| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 |
Joe, you might be waiting a long time to see my MK fly
You probably want to find someone who speaks German As for the baro testing, I got my new boards today, and they look great. Awesome service from Ken's shop I expect to install a couple of them this weekend, and try them out with 3.14 and 3.15b3 software. There's a very real chance that my homemade board isn't as good as the ones I got today, and perhaps I was having a noise issue of some sort. We know 3.14 works well, but has a problem with certain conditions. 3.15 should fix that, and I'll find out this weekend. I also realize that I've been remiss in posting pics and videos. I desperately need to start a web page, for that and my other hobby (experimental aircraft). Cheers, Rusty |
#47 |
Hi Rusty & guys,
I have just made a successful outdoor flight of the UAVP. As stable as the x-ufo is my general feeling. However, I managed to let the bad smell out of the right esc again. This is starting to worry me. For some reason, I have managed to burn 2 escs all in the same location (right side). This is more than a coincidence. What could be the reason ? At first I thought it was the bec but that still works. That means something else is dead. I worry .Anyway, I am designing a landing gear cum camera holder thing so that I can do fpv eventually. Rusty, can I copy your design for my own use ?Regards, Joe Ling |
#48 | ||
The UAVP uses the BEC from the front ESC for the flight board. The left BEC isn't used at all. The rear BEC is used to power the "Aux Servo 1" (K5). Finally, the right BEC is used to power the "Aux Servo 2" (K6). Do you have anything plugged into K6 that might be causing a problem? Quote:
Attached are a couple more pics. There's a ton of room for improvement on these, but overall, I really like the idea. These are a bit heavy, but they are strong, and should offer some camera protection in the unlikely event of a crash The center portion can easily be made to tilt via servo if desired, and one of these days I'll get around to it. Just too many projects right now. Cheers, Rusty |
#49 |
Hi Rusty,
Sneaky me already spy on your UAVP pics from earlier & made a premliminary design using autocad LT :![]() I'm kind of worried about the right esc. The first time it burned out, I was using a GWS motor. Yesterday, I had a different Himodel motor on. So, it's still a mystery at the moment. Regards, Joe Ling |
#50 | ||
UAVP 3.15-beta3 Camera Gimbal test
Hi All UAVP pilots,
I have tested the 3.15b3 and the camera servo port is working very well.
#51 | |
So have you tried the altitude hold yet Cheers, Rusty |
#52 | |
I don't think my cheap frame can handle the crash. I better wait...
#53 | |
Spark antenna on my Tx !
-EEK |
#54 | |
from 1000mm quad thread
The UAVP hex files are not really radio specific. Once you find the hex file that is correct for your combination of hardware, you will have two radio types to choose from. One is for "normal" receivers when you are plugging in the odd channels to the UAVP board. The other type is for PPM composite signals, which are generally from modified receivers. Examples: Profi-Ufo-V314-CAM0-ADX300-PPM.hex Profi-Ufo-V314-CAM0-ADX300-RX_PPM-PPM.hex Both of these are 3.14 flight software, gyro stabilization is set for the camera pointing straight forward, three ADX300 gyros, and normal (not I2C bus) motor controllers. The first file is meant to use the receiver's odd channels plugged into the UAVP board. The second file with the "RX_PPM" is meant to use a PPM composite input from a modified receiver. Unless your receiver has been modified, or if you have some sort of external converter on it, you'll almost certainly be using the hex files without the "RX_PPM" in them. Post 17 in this thread gives lots of links to the information you need, and may already have. Post 24 talks about getting a green LED by adjusting the end points. As for receivers that work, I'm sure I've read that people are using the AR6000, but I'm not sure if there is any special configuration on the radio. I do know that the AR7000 guys are struggling with external converters to try to get them to work. I would guess that the Futaba 7ch receiver will work also. If you have any other questions (after regaining consciousness from reading all this ) post them in this thread, and I'll try to help. Cheers, Rusty Last edited by 13brv3; Mar 30, 2008 at 10:54 AM. |
#55 |
For what it's worth.
#56 | |
Cheers, Rusty |
#57 |
#58 |
Hi Vic,
Let's start with the hex file for now. You said you have ADX300 gyros. What type of motor controllers are you using? Rusty |
#59 |
#60 | |
Profi-Ufo-V314-CAM0-ADX300-PPM.hex For now, since you're so good at loading hex files, install the test software named: TestSoftware-V314-ADX-PPM.hex Run the RX test, and see what it tells you. You'll get bonus points for a screen capture A close up picture of how you have the receiver connected is often helpful as well. If it makes you feel any better, getting the green LED is the most common problem, but it's usually just a matter of setting end points for each channel that are within the range the UAVP wants to see. I wrote post 24 of this thread for people who don't have the test software available, but it's worth reading if you haven't already. Rusty |
| Thread Tools | |
| New source for 32p 9t pinion for corona | darthdrk | Electric Heli Talk | 5 | Feb 17, 2004 04:09 PM |
| New source for depron....... | Summer | Foamies (Kits) | 0 | Nov 13, 2003 01:02 AM |
| New Source For Micro Plans!!!! | Taniwha314 | Indoor and Micro Models | 4 | Aug 09, 2003 03:11 PM |
| new source for control surface centereing rubber bands | Dylwad | Indoor and Micro Models | 6 | Jul 05, 2002 10:06 PM |
| Need a new source for Li-ion | GHarvey | Parkflyers | 3 | Jan 02, 2002 11:51 AM |
