Old Feb 01, 2008, 04:04 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
Valid LRK wind?
Folks
I tried this one last nite and it doesn't seem to want to work with any ESC that I have tried. It even spiked to 59A!!!! with a noload test. Yikes!!!
I will have to admit I'm trying this one with 10poles. I also carefully checked for any shorts and found none.
This is kinda like "Find Waldo".
B
fly_boy99 is offline Find More Posts by fly_boy99
Old Feb 01, 2008, 05:02 PM
landru is offline
Find More Posts by landru
landru's Avatar
Vancouver, Canada
Joined Mar 2003
Hi Bryan,
Do you have the opposing teeth wound the wrong way?
http://www.bavaria-direct.co.za/models/files/lrk.gif
Andrew
landru is offline Find More Posts by landru
Old Feb 01, 2008, 06:09 PM
fly_boy99's Avatar
Andrew
As you can see from the pic that it starts left,right,left on the star termination end it should be right,left,right. But if you look at the pic the start and endpoints for the winding are the same.
This is why I posted it and the pic must just be labeled wrong. I don't see how this can work for any lrk wind let alone mine.
B
Old Feb 01, 2008, 06:36 PM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
http://translate.google.com/translat...de/Schema.html
I did one with the five gram motor that was ABCABC. This diagram looks like AbCaBc, good according to the link for 10 or 14 magnet poles.
Len
LenBFP is offline Find More Posts by LenBFP
Old Feb 01, 2008, 09:05 PM
landru is offline
landru's Avatar
Vancouver, Canada
Joined Mar 2003
Bryan,
Yes, something seems odd here.
If we look carefully at the scheme diagram you posted, we see that when tooth no.1 is magnetized as North, the diametrically opposite tooth (no.7) is also magnetized as North. Trace the current flow and the direction of winding in any phase to see the outward facing polarity of opposing teeth.
Like-polarity opposed teeth are not typical of LRK as far as I know. Indeed, like you, I can't see how the scheme can work as drawn with 10 or 14 magnets.
Note that an odd number of permanent magnet pole pairs (such as the 5 or 7 poles pairs in LRK) always results in opposite permanent magnet polarity across the diameter of the bell.
I do understand that the intent of the posted scheme is to allow a more convenient wye termination. However, why the deviation from the standard magnetization?
Andrew
Old Feb 01, 2008, 10:57 PM
timocharis is offline
Find More Posts by timocharis
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
The diagram seems like a standard whitebread LRK wind, which has worked fine every time I did it. How many turns, what stator size etc? Delta or Wye?
Dave
timocharis is offline Find More Posts by timocharis
Old Feb 01, 2008, 10:59 PM
johnrobholmes is offline
Find More Posts by johnrobholmes
Engineer in training
johnrobholmes's Avatar
Columbia, Missouri
Joined Jun 2004
I noticed the same thing a while back looking at that winding diagram on some website. The opposing teeth are the same pole when magnetized, so it can't work unless you have 2, 4, 8 or 12 magnets.
johnrobholmes is offline Find More Posts by johnrobholmes
Old Feb 01, 2008, 11:03 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by fly_boy99
Folks
B
10 magnets should work. Did you make sure your magnets were N S N S N S all the way around? If you wound it correctly for LRK (which it looks like you have) the only thing I can think of is the magnets not alternating properly.
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 01, 2008, 11:06 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
A photo would be particularly helpful. Mondo macro, of course.
Dave
Old Feb 01, 2008, 11:37 PM
landru is offline
landru's Avatar
Vancouver, Canada
Joined Mar 2003
Look very carefully at the last two LRK diagrams on his page: http://translate.google.com/translat...de/Schema.html . Pay attention to the current flow and the 'hand' of the windings.
In one case the opposing teeth are like poles. In the other case the opposing teeth are unlike poles. Both cases cannot be correct.
I think Bryan has discovered the contradiction. He used the scheme from the bottom diagram.
Old Feb 01, 2008, 11:39 PM
landru is offline
landru's Avatar
Vancouver, Canada
Joined Mar 2003
I wonder if it will run with 12 or 16 poles.
Old Feb 01, 2008, 11:48 PM
Columbia, Missouri
Joined Jun 2004
Originally Posted by landru
I wonder if it will run with 12 poles.
I am drawing it out here, and I don't think it would work. The N poles would line up over every magnetized tooth at the same time, so it would have to be wound and terminated in a manner that kept all energized teeth the same polarity.
Maybe it would work, but I am not seeing it yet.
Old Feb 01, 2008, 11:51 PM
landru is offline
landru's Avatar
Vancouver, Canada
Joined Mar 2003
Originally Posted by johnrobholmes
...it would have to be wound and terminated in a manner that kept all energized teeth the same polarity...
Yes, agreed. Would the unwound teeth be magnetized as the unlike poles, and thus allow the motor to run? Starting problems?
Old Feb 01, 2008, 11:59 PM
landru is offline
landru's Avatar
Vancouver, Canada
Joined Mar 2003
Bryan, you haven't unwound that stator yet, have you?
Old Feb 02, 2008, 01:29 AM
lucent is offline
Find More Posts by lucent
Joined Jan 2005
It looks like it is terminated improperly. I could be wrong. I usually am
lucent is offline Find More Posts by lucent
Discussion 6 stator tooth LRK wind? rcnutt Electric Motor Design and Construction 4 Apr 03, 2006 08:48 AM
LRK wind help requested please Rocketman209 Power Systems 6 Dec 06, 2005 11:40 AM
