| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#61 |
For what it's worth.
#62 | |
http://www.uavp.de/index.php/en/Down...l-options.html This link says 3.14, but it's really 3.15. Rusty |
#63 |
#64 |
Well done. We can certainly see that the UAVP is not happy with the receive channels. Channel 1-5 must be within 100 and 1FF, or no green light. Channels 6 and 7 don't matter. I assume you have no compass?
First, make sure your radio is in Airplane mode, not helicopter. There should be no mixing at all turned on. Set channels 3 and 4 to "reversed", and leave the rest on "normal". Verify that you have connected K12 connectors as follows: pin-1 to ground on any servo channel of the receiver pin-2 to channel 1 signal pin on the receiver pin-3 to channel 3 signal pin on the receiver pin-4 to channel 5 signal pin on the receiver pin-5 to channel 7 signal pin on the receiver (this is optional) pin-6 to +5V on any servo channel of the receiver. Finally, make sure you have "throttle channel 3" on UAVPSet. FWIW, I just ran the new test software myself, and here's a capture. I do have a compass, and the barometric pressure sensor, so it will be a bit different from yours. I am only using 5 channels, and you see that 6 and 7 "failed", but it still says the receiver channels are "OK". Good luck, Rusty |
#65 |
#66 |
#67 |
Did you get a green LED with the AR6000?
The UAVP was made to work with a common PPM type radio, using individual channels, rather than requiring all the channels in one PPM composite pulse stream. This is the only quadrocopter I know of that allows this. All others require you to either use their receiver, or modify one. The PPM composite is a string of pulses, one for each channel. The width of each pulse determines the servo position for that channel. The pulses follow one right after another, then start over. In order to save inputs, the UAVP folks realized that if you know where the odd channels start and stop, the time in between must be the width of the even channel pulses. This allows them to determine the even channels, even though they were never physically connected. Pretty slick. Bottom line, the UAVP sees all the channels, so don't try to help it by getting too creative Channel 1 is roll, 2 is pitch/nick (never figured out where "nick" comes from), 3 is throttle, 4 is yaw, 5 simply switches between two pre-set flight parameter files. It's very important that there be no mixing. Advanced modes like PCM, and whatever CCPM is, can throw it off, and the whole 2.4 GHz line has really thrown a monkey wrench into it. There's no rule that says radios must use the old PPM timing of channel outputs, so there are some receivers that simply won't work. I still believe your Futaba will, though I'd never choose that over 2.4 GHz. Rusty |
#68 | |
Rusty Last edited by 13brv3; Mar 30, 2008 at 09:04 PM. |
#69 |
#70 | |||
Rusty |
#71 |
#72 | |||
As for "mixing everything around", I'm afraid you're trying to make this harder than it is. You don't mix anything. You don't have to move, or reassign any channel. You want the most basic airplane mode you can get on your radio. If you hook up channels 1,3, and 5, the UAVP will see 1,2,3,4, and 5, just exactly as if you hooked all of them up. If you add channel 7's connection, the UAVP will see ch 6 and 7 also. FWIW, 6 and 7 aren't used unless you want to tilt or roll your camera manually. Even with 5 channels, the UAVP will gyro stabilize the camera in tilt and roll directions. Quote:
Cheers, Rusty |
#73 |
#74 |
#75 | |
Do you have access to an oscilloscope? Rusty (off till tomorrow) |
| Thread Tools | |
| New source for 32p 9t pinion for corona | darthdrk | Electric Heli Talk | 5 | Feb 17, 2004 04:09 PM |
| New source for depron....... | Summer | Foamies (Kits) | 0 | Nov 13, 2003 01:02 AM |
| New Source For Micro Plans!!!! | Taniwha314 | Indoor and Micro Models | 4 | Aug 09, 2003 03:11 PM |
| new source for control surface centereing rubber bands | Dylwad | Indoor and Micro Models | 6 | Jul 05, 2002 10:06 PM |
| Need a new source for Li-ion | GHarvey | Parkflyers | 3 | Jan 02, 2002 11:51 AM |
