Old Apr 12, 2009, 09:08 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
when i walk with it in the wind and hang on to a gear leg it is trying to fly out of my hand ....lots of lift ...but if you stall the outer wings the c/g moves aft and it will pitch up ,they do deep stall training with a 2 seater out here at mojave at the civilian test pilots school ...there was a vid on you tube ...it looks scary for sure ,,,cant wait to fly her
AIR SALLY is offline Find More Posts by AIR SALLY
Old Apr 12, 2009, 10:53 PM
Lmeano_from_MO is offline
Find More Posts by Lmeano_from_MO
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
Originally Posted by AIR SALLY
..but if you stall the outer wings the c/g moves aft and it will pitch up ,:
Something to watch out for on the deltas I guess. I was hopping for if power loss happens it would float in like my F-4 and 15 so looks like throttle up. Your Draken sure is looking like your close.
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Apr 12, 2009, 11:26 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
just spent the eveing going through this thread .....i am sorry this is taking so long ....but the end product will be very nice ...poor Claus is waiting for his baby to be born i'll see what i can get done this week .thanks for all the input all of you have made to this project.really trying to get it done by this sat or next. thats the best i can do
Old Apr 14, 2009, 12:25 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
got some more sanding done and sprayed a coat of epoxy chromate primer on tonite as a guide coat ...brite green
Old Apr 14, 2009, 12:59 AM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Man you gotta show us pics!! Even in nasty primer
rvincent is online now Find More Posts by rvincent
Old Apr 14, 2009, 03:47 AM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
AS, man you gotta share. I cant wait to see this one in person.
Jason
FresnoJay is offline Find More Posts by FresnoJay
Old Apr 15, 2009, 12:41 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
It's Green ....and it's alive
well i got the esc working ..took a bit but the CCHV 110 does work on 4s....so i got it all soldered up got a bec from C/N and a few phone calls later it was in the plane and running! on a storged charged XPS 5000 4s batt (16.35 and cold 50-60 degrees) it pumped out a peak of 1300 watts at 92 amps..it settled in at @ 1275 ish watts and 90 amps ...that should get it done so it only looses less than or right at 100 watts breathing through the 20 something inch long scale ducts...it's not pretty yet needs alot of sanding but i'll set it up and fly first......all the control surfaces are next and a tail pipe extension of some sort ....man it sure is loud in my small shop ,sounds like a dang schubie
Old Apr 15, 2009, 12:59 AM
rvincent's Avatar
Joined Jul 2004
Sweet Rodger! Kinds like the Incredible Hulk!
Old Apr 15, 2009, 01:46 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i was having trouble seeing where i needed to sand so i just put a coat on as a guide coat ..it needs a lot of filling ...maybe i should have put another coat of epoxy on ...but this is a waterbase epoxy primer and it sands nice and leaves a great finish ...this is what i use on all my plugs for molds...hmmmm
Old Apr 15, 2009, 08:25 AM
J Morgan is online now
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Ha! Man, it looks fast just sitting there Rodger!
J
J Morgan is online now Find More Posts by J Morgan
Old Apr 15, 2009, 10:39 AM
Thomas Nelson is offline
Find More Posts by Thomas Nelson
Thomas Nelson's Avatar
Calgary, Alberta, Canada
Joined Sep 2002
Fantastic work Roger. What a great shape - can't wait to see it slicing through the air!
You think it is strong enough to serve as a plug? Be a shame if it didn't release intact.
tn
Thomas Nelson is offline Find More Posts by Thomas Nelson
Old Apr 15, 2009, 10:49 AM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Rodger
one thing for sure it have got all the lines from the original .. you have got it right on the spot.
that green primer is it the same used for real aluminium airplanes?
the little drop in thrust static is part of the just right size for the duct in the air, the duct intake area will not slow you down..it is just on the step...
I am like a child waiting for christmas... to see that in the air.
Claus
clausxpf is offline Find More Posts by clausxpf
Old Apr 15, 2009, 10:55 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Hello Claus ..yes the green primer is a zinc chromate primer used for full size aircraft alum and composite. with some color on it you can see the lines and curves of this bird ...it wont be too much longer . it is snowing here today ...not good as all our fruit trees blossomed about 10 days ago . very windy here too . more pics tonite i hope ...im off to the doctors to see if there is anything i can do for a bone spur on my heel.
Old Apr 15, 2009, 01:34 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Rodger, She looks really slick and ready to cut up some air. Absolutely beautiful. Keep up the work and hope you can get the spur taken care of.
Jason
Old Apr 16, 2009, 11:35 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Jay ,Kaiser bites! i take a day off work go to the doc ...and they say i cancelled the app. i was not happy ....they would not see me i was pretty mad. so for now i guess i live with it ...not going to let a bunch of idiots cut me if they cant keep there app straight ...with a computer even
on a brighter note took "little c/n " down to the jet shack tonite(we were baby sitting) he said "Wow" a bunch of times talked some jibberish and started getting into every thing ...he was tearing off little pieces of foam from the cradle....i got the elevons hooked up tonite .alierons are backwards so i got to work that,and a tail pipe ...might get a taxi test in sat.
Discussion Made in Sweden J-35 Draken Jocke Electric Ducted Fan Jet Talk 45 Feb 04, 2008 12:37 AM
Discussion Saab Draken J-35 cyclops2 Japan 1 Aug 10, 2007 02:37 PM
Discussion J-35 Draken from blue fanfold. soarrich Pusher Prop Jet Models 0 Jan 08, 2006 07:27 PM
GWS J-3 Gets Flaperons, Build Photos 4throttles Parkflyers 9 Aug 12, 2002 02:06 AM
