| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
See Us On Wikipedia
Thrust Mod For Stick Planes?
If someone made a 3 degree down and 3 degree right thrust mod adapter for the slow stick or any of the other stick planes they would be rich.
I usually make my own by hand from redwood pieces, but it's a pain to do. Is anyone making a decent one that can be used for on the Slow Stick, DuskStick, Stevens Aero Stick or the dozens of other "stick" planes that can be made of the aluminum SS fuselage? Links would be a bonus. I know there must be someone, somewhere making these. I'd like to mount this style of motor to it. Thanks, Frank |
#2 | |
Master of 1 point landing
#3 |
Bernoulli+Newton=Lift
Here's what I do:
Take 3/8" square stock, cut to desired length Determine how far back on stick it must be glued to plane, and mark there. Determine what thickness a shim must be to point stick down 3 degrees Glue shim on motor mount stick Then I glue the stick onto the plane at 3 degrees to the right. (I do keep the aft section of the stick offset to the left, so that motor / prop sits close to centered.) Then any motor mount with a 3/8" square section will slide right on / off, to be held in place with a set screw. Since I swap various motors on and off lots of planes, this simplifies and speeds up this process. One helpful aspect to this is that it typically places the shaft of the motor in a more centered position relative to the fuse itself, instead of being offset up or down. The other nice thing about this set up is that if I do somehow manage to nose the plane in (which fortunately is rare these days), the motor mount snaps off the fuse, saving the prop shaft. |
#4 |
See Us On Wikipedia
I understand all this and like I said, and do make my own out of redwood stock I get from Home Depot. This is normally the only thing that survives if I bite it big.
The thing that I am wondering, based on all the far reaching contacts we have here on RCG, is that someone, somewhere might have seen someone that makes these thrust mods. Frank |
#5 |
Gord
Don't know how you you could make one fit all as different planes need different amts. of down and side thrust, unless you could make it adjustable, which is'nt impossible. I make mine from plastic kitchen cutting board wacked out on the bandsaw. Nearly indestructable.
Gord. |
#6 |
Sky good, Earth bad!
I saw a mount that you could adjust the thrust deg for stick mounts. I will have to search around a bit to find it. Maybe I saw it around here???
Dak... |
#7 |
Who says' EPP dont break?
For the sticks I wouldnt wory about it. My uncle has a park 480 in it and its fine.
#8 |
See Us On Wikipedia
Tough one, isn't it? I've been looking for a long time also.
Frank |
#9 |
See Us On Wikipedia
These are probably the coolest/strongest motor mounts going, but alas, no thrust mod.
http://www.strongrcmotors.com/Mounts.htm Frank |
#10 |
...back to reality.
I've flown mine with down and right. Found the right just made it pull to the right. I straitened it out to pull straight and true. Left the down in because it noses up at WOT.
It would be easy to cut the top part off the motor mount and drill the fuselage with a bit of down angle. You would need to drill two holes to hold that angle. |
#11 |
See Us On Wikipedia
I guess everyone that owns a "stick" plane must fabricate their own stick mounts.
That's interesting. Looks I will continue to do that also. Frank |
#12 |
old aussie
For adjustable down thrust I use GWS aloy stick mount with a 3mm taped hole in the top[behind the front through mounting bolt] -grind down the head of a 3mm bolt til its about 1mm thick fit the bolt with the head against the stick and put a locking nut on the top side,you can then adj bolt up/down to try diff thrust angles[after prop size changes]
Russ |
#13 |
Hi All:
I have one of those plastic motor mounts that you get from Heads Up RC. I think they were originally made for some sort of brushed motor but I have an outrunner bolted to mine. That mount goes onto the fuse. The fuse is that black plastic stuff that came with the GWS kit. A bolt (or maybe two bolts, can't remember) goes through the mount to hold the mount on the fuse stick. Anyway, I really need down/right thrust. Given what I am using for equipment, discussed above, what is the best way for me to get the thrust angles I am looking for? Maybe you could send a photo if you have one that will work with my setup? Thanks for your help. Michael |
#14 |
I don't have one of those mounts so no photo available, but I visualize cutting a round disc of plywood, or something similar, and gluing it into the plastic circle. Then bolt the firewall mount to the plywood orienting the two screws that are closest together on top. You should be able to put some washers under the top-right screw (while facing the front of the plane). This should point the motor down and to the left. (Looking at this from the pilot's view, the motor would be down and to the right.) Add/subtract washers to get the proper angle.
Bill |
#15 |
Deletedfor proving Nauga wrong
For wood sticks mounting the motor in the original post...
Shave a wedge off the side you want to shift AWAY from and glue that same wedge back on the opposite side of the stick. You will have shifted the thrust line by the wedge angle. (you could also sand the wedge off... glue on just a shim at the front opposite side and it will work) For aluminum sticks... you can sometimes put the fuselage in a vice about 1 inch behind where the motor mounts and use "square pipe" slip fit over where the motor mounts to bend in the desired thrust angle change. You could also file the wedge angle off and shim the opposed side. Where there is a will... there is a way. |
| Thread Tools | |
| Wanted Thrust Mod for 10MM Square Tubing | Murocflyer | Aircraft - General - Miscellaneous (FS/W) | 10 | Feb 07, 2008 12:06 AM |
| Thrust Measurements for 3D Planes??? | Seared Ice | 3D Flying | 4 | Jun 15, 2004 08:27 PM |
| Looking for Slow Stick Thrust Mod! | tdavis | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 06, 2004 01:56 PM |
| Down-right thrust mod for Slow Stick? | danawatson | Electric Plane Talk | 2 | Feb 06, 2004 08:26 PM |
| first mod for stick ??? | jeffhines | Parkflyers | 1 | Feb 04, 2002 08:36 AM |
