Old Apr 16, 2009, 10:53 PM
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Cool! Rolling on its wheels under its own power
rvincent is offline Find More Posts by rvincent
Old Apr 16, 2009, 11:03 PM
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Rodger, sorry to heat about the BS. Your are right they aren't too bright. I hate dealing with them but at least it medical coverage even if its a dense one lol.
Look forward to test report.
Jason
FresnoJay is offline Find More Posts by FresnoJay
Latest blog entry: My new addiction.
Old Apr 16, 2009, 11:40 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
oh i forgot to metion that lil c/n was wearing out my DX 6 throttle stick .....he is a chip off his dad....he knows where WOT is
AIR SALLY is offline Find More Posts by AIR SALLY
Old Apr 17, 2009, 03:10 AM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
ROFL, Kids are the best. Love my little monsters and they both know what happens when dad pulls out the toolbox. Unfortunately the first questions are usually "Daddy you crash it?" . Sheesh .
Jason
Old Apr 18, 2009, 11:28 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Low speed Taxi complete
Good news i was able to clear the draken for low speed taxi test ...it was cool to see it move under it's own power it steered very well...i wanted to see if the WM400 had the thrust to get this thing moving .so i set it in some dirt and went straight to WOT...for about 2seconds and the thing shot off and rolled about 50 ft ...i was impressed . That really all i could do as i have a few issue to work out be for high speed / takeoff can be done
1) i have a serious battery connector proplem on my main power wires ,the radio and esc shut off if i wiggle the deans connector ...i've never seen this happen befor ,not sure if it is the bec power wires or the male Dean's giving the proplem ,i use 3 diff batts and i could induce a power failure with all of them by wiggling the connector not good
2)main gear legs are a tad short,so i'll see what i can do to fix this .
3)one wing is longer than the other,by atleast 3/8 of an inch ,i think i can fix it at the tips by adding to one and sanding some off the other.
4)need to install my airtronics rx and set up the radio .i was using my DX-6 and the sky ray set up ..but the alierons were backwards.thats why i did not try a high speed taxi.
i used a wemotec fiber glass tail pipe that i installed over the wm400 tail cone ,which i removes most of it except for 3 finger to hold the tail cone and stators.looks nice i used silicone to bond it to the fan shroud.
i also noticed the motor was plusating ever so slightly at WOT not sure if it is the esc or cold not fully charged batt.Bob have you run a JS1400 on a CC HV110 before?
i just weigh it tonite by holding it and stepping on a digital scale ,AUW now with out paint is 4.4 pounds. not sure if i can get any weight out of it but i'll be happy with 5 lbs total after paint
here some more pics. oh the last shot shows the wm400 V-2 rotor
Old Apr 19, 2009, 01:36 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
dad, just switch over to 6mm bullets. your going to need them at some point anyhow. it will make the setup in the bearcat much easier. dang, how did you build one wing bigger....thats really odd. are you sure? im a little worried about that tail pipe after the experience we had with your F-16, but i guess just make certain that its straight. also, if you use bullets on the packs, you can borrow some from me if needs be. looks good though. maiden set for next sat....
corsair nut is offline Find More Posts by corsair nut
Old Apr 19, 2009, 02:02 PM
That thing's operational!
birdlives1955's Avatar
New Orleans/Dallas
Joined Jan 2006
That's an amazing build! Great job Roger!
birdlives1955 is offline Find More Posts by birdlives1955
Old Apr 19, 2009, 02:37 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i dont think i have any 6mm bullets i think most of the wing thing is the tip block and the fuse i measured from might be fatter on one side
Old Apr 19, 2009, 02:46 PM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
i think ive got some you can use. yeah, i think your right. i see a bit more on one tip. try measuring from a differnt spot.
Old Apr 19, 2009, 03:04 PM
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
Very nice Rodger,
Question, is C/N going to be your test pilot? How much travel are you planning on using for a maiden start point?
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Apr 19, 2009, 03:25 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
well i'd like to do the madien but he'll be there if needed ...just depends how well i'm seeing it . i think 1"" up and down 1/4 to 3/8 alieron. there is a lot of surface area and deltas seem to roll a lot(read twitchy) ,i'll have dual rates to calm it down if needed ...the c/g seems sensitive if you move just a 1/4 " the nose raises or drops depending which way you go ..so i'll stay with a fwd c/g and keep the 1 " travel to trim out the heavy nose for madien.
Old Apr 19, 2009, 04:54 PM
P. Seitz
Iowa
Joined Jan 2006
good luck on your maiden !
Paul
seitz2c is offline Find More Posts by seitz2c
Old Apr 19, 2009, 05:11 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
AS, I have learned the hard way tail heavy for delta's, nose heavy for conventional birds. This way delta's dont loose ele authority.
As for the connectors, I am with CN just go to the 6mm-6.5mm connectors. I am running 6.5mm ones in my A-4 and anything that pulls more than 50A. No muss no fuss and full flow of current without worry of connection failure or power loss.
Jason
Old Apr 19, 2009, 06:00 PM
rvincent's Avatar
Joined Jul 2004
Yes Rodger my F-16 uses a CCHV-110 and 5S and works great Jason got to see it Friday. No issues with the esc at all.
Old Apr 19, 2009, 06:04 PM
Retired and Lovin' it!
United States, KY, Sturgis
Joined Jul 2007
Just out of curiosity since I haven't gotten into high current operations yet, but what size wire are you running that needs a 6-6.6 mm bullet connector?
Tony
tpfing is offline Find More Posts by tpfing
Discussion Made in Sweden J-35 Draken Jocke Electric Ducted Fan Jet Talk 45 Feb 03, 2008 11:37 PM
Discussion Saab Draken J-35 cyclops2 Japan 1 Aug 10, 2007 01:37 PM
Discussion J-35 Draken from blue fanfold. soarrich Pusher Prop Jet Models 0 Jan 08, 2006 06:27 PM
GWS J-3 Gets Flaperons, Build Photos 4throttles Parkflyers 9 Aug 12, 2002 01:06 AM
