more than enough power to fly ,the ground handling is not as bad as i though it would be...but it so windy on my drive way i cant really set up the steering
Old Apr 24, 2009, 10:00 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Good luck when you get her ready Rodger.
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: F7F Tigercat from Palmer Plans
Old Apr 25, 2009, 12:29 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
poor claus ...he's been waiting so long for this, thanks for the well wishes guys
Old Apr 25, 2009, 04:30 AM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Rodger
Do not forget that the rotor you got for test is a test shot from the not hardend mould. among the things i have changed going from mrk 1 to mrk 2 is a litlle more center thickness, to make sure the washer has something to push on.
Rounded corners at the where the fan blade meets the centre. and different profiles for the blade itself.
Claus
Old Apr 25, 2009, 05:01 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
thanks Claus ....i'll get it dailed in .....it is well enough for the madien .we put the "petro matt " runway in today at our club field . still windy but we might give it a try in a hour or so .
Discussion Made in Sweden J-35 Draken Jocke Electric Ducted Fan Jet Talk 45 Feb 03, 2008 11:37 PM
Discussion Saab Draken J-35 cyclops2 Japan 1 Aug 10, 2007 01:37 PM
Discussion J-35 Draken from blue fanfold. soarrich Pusher Prop Jet Models 0 Jan 08, 2006 06:27 PM
GWS J-3 Gets Flaperons, Build Photos 4throttles Parkflyers 9 Aug 12, 2002 01:06 AM
